    Veteran Member Three Rings pape's Avatar
    Nov 30 2008
    MIA
    18062 - Please check DTC Memory of Instrument Cluster ????
    Hi I have been loging my car for a week now and this code seems to always pop up again and again even when erased.
    P1654 - 004 - No Signal/Communication - Intermittent
    any one have any ideas??? the car does have a brake light out.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    i want to say i read a post like this somewhere and it ended up being a loose connection to the cluster. Old guy... input?
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Nov 30 2008
    MIA
    cluster still works 100% but it was on my check list.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I assume you are getting a "brake light out" warning in the cluster. the P1654 is simply telling you that you have a cluster warning, thus "Check DTC memory of instrument cluster". Fix your brake light and the P1654 should go away.
    Nov 30 2008
    MIA
    I had a feeling it was going to be somthing as simple as that.
    Thanks
