Love the mod, but not the cost... Especially those wires, which Audi charges about $20 a piece. That is pretty rough considering that all we really need is the little connector that goes into the back of the fuse panel. So, it is time for the "cheap" way out... This modification to DavidB8's instructions leave you a little less than factory, but I think it is worthwhile.
First, you will no longer need or order:
1 - 1J0 919 321 - Electrical plug (for accessory outlet)
2 - 000 979 227 E- Wires for plug and fuse holder
1 - 000 979 230 E
Second, you will need some other non-Audi parts:
2 - 1/4" Female Crimp-On Quick Disconnects - Radio Shack 64-4039 (1 package @ $1.99)
1 - 1/4" Insulated Ring Connector - Radio Shack 64-3120 (1 package @ $1.99)
2 - 18" pieces of wire. I found myself an old PC power cord and cut that up.
1 - Tyco Electronics Timer Contact, Part Number 926965-1. This is the piece that the fuse will plug into. You can find the specs here:
http://www.tycoelectronics.com/catal...?RQPN=926965-1. I won't point out the fact that, if you ask nicely at that web site, you can get a few free samples...
Get extras so you can hard wire in your radar detector nicely too.
Time to make your wires
The ground wire will have a Crimp-On Disconnect at one end and the Ring Connector at the other. The hot wire will have a Crimp-On Disconnect at one end and the Timer Contact at the other. Make your wires (a nice pair of pliers helps here).
Connecting your wires
The Crimp-On wires go to the bottom of the Accessory Socket. There are three places they can connect to on the socket. The hot wire goes to the bronze connector in the middle. The ground wire goes to the only other bronze connector. The silver connector is left unused. The rest of the wiring should be done exactly as David says.
Hope this is useful to someone.
