Originally Posted by
Akabetterthanu
if your compressor didn’t grenade and send internals through the whole system. You should only need to vacuum system, change compressor and drier, and pressure valve. Keep the new drier sealed until you’re ready to install
Yeah that's what I'm doing now. Keeping everything sealed and watching the pressure. It was at 150 (didn't catch the units of measurement on the AC Pro reader) and had to make a call to my friend to vacuum out the system. Thankfully we got it down to 40 and it's been stable. He told me to not run the AC until I get the entire system replaced to avoid overcharging the entire system again.
Right now, if I try to turn on the AC, nada. I don't hear the compressor turning on at all. We tried filling it a little and see if the AC temp changes, nada. I don't even hear the compressor kicking on, even though it's been working great these past 4 years I've owned the car. Thankfully the lines never sweated or had condensation. Just the Schrader valve.
And speaking of which, does the AC system have a fuse or relay I can check? I want to make sure before I plop down $600, that I am indeed in need of a new compressor and dryer.
Sent from my Pixel 4 using Tapatalk
