Originally Posted by
Maxalama
Let's define 'hub centric'... To my understanding a hub centric spacer (with or without a lip) is the one whose diameter of the centre bore equals the diameter of the centre hub. The lip is used to center the wheel in case the spacer covers the entire center hub heigth. Am I correct ?
I can understand a spacer having a chamfer which should match the baveled inside center bore of the wheel, but I can not understand why a spacer should have a beveled center bore. Is there any reason ?
Yes, your understanding of "hub centric" is correct. The spacers with the chamfer leading down to the lips (typically only 8, 10 and maybe 12mm spacers have this) are made specifically for OEM wheels. My 5mm (no lip) spacers have a beveled center bore, but I'm not sure what purpose the bevel serves.
And yes, if you are running a spacer over 5mm thick, you should get the ones WITH a lip. If you are going to run OEM wheels get the kind with the beveled/ chamfered lip. If you are running aftermarket get the kind with a straight lip.
