Results 1 to 8 of 8
    Aug 09 2007
    Mount Airy, MD
    tire question, 245 40 19 too big?
    Like the title says, are 245 40 19's too big for 19x8.5 (et35) rims? I know it will be a bit beefier then typically run. and if it matters, these will end up on an avant. thanks guys
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Dec 07 2008
    Harrisburg, PA
    Yes, but what is the stock size that came on your car?
    Veteran Member Four Rings AWDTURBO's Avatar
    Oct 28 2008
    '14 Allroad
    Newark, NJ
    yuck!
    Please dont do anything more then a 35 sidewall on 19in wheels.
    245 will rub if your lowered on some wheels.
    '08 Brilliant Black B7 A4 w/ DTM Conversion Stage 2+ - Sold
    '14 Midnight Blue Allroad Premium Plus w/ Nav & LED Package - Sold
    '13 Ford F150 XLT - Current
    '14 Glacier White Q5 Premium Plus - Current
    '08 Ibis White B7 A4 Titanium Edition Stage 1 - Current
    -Steven
    Aug 09 2007
    Mount Airy, MD
    stock was 235/45-17. I've also got 5mm spacers if that will help... I live down a pretty crappy road, so i wouldnt mind the extra cushion... but not at the risk of rubbing. right now the cars on stock non sline suspension, but i have coils going on in a few weeks.
    - Will
    The Avants Timeline
    Dec 07 2008
    Harrisburg, PA
    This is why.
    Stock Tire - 235/45R17 >Search Tires Tire 1 - 245/40R19 >Search Tires
    Section Width: 9.25 in 235 mm
    Section Width: 9.64 in 245 mm
    Rim Diameter: 17 in 431.8 mm
    Rim Diameter: 19 in 482.6 mm
    Rim Width Range: 7.5 - 9 in
    Rim Width Range: 8 - 9.5 in
    Overall Diameter: 25.32 in 643.12 mm
    Overall Diameter: 26.71 in 678.43 mm
    Sidewall Height: 4.16 in 105.66 mm
    Sidewall Height: 3.85 in 97.79 mm
    Radius: 12.66 in 321.56 mm
    Radius: 13.35 in 339.09 mm
    Circumference: 79.54 in 2020.3 mm
    Circumference: 83.91 in 2131.3 mm
    Revs per Mile: 821.4
    Revs per Mile: 778.7
    Actual Speed: 60 mph 100 km/h
    Speedometer1: 56.8 mph 94.8 km/h
    Speedometer Difference: - Speedometer Difference: 5.483% too slow
    Diameter Difference: - Diameter Difference: 5.21%
    DUH! an Audi
    los angeles, CA
    i wouldnt run that setup, stick with 35.
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    FWIW, I rub very occasionally in the rear with 235/35-19 running 19x8.5 et35 on my Avant, so I don't see how you wouldn't rub all day long with 245/40-19s on the same spec wheels. Spacers would just make it worse. The rubbing is on the rear fender liner.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Aug 09 2007
    Mount Airy, MD
    good to know. thanks guys. 35's it is.
    - Will
    The Avants Timeline
