Results 1 to 35 of 35
    Senior Member Three Rings Tarmac's Avatar
    Oct 10 2008
    b5 s4 nogaro
    Perth Western Australia
    B5 S4 Downpipe removal
    I was told by an Audi mechanic, "to remove the down-pipes on a b5 s4 6 speed manual you have to in part or in some degree move the engine forward". I've never heard of this & I don't think this guy is well informed. Has anyone ever encountered this exprinance with the removal of the b5 S4 DP's before?
    Jan 29 2007
    08 S4 00 S4
    MD
    08 S4- Stock SOLD
    Senior Member Two Rings Jman25's Avatar
    May 18 2009
    98 A4
    PDX
    yeah you can do it without moving anything other than the the heat shields. It is a pain in the ass big time and it will take a while to remove them but it can be done without moving the engine.
    Oct 10 2008
    b5 s4 nogaro
    cheers, thanks for that but I have seen this before
    Veteran Member Four Rings Mooseimage's Avatar
    Feb 15 2008
    2007 Audi A4, 2017 Audi SQ5
    Sacramento, CA
    Engine movement is not required. It's just a PITA to get to the nuts. Or sometimes they're just rusted/seized on there real good, like mine was.
    GCC Rule #22 Enforcer
    marty was here: id stay away from the womb that gave birth to fail
    2007 Audi A4 2.0T MT Avant: JHM Stage 3 goodness
    2017 Audi SQ5: Stock (for now)
    Jan 29 2007
    08 S4 00 S4
    MD
    I don't even think the manual makes mention of moving the engine for exhaust work. It's not that bad once you get the heat shields off. Plenty of room to work them off. You might have to drop the rear subframe bolts, but other than that, it's not a bad job..once you've done it..
    08 S4- Stock SOLD
    Established Member Two Rings rmv6's Avatar
    Aug 05 2009
    2001 Allroad
    Grand Rapids, MI
    i've done it twice now, first time i simply removed the cv covers and then jimmied the heat shields around. took me about 12 hrs to remove and install. second time we were pulled the tranny for other work. that made it very easy with no driveshafts or anything in the way and the heatshields came out of the bottom nicely. it really helps having another person to help with the top bolts on each of the downpipes (one person to hold the wrench/socket, and one person to wrench on it from the top...remove the coolant reservoir
    Oct 10 2008
    b5 s4 nogaro
    Quote Originally Posted by rmv6 View Post
    cheers guys thanks for that!
    I'm wondering, before I fit the DP's if I should first wait till I'm ready to fit a stage 3 clutch. Which will be in the near future, soon as I make my mind up what clutch to go with.
    (VAST, 034 Spec or South Bend). It's a hard one!!!
    So how much time u think will it take with the tranny out (for the first time). With the tranny out is it really hard getting to that last bolt from the top?
    Usually with the tranny IN dose the heat-shields come out from the top or bottom? (I'm guessing from the top)
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Quote Originally Posted by Jman25 View Post
    TRUTH!
    15+ hours for me.
    Be sure to have ALL the necessary tools too and extra neosporin ointments on standby; its murder on your hands.
    2015 B8 SQ5
    Click Here
    Past
    Dec 06 2007
    Calgary, AB, Canada
    If you drop the rear of the subframe, the DP removal and re-install is much easier.
    b5 s4 biturbo,
    You'd be much better off to do the DP's when you've already got the trans out of the car. I personally just pull the engine and trans together when I want to do a clutch job, and the dp's come out of the car at the same time, making it a cinch to replace them at that time.
    Oct 10 2008
    b5 s4 nogaro
    Quote Originally Posted by The_Jerbel View Post
    b5 s4 biturbo,
    Sorry I'm not a 100% on this subject, don't you have to remove the DP's first before you can remove the tranny?
    Dec 06 2007
    Calgary, AB, Canada
    Yeah, I just meant that you'd be better off to do them at the same time, since the dp's have to come off when you do your clutch job, anyways.
    Oct 10 2008
    b5 s4 nogaro
    That sounds like some really good advice, do it all at once and save on time.
    But, dose any one have a photo from the top view of the DP's with the heat shields off. I researched the threads but couldn't find any pics with the heat shields off. I want to see how much of a squeeze it is to get to that last bolt on the DP's from the top
    Oct 10 2008
    b5 s4 nogaro
    b5 s4 biturbo,
    Haha "pull the engine and trans together" that sounds great but I'm not as mechanically inclined as you maybe but hey,,, that would be nice. In Australia, it's really expensive to pay a mechanic to pull the engine and trans, around $3500
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by b5 s4 biturbo View Post
    It's tight, but definitely do-able once you've got the Y-pipe, MAF housing, etc. out of the way.
    Jan 29 2007
    08 S4 00 S4
    MD
    Loosen the heat shields ad push them back as far as they will go. I've never bothered with completely removing the shields until starting to work the down pipes off.
    08 S4- Stock SOLD
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by mholme View Post
    Agreed. There's no reason to remove them completely from the top.
    Jul 04 2007
    00 s4
    danbury
    use pb blaster and the adjustable open-ended wrenches. those made everything soo much easier. if you have questions about what wrenches you can pm me. i can do it in 7 hrs w/o a lift, on jack stands by myself. def a pita but dont mind it.
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    rachet flex head gear wrenches are your friend or you'll be nothing but swearing for some of those bolt angles
    i just did my downpipes myself and its not terribly hard.. follow the guide on AZ here and its very well written and truthful i found.. i didn't touch the subframe for removal at all.. and i did it all on jackstands.. reinstall is so much easier as you know the angles,etc
    have fun!
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Dec 06 2007
    Calgary, AB, Canada
    Yeah but you dropped the SF for the re-installation
    BTW, I've done dp swaps using standard open/box-ended wrenches, no gears, no flex heads. It IS possible (and not that difficult, at that), but it's easier if you have all the nifty wrenches.
    Jan 07 2006
    S3%2C%20Q8
    LOL ya jordan but in the end i don't think i needed too either way it does make it easier to drop the rear down at the end of the day ;)
    not a hard job IMO just time consuming nuts and bolts..
    www.eurodrivers.ca
    Oct 10 2008
    b5 s4 nogaro
    Quote Originally Posted by soccerplayer01 View Post
    This is really good, you guys are building up my confidence to do the DP removal myself. At first I was feeling uneasy to do the job but if most of what you guys are talking about is scraped knuckles, time & a steady persistence, why not give it a go. Lets face it, if I get someone else to do the job it's going to cost me a small fortune.
    I've got the jackstands but can you let me know exactly what tool I will need to remove the 02's & what wrenches & allen keys will I need?
    Veteran Member Four Rings fixn2xlr8's Avatar
    Apr 11 2005
    Winston-Salem NC
    Dont pay anyone. My first time it took me 7 hours to get em off, and the new ones back on.
    Oct 31 2005
    Ashburn
    TRUTH!
    15+ hours for me.
    That night was Epic john!!
    - Instagram: @Sinister_rs5-
    Active Member Two Rings BertaMade's Avatar
    Apr 10 2015
    2013 Ford F350
    Calgary, Alberta
    I dropped the sub frame to get to mine ... All in all took about 6 hours to do .
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by BertaMade View Post
    son...this thread is 5 years old.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Established Member Two Rings s4biturb0's Avatar
    Jun 05 2007
    Orlando, FL
    Quote Originally Posted by CELison View Post
    LMAO
    SOLD: 2001.5 Brilliant Black S4....Current Car :2014 BMW 435i
    Aug 06 2008
    Canadia
    if its tiptronic you need to remove rear transmission mounts and allow the engine/tran to tilt down a bit, may also have to loosen snub mount bracket too (its been awhile since i did piggies)
    other than that i just needed really long extensions, like 3-4'
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    Lmao at the people giving advice on a 5 year old thread. I think he probably figured it out by now.
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    But what if he didn't?!?!
    Maybe the dude has been fucking with the goddam heat shields for five years!!
    Dec 17 2014
    Chicago
    Quote Originally Posted by MacDaddy View Post
    I've been wanting to do this on my Tip car, and having problems finding any info on it. Thanks for the 'Tips'. Sorry to beat a dead horse (this old thread)
    Feb 27 2011
    Winnipeg
    I plan on attempting this in the future on my tip as well, so youre saying the side trans mounts that bolt to the subframe get removed? Did you remove the driveshaft?
    Aug 06 2008
    Canadia
    don't flame, i legit got a PM asking details on DP's on a tip, keep in mind i did this 6 years ago so i may forget a coupe things but this is the main of it....
    -get the car up as high as you safely can, you will need the clearance for the back half of the DP's
    -had to remove exhaust of course
    -removed O2 sensors (so you can get heat shields off)
    -removed heat shields, they were a real PITA, i may removed the bolts holding DP's onto the turbos to give me more fiddle room
    -heat shields will need some bending/convincing
    (side note, i did not re-install heat shields since i didn't have the immense heat of the pre-cats anymore, piggies)
    -i used a long 3/8" extension (i think the 36" one with a swivel impact socket on the end) and an 1/2" impact with adapter to get the 4 bolts holding the DP's to the turbos off, use some penetrating oil too, soak it overnight if possible this was actually one of the easier steps
    *fun part*
    -loosen off the trans mounts (bolts, nuts, whatever they are)
    -lift up trans
    -remove mounts
    -trans will now move down lower than its previous spot
    -I may have loosened off the two rear subframe bolts, cant quite remember, (removing all 4 bolts will throw out your cars front camber and will require a wheel alignment)
    with all that, i had just enough room to wiggle the stock downpipes out, but it was still a PITA.
    Aug 06 2008
    Canadia
    Quote Originally Posted by seanf86 View Post
    driveshaft stayed in
    Dec 17 2014
    Chicago
    Thank you for your insight! Your notes will come in handy when I go stage 2 in a month or two....
