Engine line is on, went to autozone to fine out the code and P0431 pops up. My audi has 85k on it. I have heard that this problem arises on 3.0 quattro.
Definition:
Catalyst efficiency low-bank 2.
Explanation:
The oxygen sensors monitor the Catalytic Converters ability to store oxygen.
Probable Cause:
1- Catalytic converter defective (failure possibly due to #2, 3, or 4)
2- Engine misfire or running condition
3- Large vacuum leak
4- Engine oil leakage into exhause-valve guide seals, piston rings.
That's what the code reader said. I have no idea of what the problem is. It is giving me many possibilities.
I have many friends that knows a lot about cars and one found out through using the Vag Com is that it seems as if one of the four O2 sensors is heating up slower than normal. This has no effect on the motor or how the car runs because it has 4 of them monitoring at all times. It does however cause the light to be lit.
I don't know what to believe. Taking it to an Audi dealership would be insane because of how expensive it will be just for a check up or diagnostic check. My audi has 85k on it. I have heard that this problem arises on 3.0 quattro.
Can anyone help me out??
Anyone ever have this code pop up? IF so what did you do???
