Results 1 to 12 of 12
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    Any Experience with the Forge Hybrid diverter valve?
    like the title says. i got a great deal on one of these but it doesnt have settings for boost levels listed. it works by turnig the top a certain # of "clicks" to set boost levels/spring tension.
    just wondering if someone already has one, and how many clicks did it take to reach stock boost levels.
    ive yet to put a boost gauge in, just cant find a location i like.
    heres the instructions it came with:
    http://www.forgemotorsport.com/media/USASPLTR.pdf
    thanks for any help.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    i have one and some say about 12-18 clicks for stock. mines is on no clicks and i have no problems.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    i have a diffrent splitter so i can't comment on exactly how many clicks you should use on the forge but i can tell you that it's best to leave the location stock. longer hoses off the IC piping will cause a delay in releasing the pressure and in turn put more stress on the turbo. No reason to move it, set it and forget it.
    Jan 08 2010
    CT Shoreline
    thanks for the responses. ill wait around to see if i get anymore.
    youngturbo, you say you have it on no clicks? clock wise, or counter? are you stock?
    Dec 01 2007
    Orange County, NY 10918
    i have one too. its on 18 clicks for me. REVO stage 2.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Senior Member Two Rings B6 1.8T's Avatar
    Sep 03 2009
    B6 A4 1.8TQM *Goodwood Green*, and MKIV 24v GLI
    Sebago Lake, Maine
    You talkin 18 from all the way in or out?
    -Chandler
    USP front | Forge Splitter | CiM Boost Gauge ...and still slow.
    Jan 08 2010
    CT Shoreline
    bump for the last question. i borrowed a gauge from my mech, so ill have answers tonight. but anymore insight is good.
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    On about 14 clicks from outward on stock boost, no issues or fluttering in over 2 years, once in
    a while under hard driving during auto x I get what sounds like bov flutter on real fast on/off throttle in 2nd gear.
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Established Member Two Rings bmilleker's Avatar
    Aug 12 2008
    04 A4 1.8T USP, 99 MK3 GTI VR6
    Regina, Sk, CDN
    I just installed one last night. Took about 2 hours as I couldn't find anything to cut the one-time-use clamps. One those clips are off it takes about 10 minutes to put on. I have it on 15 clicks clockwise and im on stock boost. Planning to go stage 1 right away and will be adjusting it. I wasn't sure about the psshhh sound when ordering it, but the beauty is that you have the option with this dv.
    Also, build quality is unbelievable.
    Dec 01 2007
    Quote Originally Posted by B6 1.8T View Post
    what do you mean? theres like 8 'clicks' per full revolution of the nob. makin for 53 "clicks"
    edit from my post above. i'm on 24 clicks to go with the KO4 (20psi of boost)i had in car. (had it written on the box the DV came in) but still running that same amount with the Ko3.
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    I think it depends what your max PSI is. Just e-mail Forge and ask them. I know you said you don't have a boost gauge, so just search on the forum what whatever tune you have and find out what PSI you should be running at. If you are stock, a healthy system should max out at about 8-9 PSI. So just find out what PSI you are running and ask Forge. They will give you a direct answer.
    Jan 08 2010
    CT Shoreline
    i put it on 15 clicks clock wise and it feels fine. no luck on the boost gauge tonight, but i will call forge to get the correct # of clicks per psi. funny it doesnt come with that info. i realized when i took my old dv off that its not a stock one, but a pretty heavy, stout one. ill post up pics tomorrow to determine what it is. loving the woosh!
    as of right now im a heathy bone stock, with a true 3" test pipe back, thermal r&d race going on this weekend.
    thanks for all the posts.
    p.s. as this car is brand new to me, is there a way for me to tell if it has any work done to it as far as a chipped ecu program? it was well taken care of and day one audi serviced, so i doubt it, but who knows.
    thanks.
