Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 280
  1. #121
    Established Member Two Rings alarum_78's Avatar
    Dec 10 2012
    2007 VW GTI, 2018 GOLF R, 2010 Audi S4
    Ontario
    Maybe we could start a sticky/poll for DSG issues? Its really hard to tell the percentage of failures and if some of us are losing sleep over nothing?
    2010 S4 Quartz Grey, Sport Diff, Nav, Magma Nappa, 19" Peelers, S-Tronic.
  2. #122
    Jan 14 2013
    Northwest Suburbs of Chicago
    hmm, hopefully that's a computer glitch and not a genuine transmission issue
  3. #123
    Feb 24 2013
    Queensland Australia
    Love the finish, handling and looks of my 2010 Audi B8 S4.
    However, it seems that the more you spend on a car the more time it spends on a tow truck.
    1. Water pump failed after only 12 months fixed under warranty.
    2. Thermostat failed exactly 12 months to the day after the water pump failure
    3. DSG Gearbox Malfunction requiring the mechatronics to be replaced only 3 months out of warranty and 70000 klms. $8000 repair bill with no sympathy from Audi.
    This will be the last Audi we ever buy. Can not recommend Audi for reliability.
  4. #124
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    Quote Originally Posted by Pedro1956 View Post
    Sorry to hear than man. That REALLY sucks.
  5. #125
    Established Member Two Rings 2010drive's Avatar
    Feb 17 2013
    Liberty Lake, WA
    That's why I will never own an expensive car out of warranty.
  6. #126
    Veteran Member Three Rings tins5's Avatar
    Sep 21 2011
    Delaware
    This is really getting me worried now. Will Audi ever do anything about your mechatronics if there are no alerts on the dash? I only have about 10k miles left on my warranty. Although i haven't gotten any alerts yet, i feel like i have experienced some symptoms that others are saying.
    The symptoms are:
    -Hard, jerky shifts when manually shifting 1 -->2 under 3k rpm
    -Occasional laggy 1-->2 shifts in S mode when flooring it.
    -Occasional revving (as if i'm in neutral) in manual mode when slowing down abruptly in 4th gear and then getting back on the accelerator again
    B8.5 S4 6MT
    Previous Rides: B8 S4 | B8 S5 | MK5 GTI
  7. #127
    Mar 08 2013
    Tampa
    Quote Originally Posted by tins5 View Post
    The symptoms are:
    Hmm...Similar worries here, different symptoms... . 2010 with 30K miles, CPO thankfully.
    Mine did the laggy jerky shifts in S mode that you describe, and seemed to "jump" and make a "clonk" noise when shifting from Park to Drive (and back to Park and S, to verify what the hell happened, yup still clonking). It did this when parked at my kid's school, then shifted harder than usual on my way home. I attributed it to me not being used to sports mode, but nope. Once home it clonked some more moving back to park. I almost booked a service appointment on the spot, but no warning lights, so..... Odd.. Restarting it 20m later, all was well, and has been ever since... ?!?!? That was a hot day and I had been playing with the paddles a little bit, but nothing crazy. Now I'm waiting for it to happen again or for the dash to light up so I can exercise that CPO warranty on -presumably- the mechatronics, but so far nothing...
    I'm almost disappointed I didn't get a code, ironically, I don't like occasional malfunctions - with my luck it'll finally die when the CPO expires...
    Kinda annoyed I could not find a local 6MT, but I hear those shift funny too (like a CDV issue). We shall see...
  8. #128
    Deactivated Four Rings Kay15's Avatar
    Jun 12 2009
    Audi A6
    Norway
    I have had my mechatronics unit replaced already I still get that revv'ing as if the car is in Neutral. I dont know what it is but I have had the Mechatronics unit replaced, the rear drive shafts replaced, I will see what happens. I have had the DSG re flashed a bunch of times to re learn what is going on. Nothing. Hoping a DSG tune can fix it slightly.
  9. #129
    Feb 25 2013
    MI
    Probably wayyy to early to ask this, but anyone with a 2013 having DSG issues? I do know that they changed some parameters on the shifting logic in the b8.5, and many users reported smoother shifting. But reading all this really makes me wish I went 6MT, guess I'll have to pony up for the extended warranty...not sure how this affects going with a Stasis stg 1 tune.
  10. #130
    Oct 18 2010
    1973 Austin Mini Cooper
    Elgin, IL
    Quote Originally Posted by Deschodt View Post
    I have had Similar issues in my 2010 S4. No warning lights. Hard thunk when slowing into first gear and hard clonk when shifting to park. It usually happened when stuck in stop and go traffic. Sounds like transmission overheating. Audi service yielded a reflash. It worked great until just recently when the problem reared its ugly head again although it was minor this time. I dont like this. I would rather have a hard failure and get it fixed. no CPO however my car history had the pump and thermostat recall so I should be covered under the extended 6 year 100k mile warranty.
    Quote Originally Posted by drob23 View Post
    If you jump back a page or 2, yes there have been a couple of 2013s that have had this issue.
  11. #131
    Oct 18 2010
    Elgin, IL
    after doing some research and thinking back on my own experiences, I believe that the OEM DSG cooling unit is the issue. The reflash is just a band-aid. Replacing the mechatronics unit is what results after multiple over heating sessions.
    It goes like this - Transmission overheats, Transmission computer starts messing up the shift algorithms. Eventually Transmission mis-shifts begin to damage mechatronics unit. It is a sound theory anyway.
  12. #132
    Jul 13 2012
    Omaha
    Does the TSB reflash help with the 1-2 shift issue where it holds the shift way too long and cuts power? If it doesn't fix that then it's not worth it for me to get my GIAC tune removed, go to the dealer for the TSB then have the tune flashed back in.
    2010 Ibis Prestige - Strat Intake, GIAC Stage 2 + DSG File, Alu-Kreuz, H&R OE Springs, Hankook Ventus V12's, Lamin-X Tinted Headlights, Taillights and Fog Lights, RS4 Grill, Blacked Out Rings, P3 Vent Gauge, Complete Interior/License Plate LED Kit, Tinted at 18%, Vinyl Wrapped Window Trim
    Next: Meth once we have a proven kit
  13. #133
    Oct 18 2010
    Elgin, IL
    It does. It only does this when run hot. however the problem returned after bumper to bumper traffic. It only happened once tho. after that it was fine.
  14. #134
    Jul 13 2012
    Omaha
    Quote Originally Posted by VMPhil View Post
    What do you consider hot? Operating temperature or flogging the car repeatedly? I never redline the car until it's reached 200F+ any how.
  15. #135
    Oct 18 2010
    Elgin, IL
    Quote Originally Posted by OmahaB8 View Post
    Operating temperature. During stop and go running around the neighborhood on a hot day (never going more than 30mph) was when the problem first appeared for me.
  16. #136
    Mar 26 2010
    US
    It seems to act more oddly, more often, in dynamic mode (ADS-light), than the Auto mode. In Auto (compared to Dynamic) it rarely sems to do anything funny.
    BMW M3 Competition X-drive
  17. #137
    Established Member Two Rings Drew855's Avatar
    Mar 02 2013
    Bergen County NJ
    I just got the malfunction notification after owning my car for 3 weeks and just over 1,000 miles...but I bought used. Car is a CPO 2011 S4 with 32,000 miles. Brought it into the dealer and they said they will call me tomorrow with a diagnoses. Sounds like it might be the mechatronics. Really won't be happy if my car has to stay in the dealer for weeks while they order parts.
  18. #138
    Established Member Two Rings FBO 335i's Avatar
    Nov 08 2012
    Quote Originally Posted by Drew855 View Post
    damn...after 3 weeks of ownership..that's horrible! good thing your car is cpo'ed. good luck and keep us posted on the issue.
  19. #139
    Established Member Two Rings Doc Brown's Avatar
    Apr 01 2012
    2017 Q7 3.0T, 2015 F-Type R
    Pittsburgh, PA
    Speaking (Writing) off the cuff, and not trying to blame the owners for the issue, stop and go traffic is very hard on a dual clutch transmission. Essentially, it is slipping the clutch near continuously to crawl along. Add 90 degree ambient temperature, hot exhaust from the car in front of you and the AC nice and cool and there is a lot of heat around the drivetrain.
    My prior M-DCT M3s had a "walking" option where a quick tap of the gas pedal would engage the clutch fully and walk the car at about 2.5 mph. Thereby not riding the clutch. It was a feature designed specifically to avoid this issue. I think this is further complicated in the Audi with the S-tronic as this transmission is calibrated to feel more like a conventional torque convertor auto. In most situations, one would be hard pressed to distinguish the S-tronic from Tiptronic driving around town. Okay, maybe on hills where it engages from a stop somewhat abruptly. The M-DCT made no attempt to be smooth like a conventional auto. There was no doubt in most any situations that this was a different kind of transmission.
    that said, Audi should have designed the transmission to tolerate normal driving conditions in the real world. Or added a "walking" mode, like BMW, to address just this issue.
    Whether or not it will make any difference in the long run, I think about the S-tronic when in traffic. If at a light, I will pop it in neutral to take the load off the throw-out bearing. I don't creep along in bumper to bumper. I move in increments - much as I would in a traditional manual. Maybe pissing off those around me as I am not continuously up the ass of the guy in front of me, but less pissed off than they would be if my car shit the bed right there in front of them in traffic and blocked a travel lane.
    Only at 7500 miles on my 2013 S4, living in metro PGH, occasionally commuting downtown, and so far no issues.
    Current - 2015 Jag F-Type R, Triple Black. "it's an x-rated, hardcore monster, for the terminally unhinged..."
    Recent past - 2013 S4 Prestige. Phantom. Black/Magma and Carbon. It did everything but touch my soul.
    Past
    E90 M3 - I still hear the distant howl of the V8......; B7 RS4 - I hardly knew you; B7 S4 Avant - Uber Wagen; Z4 - driving it was the most fun I had in a car (at least until then) with my pants on.
  20. #140
    May 27 2010
    2010 Touareg, 2007 Jetta GLI
    Vancouver, Canada
    parts are typically 10 days out as they have to come from germany. They are vin specific.
    Even after my second replacement the car is acting kind of wonky. Really just counting down the days until this thing is gone at this point.
    2007 VW GLI - AWD Conversion, a diet and 600+HP coming soon - Racing @ 2014 Pikes Peak Hill-Climb
    2011 Audi S4
  21. #141
    Feb 25 2013
    MI
    Quote Originally Posted by Doc Brown View Post
    Interesting theories, I have also been surprised how well the s-tronic feels while creeping. Do you think this causes additional wear on the clutch packs or stress on the mechatronic unit? I would imagine impulsive forces during hard driving would be worse for wear and tear but that's a total guess. My understanding is the Getrag M-DCT is dry vs the wet DCT's of the VW AG family (PDK, Stronic, golf DCT), so maybe that changes how clutch play works at low speed? I know Ford has had a lot of problems with their powershift Getrag 6-DCT with dry clutch's, which presumably uses lesser quality light weight components.
  22. #142
    Mar 02 2013
    Bergen County NJ
    I just got a call back from the dealer saying it was the transmissions control module. They said it is apparently a known issue. I asked there was anything mentioned about the mechatronics and he said no. He even went to talk to the tech while I was on the phone who said the mechatronics was fine. Does this sound legit? I don't think I read anything about transmission control modules in this thread.
  23. #143
    May 27 2010
    Vancouver, Canada
    I thought the TCU is the Mechatronics unit??!!
    2011 Audi S4
  24. #144
    Mar 02 2013
    Bergen County NJ
    I was under the same assumption...I am going back to the dealer tomorrow to trade my loaner for a different one and will discuss with the technician. They said the part should arrive tuesday of next week and the car should be ready thursday. We will see about that.
  25. #145
    Feb 25 2013
    MI
    Quote Originally Posted by theKB View Post
    I'd guess the TCU is just an electronics unit while the mechatronic unit comprises the hydraulic actuators that engage/disengage the clutchpacks and mechanically select the gears (what you do with the shifter).
  26. #146
    May 27 2010
    Vancouver, Canada
    that again doesn't make sense. If you were to get a bench flash TCU upgrade you physically take out the mechatronics and send it to whoever is flashing the software because those actuators are together with the circuit board etc. The Mechatronics is the brain of the transmission.
    2011 Audi S4
  27. #147
    Veteran Member Four Rings riegeraudi's Avatar
    Apr 16 2009
    While the first two was obviously due to some production problems the last one being DSG really is unacceptable. The DSG transmission being a major component should not fail so early in a cars life especially at that cost. I definitely won't be going with any cars with DSG on my next purchase as it looks like Audi can't make it reliable in the long term and are not backing the product. I know when BMW had the HPFP problems they gave the owners a 10year warranty. This is what Audi should do with the DSG with all the failures. This is definitely one area where Audi needs to step up to the plate and back the cars since obviously some of the parts are not well designed.
  28. #148
    Apr 16 2009
    I was stuck in a traffic jam for about 1.5hours and the DSG transmission was definitely not happy. It started to get loud. Once I put it into neutral it quiet down.
  29. #149
    Mar 02 2013
    Bergen County NJ
    I spoke to the dealer today and they told me the "transmission control unit" is in fact the mechatronics. They said it should arrive by next week, but based on some responses in this thread I doubt that to be true. Pretty annoying since I have only had my car a week. Oh well, on the bright side, I'll be racking up miles on their car and not mine.
  30. #150
    Feb 25 2013
    MI
    When I think of the word "mechatronics" I think of robotic's inspired composition of electronic control units with actuators of whatever sort. I presume the actuators in the DCT would be big and buried within the transmission housing. If you are going to bench flash the TCU, I don't understand why you would take out hydraulic actuators. Check out details of the M-DCT by Getrag here (page 30).
    But it seems like we are just debating semantics.
  31. #151
    Mar 26 2010
    US
    I think the DSG controller is near the sensors & actuators. http://www.audizine.com/forum/showth...ic-%28DL501%29
    "The mechatronic system acts as the central gearbox control unit. It combines the electro-hydraulic control unit (actuators), the electronic control unit and some of the sensors into a single unit. On account of the longitudinal configuration, the rpm sensors of both gearbox input shafts and the gear sensor are located on a separate mounting bracket.
    The mechatronic system controls, regulates and performs the following functions:
    – Adaptation of oil pressure in the hydraulic system to requirements
    – Dual clutch regulation
    – Clutch cooling regulation
    – Shift point selection
    – Gearbox control and regulation
    – Communication with other control units
    – Limp-home programs
    – Self-diagnostics"
  32. #152
    Feb 25 2013
    MI
    Cool, thanks for the link. Whenever I think I have any specific knowledge of the DSG (or any subsystem for that matter) I'll remember to look at this and remind myself that I have no f*cking clue how complex this is .
  33. #153
    May 27 2010
    Vancouver, Canada
    tuned/stock and what year? (and if tuned what software)
    2011 Audi S4
  34. #154
    Mar 02 2013
    Bergen County NJ
    2011...bone stock
  35. #155
    Mar 02 2013
    Bergen County NJ
    Just got a call from the dealer saying my car won't be ready until next week now. They said it is more work than they thought and that they have to pull the entire transmission to replace the mechatronics. Is this true?
  36. #156
    May 27 2010
    Vancouver, Canada
    yeah it's a big job to replace the mechatronics unit on these cars although it surprises me that the dealership didn't realize the scope of this job. I think it also takes a while to reflash the car etc as well plus re-adaptation etc.
    2011 Audi S4
  37. #157
    Dec 02 2011
    Baltimore, MD
    Mine took a couple weeks to replace when my mechatronics failed @15K miles.
    2012 S4 - Monsoon Gray Ti S-tronic - AWE Exhaust, resonated
  38. #158
    Junior Member Two Rings
    Mar 31 2011
    denver
    looks like I got hit by this too with 2010 S4 @52k miles and APR tune.
    My SA said Audi will not cover it because Audi home office claims its "had an ECU flash" based on the VIN.
    Its going to be an out-of-warranty replacement of the transmission gearbox and $11,000. Hoping to knock some of this off with the dealer.
  39. #159
    May 27 2010
    Vancouver, Canada
    Quote Originally Posted by soundsubs View Post
    Isn't that lovely that your transmission bites the dust 2k miles out of warranty and again hiding behind the tune is simply insane but that's Audi. I am not so sure about it needing a full transmission replacement, and may just be a mechatronics but geez, I would have a hard time stomaching 11 grand because of poor design on audi's/VAG/zF's behalf.
    Keep us up to date on this.
    Also would love to see a poll posted up with potentially a breakdown by model year and which tuner if not stock.
    2011 Audi S4
  40. #160
    Sep 21 2011
    Delaware
    What were the symptoms of it failing? If they were documented with the dealer prior to it going, maybe they'll help you out. Who knows.
    B8.5 S4 6MT
