Results 1 to 40 of 57
    Senior Member Three Rings tsbpenguin's Avatar
    Mar 15 2008
    03 RS6 x2, 04 Allroad 6mt k04, 07 Tundra, 92 Legacy
    303 (CO)
    DIY: Fix/Prevent broken & leaking early style spider hose assembly.
    Hey everyone!
    So I decided to do this mod after I was working on my engine and cracked the boost hose of the spider hose assembly. I didn't realize it at the time, and couldn't find my boost leak for a week or two (after checking every charge tube, and finally buying a set of silicon hoses). When I pulled the assembly, the boost hose, and smallest hose were both cracked. That's why in the first picture (and the whole writeup) those two hoses are already done. I decided to do the other three hoses, and thus did the writeup for anyone else that wants to give it a go.
    Cost of Mod: Less than $25 @ Home Depot or Lowes
    Parts:
    - ~6 feet of rubber hose. (I used 1/2" hose from Lowes, good to 200psi. If I were to do it again I would get slightly larger because the fittings were a PITA to get in.)
    - Pack of 10 small hose clamps
    Tools:
    - Utility knife
    - Small flathead screwdriver
    - Flathead or socket for clamps
    - Hose cutter (optional. Can use utility knife)
    STEP 1:
    Ok so here's what your spider hose assembly should look like (again, ignore the 2 red hoses that are already on there as I had previously done this.)
    You want to do one hose at a time, so that you keep the correct orientation of all the hoses. Start by taking your utility knife and making a slit down the smooth portion at the end of the accordian style hose. It will take a couple passes to get deep enough to actually cut through the plastic. Make sure you're going from the end of the hose towards the middle of the hose. Repeat for the other end of the hose.
    STEP 2:
    Take a small screwdriver and insert the tip into the slit you just made with the utility knife. Get the flathead under the plastic until you feel the hose pop out of place. Pull the hose off the fitting. Repeat for the other end of the hose.
    STEP 3:
    You should have something that looks like this (two bare hose fittings).
    Now take the plastic accordian hose, and hold it up to your rubber hose. Use your hose cutter (or utility knife) to cut the rubber hose to approximately the same size as the stock one. You don't have to be perfect here since it's rubber hose and will flex easily. Cut slightly long to be on the safe side.
    STEP 4:
    Now comes the fun part. Work the rubber hose onto the fitting for each end. My hose was slightly small and required a tiny bit of stretching and a LOT of force. Now clamp each end down tightly with your clamps. Check to make sure the hose will not pull off.
    STEP 5:
    Repeat for all the other hoses.
    And VOILA, you're finished! Final product should look something like this:
    Hope this was helpful! Let me know if you have any questions, or want any more pictures.
    May 04 2004
    00 BB S4
    York, Pa
    For that much work, i'd rather do a catch man. But nice write up
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    when installing my F hose I heard a crack that came from that cheap plastic POS hose on my 2000. Im wondering if it actually penetrated the hose or if it was just the plastic flexing. I bought a new manifold and spider hose from the newer style but im debating whether to replace or leave it be to see if anything is actually wrong.
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    I'll be doing this soon. I already have a Home Depot special F-Hose.
    Mar 15 2008
    303 (CO)
    Quote Originally Posted by 98a4 View Post
    It's not that much work. It took me a total of like 15 minutes. Although my engine is not in the car...
    Veteran Member Four Rings Raacerx's Avatar
    Mar 22 2009
    ex B8.5 SQ5, ex 8V S3, ex 8P A3 VR6, ex B5 STK S4
    Norcal
    Quote Originally Posted by tsbpenguin View Post
    yeah doesnt seem like to much work to me, nice writeup.
    The Best Things in Life Are Free... Or Heavily Discounted!
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    FYI... there's no need to cut the stock plumbing to remove it from the distributor piece. Use a lighter or a torch and heat the junction (very lightly, maybe 10 seconds around the circumference from a good distance), and the joint will pull apart.
    B7 S4 Avant
    Senior Member Two Rings Nadrealista's Avatar
    Jan 09 2009
    2001.5 Audi S4
    Falls Church, VA
    I deleted my PCV and now I am venting out..no good reason for returning oil vapors into intake..they leave deposits, mess up timing and rob you of power!
    Jan 24 2006
    Ohio
    You mentioned the pressure rating for the rubber hose you used, but what is the temperature rating? I think temperature is of greater concern in this application, considering the system operates under vacuum.
    B7 S4 Avant
    Jan 24 2006
    Ohio
    Quote Originally Posted by Nadrealista View Post
    You've removed the vacuum source for the system, which means vapors will vent out only if the crankcase pressure is higher than atmosphere. This is why people install catch cans... you can retain the vacuum source without feeding the condensed vapor back into the turbos/combustion chamber.
    I'd put the valve back in, or install a catch can.
    B7 S4 Avant
    Mar 15 2008
    303 (CO)
    Quote Originally Posted by BlackS4TT(Josh) View Post
    Not like you need to save it, but either way will remove it just fine.
    I don't see the heat rating anywhere, but I've been running those other two for a couple thousand miles without a problem, so I have a feeling it's perfectly capable. You're right though, anyone who wants to do this now should probably get a high heat rated hose.
    Senior Member Three Rings Audiophyle's Avatar
    Jun 24 2009
    ABQ NM
    Autozone has various diameter bulk rolls of coolant line I am sure would work great, & isnt much more expensive.
    Senior Member Three Rings ram74's Avatar
    Oct 07 2006
    I did the same thing except I used heater hose from autozone
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Is that the Goodyear hose? Good stuff, I did my Catch can setup on my AAN with that hose.
    Nice writeup, props!
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    can anyone tell me where that long line in the 2nd picture goes? (red). by the F hose? thanx
    GIAC-X, STASIS TS,VAST,034 MS
    Senior Member Two Rings goingone's Avatar
    Jun 18 2007
    S4
    The Bay
    About to do this, just wanted to know what are the benefits of the OEM vs this method, if any????
    May 13 2009
    XXXX
    Quote Originally Posted by goingone View Post
    Benefits include ridding your car of that awful oem spider which features the structural integrity of a corn flake.
    Veteran Member Three Rings AWD87's Avatar
    Nov 23 2007
    01 S4
    Midwest
    Quote Originally Posted by GiacGRs4 View Post
    yes, the long piece connects to the F-hose
    Anyways, I appear to be having a huge boost leak somewhere in the spider hose area. And it's not a small leak either. All the pumped air is gone within a milisecond. I'm not exactly sure where the leak is coming from. It's hard to pin point. Air seems to be coming from the blue area I highlighted in the pic close to the center of the spider hose or somewhere closer to the hose that leads to the N75.
    Also, for those people that had to switch spider hoses, how exactly did you get all the clamps off of the F-hose and the long spider hose piece (area where the red arrow is in the pic)? It looks like a bitch to get them off, they're not angled correctly to loosen them. Does the intake manifold have to be lifted in order to swap the spider hose?
    Stage 18/6
    k04s, JHM FMIC, Tune, #60 injectors, 044 Bosch FP, 85mm maf, mbc, Vast stage 3 clutch, 710n's, 034 inlets, 034 tbb, ABD intake, H&R coilovers, 18" Falken Koblenz
    Sep 16 2005
    Asheville, NC
    You don't HAVE to lift the IM but it makes it much easier. As with every job on these cars, you have to choose between extra work or extreme patience.
    Edit: The leak could very well be coming from the center piece that connects all the hoses. The one on my car broke and I jimmied it back together for a short term fix. Also, if you're gonna make your own spider hose you can just delete the F-Hose.
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Veteran Member Three Rings ski&drive's Avatar
    Feb 22 2010
    00 S4
    Metrowest Boston
    I recently did this. I bought all the parts from mcmaster.com, cost was around 25 bucks shipped for some high temp high pressure hose and the factory style pinch clamps. If your gonna run a catch can it easy to modify your custom spider hose too.
    When he says the hose should be bigger then 1/2" he means it, if you run 1/2 hose that has no stretch to it you wont be able to get it on (like th mcmaster hose). i ended up running 3/4 or 7/8
    Mar 18 2010
    Ottawa
    Quote Originally Posted by ski&drive View Post
    Good olde McMaster Carr. Built a few manual boost controllers from their stuff. Good to hear they have high temp/pressure hose. will probably be using them again.
    Senior Member Two Rings Corrado's Avatar
    Apr 07 2010
    MidAtlantic
    I have a 2000, how hard is it to use the updated spider hose, or is it easier to stay with the early style hose assembly?
    Not sure if I want to tackle this or just pay or the updated piece. Also running a stock "F" hose so I want to either get a SAMCO style or brass F hose eventually.
    Sep 11 2007
    Tampa, FL
    updated hose goes with updated intake manifold.
    i replaced my hose with a used one from Shokan, a samco f-hose, brass fittings from hardware store. Works perfectly. My car has no leaks at all.
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Do you really need those plastic connectors on the ends or could you just clamp the hose to where it belongs
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    Maybe use some metal zip ties!
    - Sent from my iPhone via Tapatalk
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    This was one of the first mods I did. Super simple just takes time and patience! I would def recommend using the plastic connectors but if your missing a couple I don't see why you couldn't clamp the hose to the ports on the engine.
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Yeah I think I broke 2...
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    So instead of doing this you can run a catch-can? Anyone have a DIY or pictures on how they did it? Wouldn't mind being able to delete this thing.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    Quote Originally Posted by drkenan View Post
    ill be making my own spider hose this weekend and i would like to delete the f hose. how would i go about deleteing the f hose with my own spider hose?
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    Sep 22 2009
    Vermont
    i just capped off the piece that goes under the intake manifold..and just shot a hose straight from the intake mani to the check valves as opposed to having one end of the f house on either of these two. Not sure if thats a good idea of not but i saw it on another diy and i havent had a cel yet
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Broke the passenger side hose going to the valve cover on my 2.7T.
    Have engine out, prepping for RS6 turbos and want to get the system right:
    a) Can or no can? I assume with elevated boost, things can get messier as they already are. Any links to good can solutions for the 2.7T?
    b) replacing the corrugated with rubber is clear. But what about the snap on connectors? At least on my 2.8, those hardly 'snap' on anymore. And aren't there O rings in there (that either from age or frequent on/off are worn)? Hat to fix the hose, and still have a gaping leak on those connectors.
    c) where can complete hose and/or connectors and/or O rings be ordered from? I am a bit a fraid to leave the connectors off and just clamp onto the valve cover/block. How much is the going rate?
    d) Check valve: should that be replace (part number/source)? Or better (looks like cheap plastic), upgraded (source?)?
    By the way: I need to do the same thing on my 2.8 12valve. More or less the same situation, layout and fix?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings U2RedEye's Avatar
    Aug 20 2009
    B5 S4 Avant (Santorin Blue)
    LATE AS HELL POST from me....i ran into a cracked spider hose situation last year and used this thread to design my own for my car. used all the tips and advice...but i used thicker hoses and black hoses from Lowes. same outcome tho....so great DIY!
    Team A.C.E. NY ...Hobby? Lifestyle!!
    R.I.P. Sway
    ...STAGE 3+ in progress...
    ...More To Follow!...
    Aug 20 2009
    Quote Originally Posted by vtraudt View Post
    A) depends on who you ask...
    B) my connectors werent all jacked up, but i had a buddy of mine who modified some AN fittings to fit the vent on the valve covers and ran the stainless lines to his catch can
    C) for the OEM stuff?...JHM, i believe ECS and maybe even FCPGroton? i know the OEM or upgraded stuff runs a pretty penny though. (if thats what you were asking)
    D) i would have to look into that as i was able to reuse everything except the hoses themselves...but i believe Audi sells that stuff as one whole set with the hoses. i had to get a check valve for the brake booster/ master cylinder and it came as a set from the accordion hose to the booster/ master cyl. (2001.5 S4)
    hope most of ur questions were answered except for the pricing. a few ACE guys have done catch can mods of varying types and from various manufacturers.
    R.I.P. Sway
    Feb 20 2010
    Brighton, MI
    Thanks for the input. Next week, I will take a close look (both cars) and check how bad the connectors are.
    Still on the look out for someone with 'left over' connectors!
    Quote Originally Posted by U2RedEye View Post
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    do you recall ID/OD of the hose material you used?
    Probably best to take the cut up connector with me and go shopping.
    05 Golf TDI
    Aug 20 2009
    ^^^this^^^
    thats what i had to do. i really dont remember what the ID was, but there were one or two of those hoses that were a bit smaller than the rest.....so be sure u take a good look at your connectors.
    R.I.P. Sway
    May 16 2011
    Thread from the Dead lol. What did you use on the part that looks metal, 2ed picture red hose on the left at the end with the nipple. What is that?
    Aug 20 2009
    Quote Originally Posted by AWDLAUNCH View Post
    i definitely thought this thread was dead until today! btw, im not sure what connection that is, as i have a 2001.5...the hoses are just a tad bit different. hopefully the op is still watching his thread. if not, check in with me later and i'll do my best to get answers for you.
    R.I.P. Sway
    May 16 2011
    Its the hose that connects to the F-Hose.
    Established Member Two Rings mic_detonator's Avatar
    Nov 04 2013
    g2
    Why can't u vent to atmos? I have done this in every other non turbo car. Is there something different with turbo?
