Page 11 of 15 FirstFirst ... 910111213 ... LastLast
Results 401 to 440 of 599
  1. #401
    Established Member Two Rings camc's Avatar
    Sep 15 2009
    White Rock, BC
    Quote Originally Posted by drumnjuny View Post
    there he is!
    08 A4 2.2TQM SE Ti Sline GT35R 419awhp 375awtrq 91octane
    http://www.blitzkriegautowerks.ca/
  2. #402
    Nov 03 2012
    CA
    The story of my car in PerfExpert dyno plots...
    Here are my PerfExpert settings for the car:
    I did PerfExpert pulls as I have made each change so far. While I take the absolute numbers with a grain of salt, they are probably comparable to each other, and I think they tell an interesting story. I have at least 3 pulls at each step, and the graphs are pretty consistent at each step.
    When I first got it used it already had some unknown tune on it, but was otherwise completely stock, ie k03 etc. One of the first things I did was to install a boost gauge, and the car was peaking around 16psi boost if I recall correctly.
    Here is a dyno log from when I got it:
    Then I flashed with a base tune from Maestro:
    Then I installed new coil packs (red) and plugs. Not a bad little bump for just red coils and plugs, especially if you already need to do it.
    Then I had a 034 HFC installed. Not a huge hp diff, but a nice bump in torque, which I assume is because the turbo gets to kick in earlier.
    Then I installed an hpfpupgrade stage 1 pump and re flashed with what Maestro refers to as their stage 2 base file. Wow. Torque bump plus look at how everything smooths out, and peak hp is achieved and held so much earlier. I definitely notice this in the butt dyno.
  3. #403
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Here are my dyno's
    Both uncorrected and corrected.
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
  4. #404
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    NIce!
    2021 Audi S4, P34 Intake
  5. #405
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by seal66 View Post
    Here are my dyno's
    What kind of dyno was this ?
  6. #406
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Dynocom AWD 5000-FX
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  7. #407
    Feb 06 2009
    328d, Tacoma
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  8. #408
    Veteran Member Four Rings Mc Suly's Avatar
    Aug 20 2010
    B7 RS4
    Québec
    DYNO RESULTS F23 frankenTurbo:
    1st file: 268.6WHP & 308.8 WTQ
    2nd file: 273WHP & 312WTQ
    3rd file: 299.5WHP 353.1WTQ (sweet numbers but not smooth & all over the place like a "W")
    Boost :25.81PSI
    4TH FILE (CURRENTLY & WILL BE IMPROVED): 279.7WHP 323.5WTQ
    Boost: 23.67PSI
    As you can see in the graph that dip is what Epic Tuning is trying to fix.
    Complete Info: http://www.audizine.com/forum/showth...3%96WP%C3%96KE
    B7 RS4
  9. #409
    Aug 05 2011
    CO
    Quote Originally Posted by Mc Suly View Post
    Boost :25.81PSI
    Boost: 23.67PSI
    Dude that is awesome numbers! How does it feel driving?
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
  10. #410
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Jesus...who is tuning this thing...that dyno is mega fucked...
  11. #411
    Aug 20 2010
    B7 RS4
    Québec
    Really quick, barely any lag! Basically what i wanted.
    Not finished yet though! Working on maps!
    Need to stop bashing man, the tune is still being worked on & isn't completed!
    It will be done soon & will show!
    B7 RS4
  12. #412
    Mar 24 2013
    Oakdale, CT
    The fix is probably as simple as adding timing and making sure it has enough fuel.
    -Adam
  13. #413
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    haters gonna hate :) I'm just surprised the tuner is doing WOT runs with a half done tune....no big deal
  14. #414
    Jun 17 2013
    jersey city nj
    It will if that tune runs lean. There's gonna be alot of internal melted metal
  15. #415
    Aug 20 2010
    B7 RS4
    Québec
    You can h8 all you want!
    Like i said, i'm the tester & they are testing for an optimal tune.
    Soon enough, will have a great tune!
    B7 RS4
  16. #416
    Mar 24 2013
    Oakdale, CT
    MED9 ECU is a big boy and can handle things for the most part. If the fuel trims are excessive it will chop timing. I know this from experience.
    -Adam
  17. #417
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by vce1232000 View Post
    exactly.
    I'm just not a fan that it is misrepresenting data. saying you made 350awtq is like saying I can do 400awhp on stock rods....can you do it, sure, but you will not last more than 2 days at that power. I would be interested in what the turbo can do reliably with a daily driver tune.
  18. #418
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Dude these ECU's practically tune themselves.
  19. #419
    Mar 24 2013
    Oakdale, CT
    I think mine actually does. I make changes in Maestro and the car just fucking ignores them and does what it wants.
    -Adam
  20. #420
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    lol right? I feel that way all the time. I also always make tiny changes, you have to make big changes to see results, but big changes are dangerous! i was going up one or two degrees of timing at a time, finally I was like feck it! added 10 degrees then I noted some power increase!
  21. #421
    Jun 17 2013
    jersey city nj
    Gotta love Artificial Intelligence
  22. #422
    Senior Member Two Rings TPW's Avatar
    Jul 28 2013
    09 Jetta Sportwagen
    Ojai, CA
    Boost :25.81PSI
    Boost: 23.67PSI
    This is ugly above 4500 or so and I wish they used the same Y axis scales for torque and HP as well! I would love to see spark advance and BSFC and Lambda plotted as well. I bet this thing went either very lean causing spark retard due to detonation or something like that - I can't tell because there isn't enough data. One thing I do know is that engine is going to be more than happy to grenade itself when you rev it high. I'd also like to know how the rods are going to hold.
    Ted
  23. #423
    Mar 24 2013
    Oakdale, CT
    He built the engine, so the rods will hold just fine.
    -Adam
  24. #424
    Aug 20 2010
    B7 RS4
    Québec
    Quote Originally Posted by TPW View Post
    Yup!
    Testing this weekend.
    When the tune is right, will re-dyno
    B7 RS4
  25. #425
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Yup!
    Will you be doing any 1/4mile testing too?
  26. #426
    Aug 20 2010
    B7 RS4
    Québec
    Quote Originally Posted by Jake@JHM View Post
    Almost done!
    I wish, full of snow & ice up here!
    Only opens up like end of may/june aprox
    B7 RS4
  27. #427
    Dec 03 2008
    2018 SQ5
    Scheduled appointment for Monday to do my 2+ dyno. ..
    Sent from my SGH-M919 using Tapatalk
  28. #428
    Veteran Member Four Rings A-BlacK_MambA-4's Avatar
    Jan 22 2011
    '05.5 A4 2.0T Tip Revo Stage 2; Wifes 2013 Chevy Cruze
    Ohio
    Excited to see the results. I need to get my 2+ tune already and hit the dyno too.
    -JOEL
    The Real Black Mamba
  29. #429
    Aug 05 2011
    CO
    Hopefully my new dyno run's well excite people
    Sent from my Nexus 7 using Tapatalk
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
  30. #430
    Dec 03 2008
    2018 SQ5
    What dyno runs? You already did some? And........ numbers?
  31. #431
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    at BW... dyno tune = dyno runs! lol
  32. #432
    Aug 05 2011
    CO
    Yeppers. They are working hard on my tune. Seen a graph and I like it
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
  33. #433
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i need a new tune, but i definitely cannot wait a month and a half without my car for one... looks like BW is out sighhhh
  34. #434
    Veteran Member Four Rings Firefox250's Avatar
    Nov 17 2009
    BT B7 A4 Sedan Quattro & B7 A4 Avant Titanium 2.0T Quattro
    Aurora, Colorado
    Is that how long BW quoted you it would take to tune your car?
    Tuned by UNITEDMOTORSPORT
    HTA3073 Build page
    Bluewaters Performance blog on my build
  35. #435
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    no but they've had seths car for like 2+ months... i need my car to go to/from work. i could sweat it out for like a week maybe two max but definitely not 3 and most definitely not 6 or 8 weeks
  36. #436
    Nov 17 2009
    Aurora, Colorado
    Seth car is breaking new ground with his tune by being the first E85 tune and using a Mk6 Golf R tune. Jeff from UM and Gabe are testing everything to make the tune perfect. So I bet with you it would only take a week. Schedule it ahead of time to call a rental car shop.
    HTA3073 Build page
  37. #437
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i'm just not tryna get in a situation like i did with RAI where they dicked around and didn't get it done on time and then i missed an extra week of work (here the cost would much less as it would just be the rental vs. the opportunity cost of a weeks worth of work, and the problem would not be dicking around but the distance between UM and BW)
    A week would be fine by me. I don't understand why it takes a week in the first place, haha... only took 5 revisions and a day for Dan to get to 415awhp . but whatever i have to take what i can get I suppose. HPR or bust
  38. #438
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by Firefox250 View Post
    Ah, did not know that wad the route seth was going already. We don't tall like we used to :( super excited to see results in that case. E85 does amazing things for other cars.
  39. #439
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    yeah i know he is doing e85 but even before then when he was getting K04 tune'd they had his car forever right?
  40. #440
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    i mean being realistic, i have no other in state options so.
