Results 1 to 22 of 22
    Veteran Member Three Rings A4.Rob's Avatar
    Sep 02 2009
    Toronto, Ontario
    Economy mode stuck on.. (any air con guru's?)
    So like the title says the econ button on the climate control unit just stays on and I cant get it to go off no matter what, so I'm not getting the ice cold air like I'm used to. Anyone else had this problem?
    2003 Audi A4 1.8TQM
    Oct 22 2005
    Reppin the Mitten.
    Probably a leak in the ac system somewhere. I had that occur when my condenser died.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by A4.Rob View Post
    It can be a number of things. You really need to see if you have any underlying codes before you start messing with your AC without the proper tools. It could be a faulty high pressure switch, it could be extremely low on R134, it could be a clogged expansion valve, it could be a defective compressor. the ECON button is staying on to prevent the system from working until the defect is fixed.
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    May 21 2007
    Florida
    mine is stuck on also....but i know the radiator for the A/C (whats the proper name for this?) is leaking. found that out 2 nights ago.
    2018 Navarro Blue Q5
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    ^^ Condenser.
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    greg, i had this issue as well, it was a faulty o ring letting the r134 leak out, so i fixed that, recharged the refrigerant and bam, cold as shit on ice!!
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    May 21 2007
    Florida
    Quote Originally Posted by [email protected] View Post
    ^^ Condenser.
    thanks, was having a brain fart.
    Sep 02 2009
    Toronto, Ontario
    I posted about this last week and for the past week or so the AC works and then doesn't work.
    I will start up the car and am driving around, air is nice and cold and then eventually the econ mode goes on and stays on the rest of the drive. Sometimes I get in the car and econ mode is just stuck on right away and other times I will drive far distances and the air con works fine.
    Its possessed.
    2003 Audi A4 1.8TQM
    Aug 26 2005
    If the R134 charge pressure is to low, a pressure switch locks out the compressor, and the ECON mode is the only mode allowed. This is usually the result of a system leak.
    Established Member Two Rings Allhailpoptart's Avatar
    Mar 16 2010
    NH
    IIRC My A/C was acting crazy for a few weeks (ECON light was off and cold air, then light was on and no cold). When I finally pulled the codes with the vag-com I came up with:
    Address 08 ************************************************** ****-
    Controller: 8E0 820 043 L
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    29-00 - Short to Ground
    And now I'm in perma-ECON. I'm pretty sure it was signs of the sensor going bad. Just had the same issue with the coolant temp sensor, although it was more fun to watch the temp gauge dance than it was to not have a defroster...
    Actually, while we're on the subject I should fix that this weekend...anyone know if it is possible to replace the high pressure sensor without depressurizing the A/C system or will I need to get it into a shop to have it de-pressurized? I'd prefer to do this myself but there's no way I'm messing with that system before asking questions. My old GTi bit me in the ass when I was working on its A/C once...
    1995 URS6 Avant | 2.6L Eurospec Sport Stroker | EFR7163 @ 25psi | Tuned by EFI Express
    Active Member Two Rings Docta_Giacomo's Avatar
    Sep 26 2016
    2013 A5 2.0t Quattro
    MI
    ECON mode was stuck on for me last summer. Ended up being a faulty a/c pressure sensor (aka pressure safety switch). Swapped it out in 10 min, and problem solved. The sensor is located on the driver's side of the condenser.
    Sent from my SM-G920V using Audizine mobile app
    2003 A4 1.8t quattro 5M
    2013 A5 2.0t quattro 6M
    Past: 2005 Pontiac GTO 6.0L | 370 rwhp | MBM 6M | Pacesetter 1.75" LT Headers | Borla Catback Exhaust | K&N CAI | Baker Engineering Street Tune
    Apr 17 2016
    kc
    Necro bump time
    Jan 24 2010
    Paramus,NJ USA
    Sounds like you have high pressure switch that is leaking right through the connector.It can be easily change if you remove the driver side headlight.
    Ziddy Autowerks
    Apr 13 2017
    2003 A4 6MTQ 3.0, 2005 A4 FWD 1.8T
    Dallas, Tx
    Alternatively, check to make sure your rad and condenser fans are running correctly. If you don't cool your condenser, the pressure will rise until the compressor just won't run anymore and it will go into econ until you park and it cools off. Anyway, check that your fans are running first. With AC on LO while the car is running, it should force both the rad and condenser fans on. If its a faulty fan, or fan control module, then there are plenty of threads on that. I experienced the same thing early in the summer with my AC, and after I diagnosed the issue with the fans I replaced my fan control module, coolant sensor, and cooling fans, then no more AC issues.
    Senior Member Three Rings 03 silverbullet's Avatar
    Dec 05 2008
    1.8 Q 05 GSXR 03 CBR RR
    Follow up question about the Econ mode being stuck on.
    Does this also affect the heat from working on the driver side only ?
    I can set the driver side to 79 and the air is cold, defrost is cold and with it being winter i need the heat to work on both sides.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by 03 silverbullet View Post
    No, that is likely the temperature control motor that's bad. Prepare to be a contortionist to replace it if you DIY.
    Sent from my Pixel 2 XL
    Dec 05 2008
    so you dont think it could be the control module under the driver seat ?
    Jan 24 2010
    Paramus,NJ USA
    NO
    Ziddy Autowerks
    Dec 05 2008
    I scanned the HVAC none of the codes were AC sensor related, any other ideas why the ECON mode would stay on ?
    Saturday, 17 November 2018, 10:19:17.
    VCDS-Lite Version: Release 1.2
    Control Module Part Number: 8E0 820 043 L
    Component and/or Version: A4 Klimaautomat 1016
    Software Coding: 00000
    Work Shop Code: WSC 63351
    VCID: 2A2781ABC5E7
    7 Faults Found:
    00727 - Potentiometer in Positioning Motor for Defrost Flap (G135)
    30-10 - Open or Short to Plus - Intermittent
    01809 - Shareware Version. To Decode all DTCs
    41-00 - Please Register/Activate
    01274 - Shareware Version. To Decode all DTCs
    41-10 - Please Register/Activate - Intermittent
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    00735 - Shareware Version. To Decode all DTCs
    30-10 - Please Register/Activate - Intermittent
    00819 - Shareware Version. To Decode all DTCs
    07-10 - Please Register/Activate - Intermittent
    01312 - Powertrain Data Bus
    79-00 - Please Check Fault Codes
    Aug 12 2009
    Dirty Jerz
    You should look up the codes better I think. Your ECON problem is probably due to 00819.
    Jun 24 2020
    Indiana
    Would a bad 219 relay cause the Econ to stay on?
