I'd give JHM a call and see what kind of price forged rods and pistons would run you. They've built at least one motor so far, if not more, and based off their other parts the quality would be the best you could get.
The forged internals are going to be better suited to a nitrous/turbo build, but...
If you are staying N/A I would advise:
-Get stock compression pistons, 11.5;1
-Get the forged rods and pistons, crank is all ready forged
-While the motor is out have the heads ported (to get the heads off you need to remove the chains on the back of the motor). The exhaust side is rather restrictive from some accounts, a proper port job could yield gobs of power. Have the porter weld in the combustion chamber a bit for higher compression (12.5:1). Possibly get schrick cams, new valvetrain pieces (valves/springs), Ferrera makes some iirc.
-Get supporting N/A parts, JHM modded intake manifold, JHM Longtube Headers, 2.5" X-pipe catback, JHM LW crank pulley, JHM Stg4 clutch and LWFW, JHM SS and shifter linkage, Stern Motor Mounts
-Get maintence stuff; oil, diff fluid, gearbox fluid, new coilpacks, new sparkplugs, K&N air filter, serp belt/tensioner/idler. Definitely get new camshaft adjusters and new timing chains/tensioners
As far as bore/stroke I would leave it where it's at. The motor is already tight with 5.5mm cylinder walls and limited valve-piston clearance. An overbore and some sleeves could work, but no one has done either.
It'd be a ton of cash for a good bump in performance, but it may be a better option to build the motor and then get JHM's twin turbo setup once its available.
