Results 1 to 35 of 35
    Senior Member Two Rings Nostalgic's Avatar
    Sep 18 2006
    06 A4 2.0TQ S-Line
    Colorado
    Question Leaking Engine Mounts
    Hi all,
    I have an 06' A4 2.0T at the dealer shop. They tell me the engine mounts are leaking fluid and should be replaced. As result of the mounts, the engine sits a little lower. The parts alone are $400 plus (two mounts) and another $500 or so for labor. Do you guys think this repair is needed? If I drive around with leaking mounts, are there any long term consequences as a result of not having this issue corrected now?
    Thanks in advance for any help on this issue.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    not an expert here but it seems like something you might want to get done.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Established Member Two Rings remOOOO's Avatar
    Jul 10 2008
    A4/B7 Avant 2.0T Quattro
    Naples FL
    Yeah I'm no expert too but I think You should fix that. Engine might put extra weight on Your gear box and that can lead to big trouble.. but $500 for labor? maybe someone else can change them for You?
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    You can get away without replacing them for a little bit, but they need to be on your short list to get replaced. $500 labor is ridiculous, its an easy enough job to DIY (I did it on my B6 a few weeks ago). That price for parts is also really high...if you want a price on new OEM motor mounts, let me know.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    Not to scare you, but this is what I encountered when I took my engine mounts out. They were "leaking" and "squished" to say the least.
    The ones in comparison are OEM b5 RS4 engine mounts.
    Squished:
    Leaking:
    Reason I replaced them:
    Driver side, casing cracked not even sure how honestly.
    Pssenger side, This one broke when my snub mount bracket broke, the whole engine fell forward and guess it just ripped.
    I recommend looking on ECS for a set of B5 S4 mounts, much cheaper than $400 and much better "stiffer" ride. Im sure a local shop would be able to do the install for MUCH less than $500.
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Pretty common failure on the motor mounts. When you start modifying the motor with a chip, exhaust, intake, etc and you're putting out more power, you need stiffer mounts to put the power to the wheels, otherwise you'll just rip out your stock ones. Our Stern motor mounts are the way to go. Solid mounts so they don't leak. Plus we have the circuitry available to override those cars that have sensors on their mounts as well.
    Sep 18 2006
    06 A4 2.0TQ S-Line
    Colorado
    Thanks everyone for all the good information. I think I will look for a local indy shop to replace the mounts.
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    So once you start modifying a car, how prone are these to fail? Is there about an average mileage that these should be replaced?
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    I had mine replaced last month. It only leaked when I drove in sport mode and the torque just shifted the hell out of the engine. They were covered under CPO warranty but the cost was around $600. Parts were $200 each + labor. I'm at 50k miles.
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Oct 06 2008
    San Diego
    Is there a good DIY video to perform this job?
    Senior Member Two Rings krewbrew's Avatar
    Apr 26 2014
    2013 Touareg V6
    Westchester County NY
    They should be replaced to avoid stress on other componenfs. I installed 034 street density mounts a few months ago and am very happy with them. Did the snub mount at the same time. Parts were about $225. A 13mm GearWrench 9554 13mm Stubby Flex-Head Combination Ratcheting Wrench or something similar is highly recommended for the passenger side.
    Kevin
    2015 A7
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    I also have 034 street density mounts. Passenger side was a serious pain in the dick to install but well worth doing it myself. Only had $190 in the job.
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    Quote Originally Posted by audihere06 View Post
    So besides motor mounts, what is recommended to change out if you beat on your car? Serious question.
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Nov 11 2013
    Charlotte NC
    Quote Originally Posted by Denio24 View Post
    Really depends on what you have done to it and how you are beating on it. Personally I always start with tires suspension and brakes. Then did snub and later engine mounts and 034 catch can. Then when my balance shafts seized I added IE forged rods. May want to change out your dv to the piston style if getting tuned.
    Oct 24 2015
    Perth, WA
    Quote Originally Posted by Geoffafa View Post
    You think that is bad... i replaced mine two days ago - eek
    My respray thread
    Feb 24 2004
    Minneapolis
    Pass side was a pain on the B5 too. Did it on my dear departed 99.5 A4 for Saturday morning + about $170.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Nov 30 2015
    New York
    Huh. Interesting. I was having something fixed on my car and dealership also stated I have lose mounts. Not leaking nor broken. To fix would cost me $1200. What's the input on that peeps? No jolt or anything resembling engine mount nor transmission mount issues. My problem is that whenever they tell me I need something done, I end up needing it 6 months later so is it worth it or might as well get new ones?
    Active Member Two Rings Phaxmohdem's Avatar
    Nov 17 2015
    Kansas City, MO
    Quote Originally Posted by bfunk1414 View Post
    1200? I'll do it for 900 . But seriously, it is DIY able if you grab the right tools and have a good space to work. Save yourself about a grand.
    Daily Driver: 2008 A4 S-Line, FWD Multitronic, 110K mi -- Bone stock (Except for 034 Street Density motor mounts)
    Backup: Mountain bike
    Oct 24 2015
    Perth, WA
    Yeah it's not difficult even on the passenger side. A 13mm flex head ratchet ringy is all you need. I didn't even need to drop the sway bar.
    Nov 30 2015
    New York
    Quote Originally Posted by Okedokey View Post
    Dumb question, the mounts aren't active correct?
    Nov 30 2015
    New York
    Quote Originally Posted by Phaxmohdem View Post
    Definitely man. Got a few other parts to take care of first tho
    May 20 2014
    e92
    @geoffafa I know your post was long time ago, but if you are still on this thread or anyone who have tried.
    Are there any ill-effects of using B5 RS4 or B5 S4 mounts on B7 other than requiring resistors for the connectors? Planning on changing the mounts as soon as it gets a little warmer, but don't necessarily want to go 034 or OEM B7 (expensive for what they are). I read in some post that the height of the mounts are different for B5 S4 and B7 A4. Is it that big of a deal? I think I read even 034 mounts are taller than OEM.
    Senior Member Three Rings WewannaB7's Avatar
    Dec 07 2014
    07 Porsche Carrera S Cabriolet, 12 M-Benz ML350
    New Jersey
    Mine started leaking a few thousand miles after my APR tune coincidentally. I have 34k miles on the car now.
    08 2.0T Quattro SE, APR Stage 1 - 93 Oct
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    B7 A4's don't need resistors... all you will see is a soft code... if you scan with vag com. No christmas tree lights on the dash.
    Oct 24 2015
    Perth, WA
    Mine didn't even have the sensor.
    My respray thread
    Dec 14 2011
    Chagrin Falls, Ohio
    Automatics have an active mount on the driver's side. Changes an orifice to vary stiffness.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Silveravant View Post
    So that's that thing I unplug to get my oil filter off.
    Oct 24 2015
    Perth, WA
    Mine didn't.
    My respray thread
    Dec 14 2011
    Chagrin Falls, Ohio
    Mine didn't.
    Maybe different in Australia. Also driver's side is different with right hand drive. My active mount is on the left.
    Apr 24 2014
    CO
    both of my mounts had a connector, pax and driver side. I just clipped em and put in some cheap solid mounts.
    Dec 14 2011
    Chagrin Falls, Ohio
    I think there is a split in 2007 where they went from one active mount to two.
    Feb 07 2018
    St. Charles, MO, USA
    None of the photos in that link work any longer.. I'd like to take a look, but to see how to do so on my 2004 A8L D3. The left engine mount needs to be replaced.
    Thank you!
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by a_naudi_guy View Post
    Thank you!
    I can see them.
    1. Use Chrome
    2. Download the Photobucket Embedded Image Fix extension
    3. Thank Photobucket for the mess they left all over the internet by never, ever paying them a dime
    Mar 01 2016
    San Diego/CA
    034 street density
