Results 1 to 22 of 22
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Exclamation Misfire = Bad fuel injector? HELP!
    UPDATE IN POST #6
    So, I’ve been having misfire issues (not every time, but the colder the temp. the higher the chances of occurrence) under cold start up for the past 3-4 months. In rare occasions the CEL blinks. All the symptoms goes away after engine hes been running for more than 5 minutes.
    Last Friday, when I hit the gas (appx. 40% load) from a stop, my engine started shuttering and the CEL was blinking, I immediately let off the gas and coasted until the blinking stopped, at which point the CEL was solid. I scanned it with vag-com and found random misfire and cylinder 2 misfire. Thinking this is a coilpack issue, I took it to the dealership to have the perform the recall campaign. The dealer changed the coilpacks and send me on my way. I started getting the same issue but on a more consistent basis now. I took it back to the dealer today and they told me that it was due to my spark plugs, so I had them replaced. Tech takes it for a road test and comes back and says that the car is only misfiring on cylinder 2 and that they swapped coilpacks and plugs to be sure, so they are thinking it may be a clogged injector and want to perform an injector cleaning but they can't guarantee that it will fix the issue. I told them thanks for all your help but I will have to pass on the injector cleaning. The symptoms are encountered on both stock and APR 91 mode.
    Has anyone come across this kind of issue before? What are your thoughts/suggestions?
    If I do have to replace my injectors, would it be advantageous to upgrade to the S3 injectors vice OEM? I will upgrade my stock exhaust but not turbo in the near future?
    FYI
    2006 A4
    2.0T
    Quattro Tip
    K&N cone air filter
    Custom intake pipe
    APR 91, 93, 100
    88xxxKM/54xxxMi
    Thanks in advance
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    not sure how hard it is to remove our injectors.... But could you take the injector out of 2 and put it in a different cylinder and see if the mis-fires follow? That should pretty much rule out the injector if it doesn't.
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by Tusin View Post
    Swapping the injectors is a great idea, thanks. I hope someone chimes in with a DIY on how to remove the injectors.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Mar 16 2009
    Anchorage, AK
    When I get home I will look it up in ElsaWin for ya.
    May 20 2008
    2013 Passat TDI
    Sweet! Thanks.
    I searched and found this, but it's for the 1.8T http://www.a4mods.com/index.php?page...injectors.html
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    May 20 2008
    2013 Passat TDI
    I am updating this thread because, there has been a few threads WRT missfires.
    I ended up changing all 4 of my injectors with new ones, at in indy shop, the problem was fixed.
    After doing some hard reSEARCH, I ended up using the oem injectors instead of the S3 or RS4 ones. The S3/RS4 ones will make the engine run rich with out some serious custom ecu re-mapping and plus I'm only at APR Stage 1 with factory HPFP. If I was at Stage II+, I would seriously consider it.
    This may not be good news for some, but at least you know what to fix now.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Senior Member Two Rings rs6's Avatar
    Mar 23 2005
    2014 Cayenne S, 2013 F-150, 2006 A4, Focus Electric
    San Francisco
    Check your cam follower. I had the same problem, put in new injectors, fixed the problem and car ran OK.
    Still, I checked the cam follower and found it was totally shot, as was the HPFP and cam.
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    this issue sounds carbon related to me. Sounds like the valves are gunked pretty good. Run a can or 2 of sea foam through the an vacuum line on the intake mani. Also throw a can in the gas tank. This will run you no more than $30 and it requires maybe 15 minutes of your time.
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    I say throw in a can of fuel cleaner the next time you fill up, and once the engine is warmed up run the engine hard (get on the highway and do 70kmh if you can, throw it in sixth gear and floor it until you get to at or above highway speeds). I used to have a bit of stumbling at the mileage you're at but no CEL, and did this and it seemed to have helped. But the misfires came back 20,000k later and I ended up getting the intake valves cleaned out at 103,500km.
    Mike
    Jan 24 2007
    there is two possible change of car misfiring. lean misfire or rich misfire. Go for 20 mile drive and take the spark plugs out on cylinder 2 to see if you see any fuel residue on the cylinder if you don't it's not rich condition. The best thing to do is really remove and swap injectors around to see if misfire is move to different cylinder. I think all you have to do is remove the intake manifold and you should be able to have access to fuel injectors.
    Mar 23 2005
    San Francisco
    I thought my misfiring was carbon deposit related also. Had the intake deposits cleaned up, replaced the injectors, but it was really the cam follower in the end.
    Markham, ON
    Yeah, I'd check cam, plugs, injectors ... all the simple stuff before doing the intake cleanup.
    Mike
    May 20 2008
    2013 Passat TDI
    Mike, can you PM the price for the carbon cleaning? I assume you took it IT.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    May 20 2008
    2013 Passat TDI
    Quote Originally Posted by rs6 View Post
    I figured it was needless to mention. But, I did have the follower changed, when they were swapping the injectors. I also had the fuel filter changed before I ran into this issue.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Established Member Two Rings Swerve's Avatar
    Jul 13 2009
    Bay Area, California
    I had the same problem. I took my car to the dealer and they replaced the fuel injector on the missfiring cylinder. I still had a missfire. i asked about the cam follower, and the tech said that he checked that first and it looked fine. They tore apart the head, and took it to a machine shop. There was a significant amount of carbon buildup. They cleaned everything up and are putting the block back together. I should have an update on how everything goes by the end of the weekend.
    My extended warranty has a loophole that states anything that is caused by carbon buildup is not covered. So I found out just now that I get to pay for all this out of pocket. FML.
    Markham, ON
    Quote Originally Posted by Swerve View Post
    Audi CPO warranty?
    Mike
    Jan 04 2011
    East Haddam, CT
    I may be newer to this community but I do not understand how a follower could be the issue causing specific cylinder misfires. This would be highly improbable if not impossible. The follower is a wear part that protects the HPFP from directly contacting the cam lobe, its pretty much 100% or nothing. Theres no real gray period for make cylinder x misfire more than cylinder y, thats just completely makes no sense to me.
    plug or coil yes, gunked valves yes, injector maybe. follower in a state prior to failure completely no.
    plus op posted end result, injector failure all replaced.
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    May 20 2008
    2013 Passat TDI
    I agree with you, Kevin.
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Feb 17 2011
    Auckland
    my car was idling very roughly after i changed the stock injector to a 386 cc injectors, will this be caused by the ecu not adapting or injector defect even when it was new
    any thoughts guys?
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    Quote Originally Posted by 88mu88 View Post
    any thoughts guys?
    Did you replace it with a FSI injector or a standard injector??? I ask because the FSI injectors are not referred to as 386"cc" but OEM FSI, S3 or Rs4 injectors....
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Feb 17 2011
    Auckland
    Quote Originally Posted by viziers View Post
    vizi
    sorry to mention that my b7 had a 1.8t in it being a european version we get in new zealand, so i replaced it with a 386 cc.
    Jan 27 2007
    NC
    Ahhh , makes sense now...lol
    vizi
