Results 1 to 30 of 30
    Oct 25 2009
    Overland Park, KS
    What tyre pressure are you running?
    The 41 psi liseted by Audi is probably the high limit for sustained high speed driving, and if thte car is fully loaded.
    IMHO it makes the car ride quite 'rough', and the tyres are noisy on the interstate.
    Anyone tried running slightly lower psi, and if so what are your thoughts on ride, performance, etc.
    Bish
    Veteran Member Four Rings jriddle11's Avatar
    Mar 26 2007
    B7 3.2Q and C7 A6
    Byers Audi - OH
    I have a B7 on 19s and I run 37 psi.
    Audi Brand Specialist / Social Media Manager / Spokesperson Byers Imports (Audi, VW, Porsche, Subaru)
    Current: B7 OEM+ and C7 OEM
    Previous: B5, B6, B6 USP All OEM+
    Veteran Member Three Rings Zed 2.0's Avatar
    Feb 12 2010
    San Diego
    Quote Originally Posted by thebishman View Post
    Bish
    Where are you seeing 41 psi? Your manual has a chart of tire pressures listed depending on tire size, load and speed. For example, the 255/19s with normal load are 36F/33R.
    Active Member One Ring obriengp's Avatar
    Mar 30 2010
    2004 A6 Avant 3.0 - 2009 Honda Fit (Hers)
    Bethesda MD
    34 seems to be best for me.
    2004 3.0 Avant
    Established Member Two Rings Leo's Avatar
    Oct 03 2009
    2010 S4, 2005 997 Cabriolet, 2008 A6 Avant, 2011 Yamaha Apex SE
    Montreal
    Quote Originally Posted by Zed 2.0 View Post
    On Canadian models running 19"s, there is a sticker on B-Pillar, drivers side clearly indicating that 41psi should be used. I'm running 41 psi and have no issues with that pressure. Remember to check your tire pressures regularly (cold tire pressure) especially during seasonal temperature changes.
    Dec 02 2009
    Rochester NY
    Quote Originally Posted by Leo View Post
    Same sticker on US models.
    Mar 26 2010
    US
    The Tirerack website lists the Audi 2010 S4 Maximum OEM tire pressure of 50-51 lbs/in^2, depending on the tire manufacturer,
    so I guess operation at 41 lbs/in^2 should be just fine.
    Maybe tyres take a different pressure level than tires (imperial pounds?)?
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    45psi all around.
    but that's on an A6...
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Dec 03 2006
    Singapore
    running factory 255/19inch on the five arm tri-spoke wheels
    have tried the lower differeing pressures in the door sticker, feels a bit lumpy here in tropics and 'not sharp'.
    now running 2.8 Bar (thats 40.6 PSI folks) all round, car feels great and am leaving it at that.
    Active Member Two Rings machattackii's Avatar
    Mar 29 2010
    1992 Montana Green VW GTI 16v
    Boston, MA
    Same sticker in my car, 41 psi seems high though, should we be running 41 psi? I have mine at 32 psi
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    on my 19s ps2 oems, i use 2psi more in the front than the rear. 42,40 is the current numbers I have them filled to.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Topic discussed ad nauseam....
    245/40 18 - 39 front 35 rear ONLY under full load conditions 41 all around
    255/35 19 - 36 front 33 rear ONLY under full load conditions 41 all around
    As always check your tire pressure when its cold.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Mar 02 2007
    Fresno, CA
    40 on all 4 corners for me. When in doubt, I'd rather go a little on the high side to avoid bent wheels.
    Veteran Member Four Rings Seinsmeld13's Avatar
    Mar 23 2009
    2020 Porsche Spyder
    Niagara Region, Canada
    Correct pressure is 39r 35r when fully loaded 41 f and r. That is for the 18". Manual as always will tell the correct info, door jamb only lists for fully loaded car which rarely occurs for me.
    Sep 03 2009
    The tires run hotter the lower the pressure. In the hotter weather I use more pressure. The difference between hot and cold pressures is 10% , so if you are 40 cold and 44 hot, it would be a decent setup. Or 30 cold and 33 hot, but it would more apt to be 35 hot due to the increased tire hot temperatures. My fx45 had the pressure reading in car, so it made finding the right pressures easier in that one. 30 mins of highway speed is enough for a hot reading. At the track the numbers for a street tire are different.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Oct 25 2009
    Overland Park, KS
    Quote Originally Posted by HyperM3 View Post
    Please tell me exactly where on the car, or in the manual it states those numbers.
    Bish
    Mar 20 2004
    Lawrenceville, NJ
    Bish
    Page 278 for me. Also found it in the index as to what page to look. Seriously I'm amazed here.
    20 BMW R1250RS
    Veteran Member Four Rings ahcow's Avatar
    Apr 26 2010
    Toronto, Ontario
    Crap, I am running 41psi all around but my car is never full. Need to adjust it now
    New: 2016 S3, Sepang Blue, Sport Seats, S-tronic, Tecknik, LED
    Old: 2010 S4, Brilliant Black, Magma Red Nappa, S-tronic, Nav, Sports Differential
    Mods: Strat Intake, 35% Ceramic Tint, RS5 Pedals, BE GTS-AV, Hawk pads, Alu Kreuz, Vag-com, APR Exhaust
    Mar 26 2010
    US
    My car was delivered from dealer with 41 LBs all four corners.
    Most cars/trucks, list both the normal and the full load tire pressures inside the door jamb or gas cap cover.
    My last three cars did and my wife cars lists, the different load tire pressures.
    BMW M3 Competition X-drive
    Veteran Member Three Rings rktskicar's Avatar
    Dec 12 2009
    Quote Originally Posted by wwhan View Post
    This one does not though. Only list full load psi on door jamb. Need to look at users manual to see other load conditions.
    Bruce
    "I think the car is too damn quiet and smooth. It doesn't seem like you're hauling ass until you look down at the speedometer."
    Stock ECU, Sprint Blue 6MT 010 B8 S4, Premium +, B&O, sport diff, black Nappa, BBS CH, 255/40/18 Bridgestone RE960 AS
    Milltek resonated cat-back & DPs
    01.5 6MT ASP Stage 3 B5 S4 (4/01 to 9/09)
    Mar 23 2009
    2020 Porsche Spyder
    Quote Originally Posted by rktskicar View Post
    Bruce
    Ya kinda f$&ky isn't it. I'm sure there will be a mail out for this as running 41 on all four corners will cause premature wear especially to the center of the rear tires. Do I smell a US law suit?
    Sep 03 2009
    you would need a lot more than 41 to wear the centres off a 35 profile tire that is rated for 186mph. It has more to do with comfort/traction/noise/wear/mpg ratings for the car itself during the testing it undergos. I don't think the 50 max would even cause uneven wear. Any uneven wear I have seen in the last 20 years has been camber related.
    ask road and track what pressure they used, or car and driver, or edmunds. bet it was more than 41 on the track time section.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Oct 25 2009
    Overland Park, KS
    The law has changed so that on door jams in the future there will be only one psi listed, that being the 'full-load/high speed' #. Reason being is that having two numbers was deemed too difficult for some to understand, and there were cases of owners running the 'lower speed/partial load' psi during high speed conditions, (autobahn/interstate?), resulting in tyre failure. Hence only one number listed now.
    Bish
    Oct 25 2009
    Overland Park, KS
    Thanks for the info.
    Bish
    Mar 26 2010
    US
    Even lightly loaded the 41lbs on all four corners is probably fine.
    But yes, the real reason, to lower the pressure is comfort. The higher full load pressure would generate less heat
    on the highway and provide better gas mileage. It obviously handles fine with full load pressure.
    Oct 03 2009
    Montreal
    The numbers you quote are on my page 264, however..........they are for a 4 CYL 2.0T. My S4 will be a year old next week, they may not have had enough time to update the S4 booklet I got and copied straight from the A4 booklet. Can you confirm that the page you list references tire pressures for a V6 3.0T?
    Mar 20 2004
    Lawrenceville, NJ
    Does it really matter???? If you have the same size tires run those pressures. Do you really think theres that much of a weight difference between the A4 and S4 to all of a sudden be like HOLY SHIT WE GOTTA GET THESE PRESSURES CHANGED IN THE MANUAL QUICKLY OTHERWISE PEOPLE WILL HAVE NO IDEA WHAT TO SET THEIR PRESSURE TO?
    No, I dont think so. Im done with this stupidity. Put whatever pressure you want in your tires. Just please, nobody ask about this again. This is like "What kind of gas should I put in the car?".
    20 BMW R1250RS
    Oct 03 2009
    Montreal
    Did not mean to offend.
    The weight difference is about 500lbs, enough to make a difference in the handling characteristics of the vehicle.
    Mar 20 2004
    Lawrenceville, NJ
    Completely not true, where do you get these numbers from? Just took me 10 seconds to google "Audi A4 weight" and a billion sites came up. Two for instance: Motortrend has the weights as: A4 3626.6 S4 3714.8 and Edmunds has the weights as: A4 3626 S4 3847. Both are Quattro premium w/manual options. At the most theres a 221 weight difference divided by 4 thats 55.25 more over each tire(hypothetically for arguments sake). Still not enough to warrant a whole change in tire pressure concern.
    20 BMW R1250RS
    Veteran Member Three Rings K1speeder's Avatar
    Aug 29 2010
    San Francisco
    I run 40 in the back and 39 in the front on 19" wheels. It is the perfect balance. I have tried having them be the same, the front lower, and the back lower. This give me the most consistent acc., least amount of freeway noise, and is by far the most fun to drive!
    2017 Q5 3.0T P+, Brilliant Black
    Past: 2015 S3 P+ • 2010 S4 Prestige, Meteor Gray • 2009 Q5 P+, 3.2, NAV, Brilliant Black
    I have HEX-USB+CAN Vag-Com cable if a local member needs some mods
