Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Senior Member Two Rings mister 2's Avatar
    Dec 01 2005
    Audi 1.8Tsportpaket
    Montreal
    K&N vs OEM air filter
    Does K&N performance air filter make a big difference over oem filter on stock a4?
    THanks
    Vorsprung durch Technik
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    I doubt it, our intakes are perfect the way they are, as for the filter, think of it like this. Racing on the track, use a K&N, as a daily driver, use a stock filter. Our MAF's are sensative, stick to the stock filter. Just my 0.02, some where here there is better explanation of why, but that's the short version...
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    If your going to get any sort of a "high flow" filter get a dry one, the oil that K&N uses along with most other brands can damage or completely fry our MAFs. ITG makes one I believe
    2019 SQ5 Prestige
    Mar 27 2005
    The Cold North
    ITG, AFE & Pipercross all make dry filters that are just drop-ins. Skip the K&N for now.
    I am running the AFE one and it fits fine. Actually fits better than the K&N.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    We carry both...it's just up to you. The K&N doesn't make a huge difference, and I'm not a big fan of the oil it throws off:
    OEM: http://www.europaparts.com/air-filte...3843-mann.html
    K&N: http://www.europaparts.com/kn-perfor...r-33-2209.html
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    I have the itg filter and I love it. I replaced my brand new oem filter with the itg and noticed a tiny difference. not like the drastic difference as someone who never changed they're filter before and toss one in tho lol.
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Established Member Two Rings nightshutter's Avatar
    Nov 28 2009
    SLC Utah
    Been using an ITG for a while now....... no complaints
    2003 A4 3.0Q Dolphin Grey
    MODS: Blackout grille, Debadge, Black mirror caps, Joey Mod. UPCOMING MODS: rs4 rear sway, Paint Lowers, Blackout Window Trim, Blackout rims, intake, coilovers. I do cosmetic cause I have a 3.0
    Senior Member Three Rings DaSkorpion's Avatar
    Apr 11 2009
    o4 Audi B6 1.8TQM - o2 MB CLK 55 AMG - o8 Kawasaki Ninja ZX-10R
    CT/NY/NJ/PA
    Who is selling/where can I pick up the ITG filter and how much is it going for?
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Yup I ran K&N and now I'm back to OE paper filter. The K&N is a PITA and I just don't trust it at all. Stick with the paper or as suggested the others if you can find
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    AFE Dry Filter guy here. Have always used them w/out issue (and you get a tiny bit o pep + a little growl, which is a nice bonus).
    Used to get em from AMS in Carson, CA but they've since closed up shop. Bummer, they were good guys.
    AFE Pro Dry S
    30-10118
    ~$50
    http://wwww.afepower.com/
    http://www.purems.com/products/product.php/II=2794
    http://www.ecstuning.com/Audi-B6_A4-...enance/Engine/ -> listed at two different prices?? Clean it up ECS. ;-]
    Also and can be purchased from a number of other locations online, just search.
    ITG
    ~$65
    Can't seem to find the dry filter... just the oiled ones, maybe it's not being produced anymore?
    http://www.eurosportacc.com/itg_perf...ir_filters.htm
    http://itgfilters.net/main.sc
    http://www.awe-tuning.com/pages/audi/index.cfm
    Senior Member Three Rings tommy782's Avatar
    Aug 01 2008
    canada
    I buy last years a AEM dry flow and work perfectly. no need to oil it. wash the filter with soap and water. thats it.
    Senior Member Three Rings diplomat128's Avatar
    Sep 16 2009
    Montreal, QC
    I considered a K&N but I might as well just get the OEM one I guess. Does anyone know how much the OEM air filter costs at the dealership? As well as 1.8T spark plugs and the cabin filter... thanks :)
    vorsprung durch technik
    2004 Audi A4 1.8T USP quattro TIP
    OEM+
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Dont buy the plugs at the dealership cuz they're $20 each when you can get brk7eix for like $30 for all four. the cabin filter I bought the charcoal one 2 weeks ago for $35
    Veteran Member Three Rings Mani's Avatar
    Dec 21 2009
    2008 BMW 335i - Dinan Stage 3
    Irving, TX
    Put in AFE Pro Dry filter yesterday... good one IMO....
    Senior Member Three Rings 02rubya4's Avatar
    Nov 13 2009
    1998 Plymouth Neon (may that P.O.S. R.I.P)
    Putnam County, NY/ Prov. RI
    Quote Originally Posted by diplomat128 View Post
    22 and change from my stealership for the OEM air filter
    addition: you can find cheaper spark plugs online, i just got 4 BKR6EIX Iridium plugs for 25 bucks with free shipping on amazon they also had one for 3.50 a plug but they only had one
    Veteran Member Four Rings tchuck's Avatar
    Apr 11 2010
    '04 A4 1.8T Avant tip
    Portland, OR
    I've done quite a bit of research on this subject lately... K&N has a "no questions asked" policy about covering damages caused to MAF sensors due to their oil. To date, not a single instance has ever been proven. Not once, ever. They also performed a simulation on their flow bench in which they over oiled the filter by 30% and found that the air flow through a filter is simply not sufficient to pull oil from the element. It's something like 14mph for a big v8.
    Anyway, company propaganda aside... I personally use K&N filters in both my A4 (drop in) and my Infiniti FX35 (cone filter), clean and oil them regularly, and have never had a single issue. Not one, ever. I have used them on many other cars as well with the same results. I can't testify to any power increases as I've never done a dyno comparison but I can say that the filtration and build quality of K&N and Apexi filters is significantly superior to any OEM filter I've ever seen. Combine that with the fact that they are washable and I am a customer for life....or until a better filter comes along.
    Also, this is my first post so "Hi". I've been lurking here for a while now. Great site.
    EDIT: I forgot to mention that the price of the K&N is less than 2 OEM filters.
    Jul 16 2008
    Finland
    Here's one test where the K&N and Apexi make an appearance: Clicky Click!
    Dec 01 2007
    San Jose CA
    There are a number of VW/Audi owners who've had their MAFs destroyed by K&N oil that would likely dispute this claim by K&N's marketing dept. The MAFs in our car's are pretty sensitive... likely more so than the big V8. Obviously some of these instances have been user error, but not all of them.
    I've used both oiled and dry filters and while K&N does make a great product their drop in filters do not provide enough performance gains to offset the potential risk to the MAF.
    Also, welcome!
    Quote Originally Posted by tchuck View Post
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    been running my K&N filter for 3 years now without any issues. just don't soak it when you clean/re-oil it.
    a dry filter seems to be the best solution if you don't mind replacing them, but would go K&N again for my next car since it has done me well.
    Sep 12 2008
    South Central PA
    Quote Originally Posted by widgget View Post
    same thing here.
    BTW, i have a K&N panel filter for sale, really cheap. PM me if anyone is interested.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings Synthetik's Avatar
    Aug 26 2009
    03 A4 3.0L V6 04 YZF600R
    Colorado
    I didn't want to start a new thread for this, hopefully someone reads it...
    I placed an order with ECS over the weekend, and sure enough I saw this thread afterwards. I called, emailed, and called and didn't get a response until it was "too late" and it had shipped. Anyways, my drop-in k&n is on its way, anything I need to do before I install it to avoid the MAF issues? (i.e. try and remove some of the oil?)
    15% Tint | USP Front End | Graphite Stockers | "Custom" Grills | DICE Ipod | Hardwired Garmin | Alpine Amp w/ 12" Sub | NEXT PROJECT: RS4 Sway Bar
    The B6 A4 DIY Master List
    Dec 19 2007
    York, PA
    it comes pre-oiled from k&n...dont worry, its perfectly fine.
    Aug 26 2009
    Colorado
    Quote Originally Posted by n7plus1 View Post
    Yea I bought one for my Ranger back in the day. But cool, I just wasn't sure if I should try and "dry" some of it up with a paper towel or whatever.
    Jun 30 2009
    Washington DC
    If you stop by the vortex forums you will find numerous people who had problems with their MAF sensor because of over oiling or not letting it dry enough. This also includes me. So their test of an over oiled filter might have worked if they also let it dry for 2 days.
    I was doing my winter maintenance on my jetta and decided to follow the instructions on recharging my K&N filter. After about 4 hours of driving my CEL went on. A nice cleaning of my MAF sensor made me a believer that K&N will kill that very expensive MAF sensor.
    Veteran Member Four Rings Raiketsu's Avatar
    Jan 21 2010
    '10 Marin Bobcat Trail
    University of Georgia
    How often should the K&N filters been cleaned/oiled?
    Amulet Red 2003 Audi A4 1.8T
    Ecodes, Trunk Lip Spoiler, K&N Drop In Filter, LED Interior Lighting, DDM 55w 6000K Lows and H9 Retrofitted 2500K fogs, Depo LED Tails, painted brake calipers, and some VAG COM Mods
    Jun 30 2009
    Washington DC
    I did it every 10k miles or once a year since i drive mainly in cities and not dirt roads.
    Dec 19 2007
    York, PA
    yea, just check it every once in a while. common sense of how dirty it is should play a role here.
    Jan 06 2009
    I use the AFE dry filter on my A4 however I have used K&N filters on previous cars and never had an issue (maf and map sensor setups).
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Three Rings AudiAdi's Avatar
    Jul 06 2007
    2020 Toyota 4Runner TRD PRO || 2016 Honda Pilot Elite AWD
    Bellevue, WA
    Air filter's first and foremost job is to (obviously) filter the air coming into the engine. No aftermarket style filter (K&N, ITG, etc.) filters better than the OEM style filter. The (very) little performance gain on our car is not worth it IMO.
    Here's a good read http://www.bobistheoilguy.com/airfilter/airtest1.htm
    USP CLUB MEMBER #78
    2005 Audi A4 1.8T Quattro 6M K04 - GONE
    2010 Audi S4 S-Tronic ADS Lite
    Jun 30 2009
    Washington DC
    Quote Originally Posted by AudiAdi View Post
    That is what i thought also, if car companies can push that extra 2-5hp they would for marketing sake. If they found a better filter that would increase mpg they would use it and push the cost on to the consumers.
    Veteran Member Three Rings LB_NY_B8's Avatar
    Mar 31 2010
    2002 Honda CBR 600F4i, 2021 VW Atlas Crosssport, 2019 BMW 640i GT xDrive
    Long Beach, New York
    I dont buy into the oil ruining the MAF. I've had kn filters in jeep wranglers, bmw m5's, nissan sentra se-r, hyundai sante fe, ford edge, NO issues. I cant see it being an issue here. I'll just make sure I wipe off excess oil.
    Senior Member Two Rings Dirty(30)v's Avatar
    Nov 10 2009
    03 A4 3.0L
    North NJ
    x2
    Red ultra suede Trim
    clear corner/stealth bulb/ yellow fogs
    DONZ 19''/vmaxx coils/15mm spacer*/ rs4 swaybar/ custom intake
    votex rear*/ usp front*/ DTH side skirts/ trunk lip/ badgeless grill
    I have a bunch of stereo stuff for sale wanna get ride of it asap
    http://forums.vwvortex.com/showthrea...vd-cd-mp3cd%29
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    but why risk it for 2-5hp?
    Jun 01 2008
    Apopka, FL
    I'll never use any sort of high performance air filter again. They're fine for race cars where the engines get rebuilt every 10000 miles, but after 3 OCI's and 2 re-oilings with my K&N my silicon count quadrupled, which means that dirt was basically passing through the turbines of the turbos, past the piston seals.. ect. Slowly eating away any everything. There are a few people in here that work on big turbocharged diesel trucks that used K&N's and most will tell you the turbo turbines looked extremely dull after extended use. I use an OEM filter, and the K&N defentally gave a slight extra bit of responsiveness, but I wouldn't say it improved HP in anyway, just throttle response. Isn't it enough evidence that nearly all supercars still use plain old paper filter elements?
    Jun 05 2007
    Nashville, TN
    I just use stock; I've used K&N filters in previous cars and never noticed any real improvement, so it's not worth the risk to me.
    Mar 31 2010
    Tough call....
    Jun 30 2009
    Washington DC
    i dont understand how some people on these forums can BOLDLY say that K&N filters will not damage the MAF sensor. Many on this forum including I have had problems. A quick stroll to the vortex forum will also show that these filters do in fact throw off the MAF.
    the chances of this is not high but it does happen.
    Dec 21 2009
    Irving, TX
    I have been using AFE dry filter... I would recommend it to anyone... Do I see any HP improvement? - None...maybe it is too low for one to see it..
    Mar 31 2010
    Ok, I just got off the phone with a tech at K&N. YEA I KNOW he works for the company so he wouldn't put down his product, BUT, as tchuck stated, as well as the tech, there has been 0 instances in over 250 tests on maf's, that oil has EVER caused an MAF failure. He said if there is EVER any issue what so ever, please call and they will take care of it, but I shouldn't be worried. He told me that I was one of many calling about this concern.
    Believe what you want, but I'll take my chances with K&N.
    Mar 31 2010
    Biener Audi, the 2nd largest audi dealer in the U.S., just told me (a service tech) that he's has a few instances of people coming in for the MAF issue but never ended up being from filter.
