So for the last 6 months or so I've been casually looking at fueling options on our cars. While a lot of people are opting for the larger 60lb injectors, it seems like a substantial amount still end up with the 42lb injectors. Having come from the mustang world before this, I knew that the 42lb green tops are a very popular upgrade for mustang guys. You figure that they're ~$50 a piece, so for 6 you'll end up spending over $300 on a set.
With my involvement in the mustang world before, I knew that the "budget" alternative to buying brand new bosch injectors, was getting a set of used stock Terminator (03/04 Cobra) 39lb injectors.
When you compare, you'll see that both injectors use the same clip. Also, although the cobra injectors are "39lb" that's actually 39lb @ 39psi fuel pressure. The 42lb injectors are 42lb @ 43.5psi fuel pressure. When you do the calculation for the 39lb @ 43.5psi, they're actually 41.2lb injectors. That would make them 47.9lb @ 4bar (58.8psi) fuel pressure (our stock fuel pressure), and they'd be 53.5lb with a 5bar (73.5psi) fuel pressure regulator.
PROS:
-You can pick up a low milage set for ~ $100-$150 (Click Here)
-You get 8 in a set rather than 6. That way even if 1-2 injectors is, or ever does go bad, you'll have spares.
-They have a good track record with reliabillity in older mustangs, v6 mustangs, focus, etc.
CONS:
-I've seen the flow pattern of 42lb bosch injectors, but can not find any pictures of the flow pattern of the 39lb cobra injectors, so I can't say which has a better flow pattern for our cars.
-As with buying any used parts, there's always a chance of getting your product in sub par condition.
This is in no way meant to be the end all injector solution, but it's just what I've found in my research. If any of my information is incorrect, please feel free to correct it. If anyone can chime in on the flow pattern of the 39lb injectors, that would also be helpful.
