Results 1 to 24 of 24
    Veteran Member Four Rings jayiszraw's Avatar
    Aug 03 2009
    swfl
    looking to buy an b5 s4 common problems?
    im looking to buy a b5 s4 i currently have a b6 a4 and it just doesnt cut it. im looking into buying a b5 s4 and wondering what are some common issues of these cars besides the k03 blowing and your average timing belt and water pump service (whats the interval?) any info is much appreciated. thanks -jay
    2.7 swap in progress
    Veteran Member Four Rings csre9's Avatar
    Feb 03 2008
    Stage 100 b5s4 hooked on meth, other money pits
    At work
    search search search
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    wooo in for the massacre!
    A few mods here and there
    Aug 03 2009
    swfl
    i tried but i get a whole bunsh of stuff pertaing to other models when i type in b5 s4 common problems
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    well the b5 s4 has all of those problems....and then some
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Three Rings Prospect25's Avatar
    Jan 09 2010
    LoHi, CO
    One of my friends is an Audi tech and i was between a B6 1.8T and a B5 S4. He said long run the S4 will be more problematic, more expensive, and less enjoyable because of the constant problems. Another problem besides blowing the turbos and expensive maintenance is the cam tensioner. I've heard about people going through them all the time. In my opinion, build your 1.8 up. It will be more reliable and more economical than a B5 S4
    Sep 16 2005
    Asheville, NC
    2000 S4 - SSP tuned Stage 3
    CrtchRktRcr: You could turn it into a unicorn with a gigantic pink dildo and i'd still love a b5s4.
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    if you have the money to buy a b5, why don't you put that money into upgrading your B6. nothing against the b5 but its double everything if not taken care of. Also double everything of your B6 when it comes to maintenance. although it can be a hit or miss when buying one just like it can be with the B6 or any car for that matter. Search is your best friend, and I dont mean just searching within Audizine. Do you homework read up on the vehicle as much as possible. Good Luck with what ever decission you make .
    Aug 03 2009
    swfl
    Quote Originally Posted by awdjunkies View Post
    the b6 just doesnt respond to mods the way other cars do. i come from the dsm world where about $1500 in mods gets me 350whp and the b6 i just too heavy for the 1.8t motor. maintenance isnt an issue for me because i am a big diy and i will be working for audi pretty soon.
    Jan 21 2010
    Virginia
    O2 censor
    was my first problem
    If you cant find something to live for, you better find something to die for.
    2pac
    Aug 03 2009
    swfl
    what is the timing belt service interval?
    Jan 21 2010
    Virginia
    70-90k? is what ive seen through my searching
    but if it hasnt been done yet you might want to do it asap
    2pac
    Aug 03 2009
    swfl
    i'd probably dp the following when i first buy the s4:
    timing belt and water pump, brakes, change all fluids, new sark plugs and coils, new air filter, new o2 sensor(s) anything else you guys would suggest?
    Veteran Member Two Rings
    Jan 19 2005
    Cranston, RI
    There are a lot of helpful resources on this site, such as a FAQ forum at the top and a Wiki link posted at the top of this forum. Here:( http://www.audizine.com/wiki/index.php?title=B5_S4 ) From there if you don't know any details on specifics, get to know the search function. This chassis is 10 years old, and just about every problem with them is known, and has been posted repeatedly. Plan on having extra cash saved for an emergency repair, every s4 needs it.
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Quote Originally Posted by jayiszraw View Post
    Yes.
    Aug 03 2009
    swfl
    Quote Originally Posted by orttauq View Post
    Yes.
    LOL!
    Aug 03 2009
    swfl
    Quote Originally Posted by TurboForTheWin View Post
    that is a perfect link if i could + rep you i would
    Veteran Member Three Rings DanS4's Avatar
    Oct 03 2008
    01.5 Audi S4, 00 golf Tdi
    Reading, PA
    oil leaks from everywhere. get a full service to replace shit that commonly fails, EGTs, 02s,seals,turbos .. should be good to go.
    SOLD Silver 01.5 S4 ; VAST tuned k04s, piggies, ASP exhaust, FMIC, Tracksports, DTS, ...
    http://www.socals4.com/
    Dec 18 2005
    nevada
    I totally understand where you are coming from and whole heartedly agree. Heck I've had my fair share of STi/evo/MKIV TT Supra so I know that the japanese vehicles are built for speed not comfort like the German vehicles are(Hence their weight). IF you are a DIYer then please proceed.
    PS: Nothing like the 4g63 huh
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    you should just buy a B5 S4 from someone that had a bunch of them, like me :)
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Aug 03 2009
    swfl
    Are the valve cover gasket prone to failure like the 1.8t
    Nov 27 2007
    2000 s4 black : 03 600rr Black
    NOVA, VA
    there goes your $1500... and no hp gain. This is a whole different type of ball game. Buy a stage 3 unless you are looking for a project or an excuse to take Excedrin.
    Stage 3 progress: here
    Picture Gallery: here
    You don't pay a ho to like you, You pay a ho to leave.
    Veteran Member Four Rings P0234's Avatar
    Jan 11 2010
    Need a B5 Avant!!!!
    NoVA
    If that has you worried, you have no idea of what you are in for. A good candidate for owning an S4 would have spend a few days of his life reading these forums and realize what he's up against. Executive summary, great second car, bad choice for a daily driver unless you have deep pockets for rentals and repairs.
    Mar 11 2007
    8V S3
    tri state
    Yep, just like the 1.8's and the 2.8's. Along with the cam tensioner seals that are underneath the valve covers. Nothing out of the ordinary for a VW/Audi product though.
