Results 1 to 8 of 8
    Oct 14 2009
    01 A4 Avant 1.8t Q 5sp, 90 toyota supra turbo, 94 civic hb gsr swap
    York PA
    Secondary Air Injection delete help!
    I have a 01 A4 1.8t FWD 5sp. I put a new motor in it that has an AEB head with out the secondary air port in the back of it. I was told you can use a resistor to keep the ECU from throwing the check engine light. Any one know anything about this, like what resistor and where to put it?
    Thanks Patrick
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    the resistor things never work. i tried a bunch of different combinations and none of them would get rid of the CEL for the SAI. Only think that worked was having my ECU flashed to pass all readiness codes. PM k0mpresd on here as he does a great job and is very cheap compared to other tuners wo provide the same service.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Three Rings DGAFxxx's Avatar
    Nov 27 2006
    Salt Lake Shitty, UT
    Quote Originally Posted by zrowcool View Post
    Yes that is correct, you have to get it written out of your ECU. I also had mine done by K0mpresd, mine works with no CEL after he fixed it.
    Hooray for boobies!
    Jun 30 2008
    Erie, Pennsylvania
    The ECU is actually just controlling a relay for the Secondary Air Pump. It has no way of knowing if the pump is there or not, and doesn't really care. It *may* throw an "open circuit" code if you unplug the relay, though. What it *does* care about is the effect of the pump. It has to pump enough fresh air into the exhaust to change the O2 sensor readings in the correct way. That is where the code comes from: "SAI incorrect flow". It is measuring the flow, not merely the electrical resistance or current flow through the air pump motor. That is why you can't simply fake it in any other way. You must have a working system, or code it out.
    Oct 14 2009
    York PA
    So can it be written out with a VagCom or do i need to get it flashed with new sotfware? Where does the resistor go In the n112 harness or at the pump wiring?
    Nov 27 2006
    You cant do it with vagcom, it has to be changed on the eeprom bin of the ecu. You have to have a cable that can dump the eeprom and write to it, then you have to change the appropriate value, and have a program such as winOLS which is quite spendy to verify your checksums.
    Hooray for boobies!
    Oct 14 2009
    York PA
    k0mpresd took care of my problem. he did a great job for a very fair price.
    Patrick
    Established Member Two Rings brockallentaylo's Avatar
    Apr 29 2010
    2007 530i sport, 2000 F350 CC
    Crescent, OK
    ^^^^ The man knows what he is talking about, get it recoded, deal with the light or put the pump back in.
    "Hey, what kind of party is this? There's no booze and only one hooker"
