Results 1 to 7 of 7
    Senior Member Three Rings Vegas34's Avatar
    Mar 04 2008
    2001.5 Nogaro/Alcantara/6speed
    Vegas
    Anyone using the Ross Tech (vag com) software VCDS-Lite?
    I can't get it to install and their support sucks so far. I bought a $300 netbook just for this use, and made sure it didn't have Vista, thus it's OS is NT. My long term plan was taking it apart and using it as a carputer...
    Anyway, does anyone run this version of the VagCom software? I guess it's their newest/best version for using a 3rd party cable, sorry I will not spend $200 on a friggin' cable from them. Was hoping someone could walk me through the install...
    Rob B. - Kansas City, MO
    2001.5 Nogaro S4 | 6 speed | Alcantara | DD with no major mods
    2008 A4 2.0T | Wife's car
    Mar 04 2008
    Vegas
    Jesus, I meant Windows XP is my OS. Not NT, wow brain fart...
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    For genuine cable the support is awesome. Download old 409.1 version from torrents or somewhere else, it works good with an Ebay $20 cable
    Mar 23 2009
    Lansdale, PA, USA
    VCDS-Lite will work with any interface that works with the old VAG-COM 311 or 409. It should also work on any version of Windows from 95 though 7, including NT4. XP is a total no-brainer.
    However, it's up to your hardware vendor to provide you with whatever drivers and instructions are needed to get their hardware working.
    -Uwe-
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    who said vag-com* wouldnt work with vista/windows 7??
    op if you have the generic serial>usb>obd2 cable pm me. i can help with the software
    Mar 23 2009
    Lansdale, PA, USA
    VAG-COM will work under Vista and 7, but it's rather fidgety to make it work correctly and reliably on those versions of Windows.
    However, VCDS-Lite does absolutely everything which the old VAG-COM versions 311 and 409 did, and number of things better/faster.
    -Uwe-
    Mar 04 2008
    Vegas
    Ok, I have the driver working with VCCS Lite (newest software) and it recognized my car. Now it won't scan it...wtf? Also, do we search under A4B5 or A6C5 because B5S4 isn't there?
