Originally Posted by
Riga89
Yes, it used to work. No, I didn't pull out the dead unit to check if the AM antenna is in place. How do I pull of the head unit to check for the AM antenna to make sure it's in place??
You need "radio keys" to pull the radio out. You can pick them up cheap on ebay or go to your local car audio installer and they may be nice enough to pull the radio for you...even if they aren't fixing your issue. You don't need the radio keys to put the radio back in, just to pull it out.
Once you get the radio out, just check that all the connections in the back are snug. Maybe try reseating them.
