Results 1 to 14 of 14
    Dec 27 2009
    Atlanta, GA
    Run-Rite Fuel Cleaner?
    My dealer has a two-step fuel cleaner kit and I figured I should give it a shot. I'm skeptic that it will do not anything for the FSI but it was a good price.
    My question is that, how is it used. It comes with the fuel cleaner and fuel shot. The rep told me to use the fuel shot a tank and 1/2 after the fuel cleaner is used.
    Any one have any experience with this kit?
    T.I.A
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    I'm not sure about the two step, but with the Lubro Moly fuel injector cleaner we have (http://www.europaparts.com/lubro-mol...ve-300-ml.html), you're supposed to dump the can in right when you fill up.
    Dec 27 2009
    Atlanta, GA
    Thanks Matt, I love your support throughout the forum. That is why I am saving up to buy this from you: http://www.europaparts.com/koni-fsd-kit-2100-4002.html.
    I'm just curious about what to do with the Fuel Shot (2nd step). The rep kept repeating that I must use it after 1 and a half tank. I was to busy taking worry about my car. (Failed low pressure sensor, no pressure is cylinder 4!!!...)
    Veteran Member Four Rings Tusin's Avatar
    Mar 16 2009
    Anchorage, AK
    I will see if I can find the PN. But there is an OEM fuel injector cleaner made for the 2.0T.
    Veteran Member Four Rings apatchin's Avatar
    May 28 2008
    PDX/DEN
    ^ interested.
    Dec 27 2009
    Atlanta, GA
    I'm also interested. I didn't know that there was OEM injector cleaner.
    My dealership also acknowledge that was carbon build-up issue. I brought my car in for something unrelated and at the end the tech drove the car to "try" to remove carbon buildup. I'm starting to really notice that the dealerships are realising the problem or they could just use this opportunity to cash in by selling use cleaners that does not work.
    Dec 22 2009
    Piscataway, NJ
    Quote Originally Posted by weezy View Post
    Thanks, I appreciate the kind words!
    And if you guys find an OEM fuel injector cleaner for the 2.0T, please let me know.
    Mar 16 2009
    Anchorage, AK
    Sorry, I know the bottle is SOMEWHERE in my house. FYI it will do nothing for carbon build up (if that is what you are looking for).
    Dec 27 2009
    Atlanta, GA
    I've came to accept the fact there is nothing out there to clean carbon buildup in our FSI's.
    My MPG was considerably lower than usual so I figured I give a shot at cleaning the fuel injectors.
    Established Member Two Rings cjnesher's Avatar
    Oct 31 2008
    DG 05 A4 2.0T 07 Passat 2.0T
    Tampa, FL
    I had the dealer do something (need to look at receipt) about 6 months ago. Tons of black smoke for a few minutes then the car ran much better. I have an 05.5 so it must of had some serious build up.
    I think it was around $50.00.
    K/N Air Filter | Podi Boost Gauge | Cupra Lip | Rear Lip Spoiler | D Version Diverter | Blue DRL
    Dec 27 2009
    Atlanta, GA
    Quote Originally Posted by cjnesher View Post
    Was it sea-foam or BG44K? Also, why are Atlanta dealers so conservative. The service rep at Rick Case Audi does not recommend anything such as seafoam.
    Established Member Two Rings topshelf BiZ's Avatar
    Jul 14 2009
    im going to the dealership this weekend and will ask about a carbon buildup cleaner.
    2006 Audi A4 2.0T
    APR Stage I|TIP|Hawk HPS Pads|Power Slotted|Debadged|Front Plate Delete|20% Tint
    "Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Jeremy Clarkson
    Dec 22 2009
    Piscataway, NJ
    I wonder if regular sea-foam treatments would do anything for the carbon buildup issues.
    Jul 14 2009
    So barrier Audi in Bellevue has a fuel injector cleaner, it's 11 bucks and you put it in with a full tank, and then again in 2000 miles. PN G 001 700 03.
    Hope this helps
    2006 Audi A4 2.0T
    Jeremy Clarkson
