Here's the scan:
Code:
******************************************************************************- Address 01: Engine Labels: None Part No SW: 8E0 UNI 518 BT HW: 8E0 909 018 A Component: 1.8L R4/415 G 0003 Coding: 0016751 Shop #: WSC 13873 410 452294 2 Faults Found: 18034 - Powertrain Data Bus: Missing Message from TCU P1626 - 004 - No Signal/Communication 18320 - Pressure Sensor for Brake Boost (G294): Short to Plus P1912 - 001 - Upper Limit Exceeded Readiness: 0110 1100 ******************************************************************************- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 A Component: ABS/ESP allrad 3429 Coding: 04275 Shop #: WSC 06435 2 Faults Found: 18055 - Check Coding of ECUs on Powertrain Data Bus P1647 - 35-00 - - 18034 - Powertrain Data Bus: Missing Message from TCU P1626 - 35-00 - - ******************************************************************************-
