Results 1 to 40 of 41
    Jan 20 2010
    Texas
    Yet another iPhone Dock
    I got tired of having to access the glove box every time I wanted to plug my iPhone into the AMI (2010 A4). So, I decided to re-route the wire to a more useful place. In the process I gave up the coin-holder, but it was worth it. The best part of this was that I can always return to “stock” with the purchase of a new $10 coin holder. Here is my DIY for the new phone dock.
    Sorry in advance for the long post.
    Parts:
    • One of those $3.23 generic iPhone cradles from china that are sold on eBay. The kind that look like they are sturdy metal but are in actuality all bunch of plastic.
    • 5 feet of 16-connector Ribbon Cable (Altex.com: RC16). You really only need 4 feet, but I found the extra foot to be helpful when running the wire. In the end, I cut it down to 4 feet.
    • 4 16-pin connectors that look like the kind on an old hard-drive cable. You really only need 2, but I got a couple extra to help with the soldering process and they were pretty cheap). Altex.com IDS16 OR FCI Part# 71600-616LF. If you are clever and know how to google, you can order yourself a few samples of these.
    • 2 16-pin matching shrouds for the connectors. FCI Part # 75869-103LF. As above, if you are clever and know how to google, you can order yourself a few samples of these.
    • An Audi AMI-to-iPod cable you are willing to cut. I have seen these for sale on eBay for about $20. Make sure you get the same part number as the one you currently have.
    • Screws and Nuts. These are going to go through the coin-slot, so they need to be long and thin. I used #4-40 x ¾” (its in a green bag with UPC 3069927461) machine screws found at my local Home Depot.
    • Washers. These will be hidden when done, but will help keep the screws in place. I found some Sealing Washers #8 from Home Depot (in a white bag from a pull-out drawer with UPC 30599??228).
    • 1 zip-tie strip (can be very small).
    Tools:
    • Soldering Iron and Solder
    • Electrical Tape
    • Pliers
    • Scissors
    • Hobby Knife (or similar)
    • Screwdriver
    • Black Permanent Marker (if you want)
    • Drill with 3/32 and 11/64 sized bits.
    • Radio removal Keys (or just pull into your local dealer and ask for a quick hand)
    Instructions:
    The following instructions worked for a 2010 A4 P-. If that’s not you, you may have some more work on your hands.
    If you do not have radio keys, you will need to go to the dealer (I went to the nearest VW dealer) and ask them to quickly pop free the AMI box inside the glove box. Do not take it completely out, just have them pull it out about 1 inch or so. The glove box will still close and everything will work fine, but you need to be able to get back behind the unit.
    Take the long ribbon cable and snap on one of the connectors. Just to be sure, make sure you line up the little molded triangle on the connector with the red wire in the ribbon. Squeeze it together tightly with the pliers. With only one connector attached, bring that into the car with you, along with the other connector and the pliers. Put this aside for a moment while you remove the coin holder.
    Next, we need to get that coin holder out. Pop-out the rubber boot holding the shifter and then pop-out the whole center console piece surrounding the shifter. You will see that the coin holder is held in place with a couple stiff plastic tabs-one in the front, one in the back. Try not to break a finger and pop it out. Once it is popped out, you can reassemble the console without the coin holder. Put the coin holder aside for now.
    With the coin holder out and the console re-assembled, take the ribbon cable and slide the unconnected end into the coin holder, down along the passenger side. It should appear under the trim along the passenger leg area. Do not pull to far, leave about 4 inches or cable inside the coin-holder area.
    Now we need to get the other half into the glove box. Fortunately, we do not have to take the whole glove box out, we just need some patience. Go back into the glove box and gently pull out the AMI box that the dealer freed. Disconnect the wire in the back and put the box to the side. If you now look in the back-upper-left corner of the glove box you will see our target. We need to take the ribbon cable and pull it stiff, and slide it up there from the bottom of the dash, again by the passenger’s legs. It took me about 4 tries to get it up there to be able to grab it from within the glove box.
    Make sure the wire comes through the shelf area where the AMI box sits. Now, go back to the AMI box, and look for a 1” wide rectangle that pretty much sits above the little tray. We are going to run the ribbon cable through that. Pull the tray out, slide the cable in, pulling all the slack. When I did this, I found it easier to just remove the tray from the unit, but you shouldn’t have to. It is now time, to put it all back together. First, hide the ribbon cable that is by the passenger legs underneath the interior trim. Feel free to fold the cable as you push it up under the trim. Second, reconnect the AMI cable that was previously attached inside the glove box. Finally, pull the tray open on the AMI box and slide it back into place. Make sure you slowly pull the ribbon cable forward as you do this. Once the AMI box snaps in place, close the little tray. Now, pull the ribbon cable and clip off any extra that goes past the end of the tray. Connect the other 16-pin connector to the ribbon cable. If you followed the suggestion above about the little triangle and the red-wire, do the exact same here. Squeeze it tight with the pliers. You are done with the glove box.
    The coin holder part is not difficult at all, but just a bit of work. I can show you pictures of what I did, but a lot of this you will have to figure out as you go...
    Pick up the coin holder (“CH”) and the cradle base (“CB”). You now need to decide how you want to mount the base of the CB to the CH. I chose to center it with the CB lines going forward-to-back. I then drilled small 3/32” holes for the screws to go through in the bottom of the CB. I put the screws in the base and then pressed it together with the coin holder as a temporary validation. I did NOT remove the sticky tape on the bottom of the CB. Once you start to put it together, you will see that there are some places under the CH that has to be cut. The CH has a bunch of little plastic strips on the underneath to keep coins from falling through. Those need to be cut to let the screws go through. Cut them. Once they are cut, you can make sure it will all hold nicely. At this point, I also decided to push the CB “back” as far as possible on the CH to make room for the wire. I then drilled a 11/64” hole in the middle of the CH for the wire to fit snugly. After the hole was drilled, I took it all apart, uncovered the sticky-tape and put it all back together, including using the washers underneath. I used a scissors to rough-cut off the overhang of the CB and then used a hobby-knife to clean it up. Now it was time for the wire-work.
    First, cut the AMI-iPhone cable in half. Strip away about one inch on each side and then about 1/8” from each wire end. I also took some pliers and a wire cutter and removed the little squeeze-lock-hooks on the iPhone plug. I wanted the phone to be able to slide on and off without having to squeeze the sides.
    Next, slide the iPhone plug through the top of the CB/CH.
    I also took a black marker and colored the top of the screws. If I had black nail polish, I could have likely used that too.
    I placed a zip-tie around the bottom of the wire, so that a strong pull (after it was complete) would not tear apart the internal wires. Cut off the end of the zip tie. Finally, I soldered.
    You will be soldering the 16-pin headers to each of these. The exact placement of each color does not matter, as long as it is identical for each header. That is important, so let me repeat that... It does not matter whether the blue wire is next to the green wire once soldered as long as both headers are soldered the exact same way. I chose to put the 8 “data” wires on one side, the 4 “power” wires on the other side, and the huge ground wire in between. I will not explain how to solder, especially since I probably did a horrible job. I would recommend that you “tip” the wires and header with some solder before you start. You do not need much solder and this is a quick way to avoid needing three hands to solder. Another hint... take two of the extra connectors and put them into the headers while you are soldering. They will help keep the header stable and prevent too hot of a soldering iron from bending or melting the connector.
    It does not look like it, but there is only one wire per connector and they are soldered identical. Here is the final product. Don’t forget to remove the connectors after you solder.
    After I soldered, I made sure I had no jumped wires, confirmed the colors were the same on both ends, and wrapped it up in electrical tape.
    I plugged everything in and it worked. Then, I snapped it all into place. I do have one task left, which is to better secure the cable to the cradle so that I can just slide it in. I am thinking of using double-back foam tape, but that is still up in the air... Anyhow, the final product:
    Veteran Member Four Rings Ryan_T's Avatar
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    Very clever.
    Did you figure out which pins are responsible for AMI activity? I'm considering splicing AMI into my pre-existing charger stand. but I need to know which pins are responsible.
    I did something similar, but with the cable routed to my center console where I keep my iPod.
    Ryan - flickr
    Jan 20 2010
    Texas
    Quote Originally Posted by Ryan_T View Post
    Very clever.
    I did not figure out the specific pins. I was just impressed with myself that I did it. I am still trying to get the dang license plate bulbs out so they can be replaced.
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    The license plate bulb holder is a static clip on one end, and a flexible tab on the other. Push from left to right, and it'll pop out.
    Ryan - flickr
    May 05 2009
    Santa Monica, CA
    You mentioned coin holder. I was not aware that the A4 had one. Is that grill that the dock is on the coin holder? If so how do you use it?
    2010 A4 2.0T sedan: ibis white, Premium + : flickr
    debadged, black rear rings, black dash, zaino show car polish, llumar tint, kunst cf filler, chrome tips, höen xenonmatch fogs, VAG-COM
    LEDs: license plate, dome, map's
    Veteran Member Four Rings UmIsThisThingOn's Avatar
    Jun 03 2009
    1954 Volkswagen Beetle
    Raleigh, NC
    Quote Originally Posted by l1fegam3r View Post
    You place coins into the slots.
    Tschüß!
    Ðave
    ____________________________________________
    '10 Brilliant Black A4 Sline • Hüper Optik • 034 HiFlo Turbo Hose • EC HFC • Milltek • Alu Kreuz/ÜSS • Hankook V12's • ST-40 BBK
    May 05 2009
    Santa Monica, CA
    I tried that and it felt like it was going to fall out all over my car. Does it hold quarters specifically? It does not seem to grip the coins very well only just hold it in place if you are going slow.
    May 11 2009
    09 A4 2.0T
    T.O - Canada
    I've always thought it was some sort of vent for return or climate control sensor.
    Ryan - flickr
    Jan 20 2010
    Texas
    It is a coin holder, not a vent. As mentioned above by UmIsThisThingOn, just put coins in the slot and hope they don't fall out when you turn.
    I have learned a few things about using the phone in this dock...
    First, if you answer an incoming call by tapping the phone, it does not go to speaker-phone. Second, I can still stream music from it while using the Map for GPS (woo-hoo).
    After only a couple days, I already see the need to secure that cable to the dock so it can just slide in. I have decided to wait a little bit before I do that. I am hoping that another week of use will help take the stiffness out of the cable and help it mold to the right angle better. This would help keep it in place once secured.
    Veteran Member Three Rings Cabal_san's Avatar
    Sep 06 2009
    TX
    Wow, great idea!!
    The coin slot is absolutely useless as designed. I wish they kept the card holder from the b6. That kept change better than anything!
    Established Member Two Rings zztroyzz's Avatar
    Jun 27 2010
    Ontario, Canada
    This is a good write up about the coin holder:
    http://a6retrofit.tripod.com/article...steryvent.html
    Veteran Member Four Rings Toast's Avatar
    Jul 05 2004
    2014 X3.5m
    San Gabriel
    wondered what that was
    thought it was a business\cc card holder but its too small
    2010 A4 Avant
    Oct 19 2006
    07 A4 2.0T
    Anaheim, CA
    Wouldn't a dock cable extenders have been an easier solution? I love how clean your setup looks but I don't trust my soldering skills to try it myself.
    http://cablejive.com/dock-extender-cable
    Jan 20 2010
    Texas
    Quote Originally Posted by TypeMRT View Post
    I actually started down that path. I decided to go the solder-path for just a few reasons. First, I was not sure how long of a wire I needed. Most of the less-expensive ones on ebay were 3 feet. It turns out that I now know I need 4 feet. Second, the longer wires were all white. I wanted black. Third, some of the wires are advertised as "charging", "no video sync", "data sync" or some other confusing statement. I decided it was not worth the hassle. Finally, I realized that if I wanted to only drill just one little hole through the coin holder, I was going to at least have to cut and solder the extension cord. Otherwise, I would have to make a bigger hold for the connector to fit through. In the end, it just seemed easier to solder and then I could get exactly what I want.
    Installed: Grocery Hooks, BLESK Plate bulbs, iPhone Extension, VAG-Com, Luminics JDM Yellow Fogs, Chrome Grille Inserts, Rear 12v power, Underseat Storage, Folding Side Mirrors, B&O Tweeters, E-Codes with BLESK 5000K, Audi Hill Hold, S-Line Rear Bumper, Warning Triangle, DIS Stalk, Full-Function Rear Power Locks, ADS, Mirror with Compass, Q5 Wheels
    Sep 06 2009
    TX
    Great mod, but for me, sinceI almost lost a finger back in HS with a soldering iron, I decided no way I could build this and just went OEM. I found this CableJive Dock Extender:http://www.cablejive.com/products/dockXtender.html
    It daisy chains off the AMI cable right into my iphone4. I tucked the cable under the trim as you but took it all the way back and not up thru CS. I havent had a chance to pull the AMI box (no keys), so it's also draped along the side then out the glove box towards the back then under the center console. 6' works great. It comes up just past the seatbelt holder on the passenger side. I keep my phone on that pad from dropstop (still very nice dropstop gear, btw!) just below my shifter and run cable from under armrest right back up into the phone. I still need to figure out how to attach wire end to console trim as it comes up over into the armrest bucket space - some kind of clip that is not a 100% permit connection.
    Anyway, this cable not only charges my phone, but gives full ipod functionality in the MMI (plus its black so blends in nicely).
    I'm not sure why Audi doesnt have a solution for us who like to have our phones buy us and not shoved in the glovebox.
    EDIT: The previous CableJive white cable TypeMRT posted above, I could not tell if it would charge the iphone. The one I got does and works flawlessly!
    Thanks for the inspiration TexasEric!
    Sep 06 2009
    TX
    Ok, so I went ahead and completed install today. As TE did earlier, I had service just unlock the AMI box with the Audi radio keys, and I shut glovebox with unit partially loosed. Went home and got the fish tape out and pulled out unit all the way.
    My Cablejive cable is pre-molded, so the head is fairly wide. so I ran down along back of glovebox and poked out the bottom as you see below, behind this round vents. It is NOT in that hole, but behind it (hard to see!) between plastic and hole.
    . Tapped female end to wire and snaked back up. it was tight, but she went thru fine.
    Next i had to alter the back end of the slide tray compartment. You can see a 3/4" slot already. I had to widen it with an Xacto knife.
    . Then pulled female end thru and reconnected to male end of AMI cable. I did take out the slide tray to make it easy then re-assembled and slide it back together when all was finished.
    The below the glove box cable end was snaked under console trim like before. However, I took back past the pass seat belt, then up. I need to find some kind of clip to keep cable nice and straight. Maybe I might remove console and punch up thru next to the hidden cigarette lighter. One day...
    All in all, looks great. I remove my phone all the time, so I chose not to have a stand, like TEs, which his looks way more professional then mine for sure! So here it is with glovebox open...disregard pill blisterpack in slot also. yes I keep RediTab Xanex's close at hand for the traffic around here!
    Jan 20 2010
    Texas
    Very Nice, CS! Nice alternate approach.
    Veteran Member Three Rings FlashA4's Avatar
    Dec 17 2006
    Formerly B7 A4 2.0T - The OG Flash Mobile / B8 A4 2.0T Quat - Baby Flash
    Orlando, FL
    Best thing about your cable, CS...drumroll please...OTTERBOX Defender capability. Worth the money right there!
    Veteran Member Three Rings routertyty's Avatar
    Aug 09 2010
    Honda Mini van
    Menlo Park, CA
    I thought the coin holder was a hand dryer.... like you would see at a bowling alley. :)
    2011 Meteor Gray - A4 2.0T Tip Quattro Prestige & Sports
    Alu Kreuz Drivetrain Stabilizer • Eurocode Sways and End Links • Weather-Tech Mats • Hüper Optik 50% • S-line Stone Guards
    LED License Plate • VAG-COM'd • Sun Shades • B&O Stereo • OEM Chrome Tailpipe • 034 Silicone Turbo Inlet Hose
    Sep 09 2009
    09 RDX
    Rhode Island
    Quote Originally Posted by routertyty View Post
    I think it is used as a SD card holder
    AEM Boost Gauge * Eurocode FMIC * JHM Shiftier * AMR Tune
    Senior Member Three Rings keeva381's Avatar
    Mar 24 2011
    Charlotte, NC
    Cabal - so you had the ability to control songs via your iPod as well as through your MMI screen? I thought I read that once the cable was hooked up Audi took control and you HAD to use the MMI controls.
    I might be misunderstanding your quote, so please clarify if you can! thanks
    Established Member Two Rings mxz's Avatar
    Aug 22 2010
    Woodbridge, Ontario
    Thanks for reviving this thread, I've never seen it before and it's the best idea I've seen yet lol
    Jan 20 2010
    Texas
    Quote Originally Posted by keeva381 View Post
    This is correct, HOWEVER, if your iPhone is jailbroken, you can use cydia to install the "noaccessorysplash" and remove this limitation. With that program installed, you can use the iPhone controls AND your MMI controls. I have had some minor issues with it, but it is still good. Check out: http://www.audizine.com/forum/showth...=1#post6343288.
    Mar 24 2011
    Charlotte, NC
    misread
    Sep 06 2009
    TX
    Oh just saw your question: my iphone gets controlled only via MMI when plugged in. I do not want to jailbreak my phone (work phone), so only can play stored songs. No Pandora access - which really bytes. Keep in mind that I have a Symphony and 2g/3g, if that makes a difference...
    I also get this annoying message when first plugging in about something like interference (can't remember exactly)... but just hit "dismiss" and all is copacetic.
    Feb 22 2009
    Ottawa
    Quote Originally Posted by Cabal_san View Post
    I think someone here was saying that you can kill that splash screen, maybe using the multitasking feature?
    Feb 22 2009
    Ottawa
    [URL=http://img802.imageshack.us/i/amiglovebox004.jpg/]
    I have a Cablejive on order and I was wondering how I'm going to route it out the glove box. Are you saying that in order to pass the cable through the back of the glove box you need someone at the dealer to help you remove the MMI?
    Is it possible to just run it through the hinged back side of the glove box door, and then run it towards the back out of sight? Will the glove box door still close if you do that?
    Sep 06 2009
    TX
    Quote Originally Posted by belzebutt View Post
    Awesome. Someone please post how to set this as a default!
    Well, you can either run by a dealer, go to the SA counter and ask to borrow the 2 keys or buy a set - e.g. ecs tuning etc... http://www.ecstuning.com/Audi-B8_A4-...eys/ES1928335/
    I live fairly close to a dealer. So I dropped by, pulled back by service bay, went in asked to borrow the 2 keys. They go into the small slots at the bottom of the box in the glovebox. I think slanted sides facing in to each other. Push them in and the AMI box pushes out so you can pull it completely out. I did what Eric did and just popped it out slightly, drove home, then pulled out completely and snaked CableJive up behind the glove box as in my pics. The head of the CableJive will not fit thru the back of the slide tray holder as is. It's like an 1/8" too fat and about 1/4" too wide. No biggie, take X-acto and enlarge. Once its thru and connected, slide everything back and no way anyone can see the bigger slot you just made! The hardest part will be taking apart console to make a opening to route cable up under armrest box, where the AUX input is if you do not have AMI.
    I would suggest you swap out your centerconsole trim at the same time (search here on AZ for DIY) to wood or S-Line brushed Aluminum. The cable is too think to close the glovebox on it, so really this is the only way, AFAIK. It's a really easy install. GL
    Apr 04 2011
    2007 Chevy Tahoe LTZ
    Plano, Texas (DFW)
    VERY NICE TEXASERIC!
    There is a company that makes a variety of cradles and some are designed to secure the cable terminal son the iPod/iPhone or any other device can merely be pushed in and pulled out. In other words, the end of the cable becomes fixed to the cradle so placing your device into the cradle is simple.
    They also sell mounting brackets and plates with specific instruction and pictures for your car. Enter make, model and year.
    Same for your device (iPod, iPhone, mp3 players, other phones, iPads, tablets, GPS unites, the big screen at Cowboys stadium, etc. ). They provide specific info and suggestions on them as well.
    It may be wise to talk to their customer service to be sure you know what you are getting because the terms "Cable Attachment" and "Pass-through Connector for Cable Attachment" need explanation. Know which one you need. Some goes for "padded holder" and "adjustable holder" and whether your device will fit. This is important if you use a case over your device.
    It's called ProClip http://www.proclipusa.com/
    Feb 22 2009
    Ottawa
    OK so I just got my Cablejive and I'm very happy, I thought you weren't able to kill the splash screen but all you need to do is hit "dismiss" once and you almost have full use of your phone while it's playing music, like for maps, email, etc.
    The obvious drawback is what you guys pointed out above, that when you play sound with other apps it keeps coming back to the iPod.
    However, the first time I was testing I was actually able to kill the iPod app using the multitasking menu and it stayed off. After I did that the MMI complained that there are no songs to play and I was able to listen to YouTube for a couple of minutes. Then I realized that launching the iPod app manually didn't allow the MMI to control the sound once again, so I rebooted the phone. After I rebooted the phone I couldn't kill the iPod app for good, it only killed it for a few seconds but then the MMI kept bringing it back. I don't know what happened that first time I tried it but I was definitely able to kill it for good, I just don't know how. I'm using an iPhone 4 with 4.3.1.
    Jul 27 2012
    Winter Park, FL
    I know this is an old thread but I didn't want to start a new one. Do you guys think a mount like below would work better since it has a built in connector? You could then permanently leave your cable that is rerouted from the glovebox plugged in to the mount which would allow you to slide your phone in and out much easier. Are there other mounts similar to this one that people have used? Thanks in advance.
    Edit: Wow these are actually really expensive...
    http://www.expansys-usa.com/brodit-h...stable-201949/
    Veteran Member Three Rings TheHeiko's Avatar
    May 24 2012
    Quote Originally Posted by cartar452 View Post
    While still not cheap, you can buy directly from Proclip for $80.
    http://www.proclipusa.com/brodit-dev...165-18357.aspx
    Jan 20 2010
    Texas
    When I started this project, I was actually thinking of using a cradle with the wire molded into place (similar to the one you picture). That would make the "connecting" process just a matter of sliding the device into place--no fumbling with wires. The problem I had was purely cost. They were about $80 (as mentioned above). Considering the cradle I used above cost only $3, I felt it was worth the trade off. Before you buy something make sure you know where you want to put it and hold your phone in that location as a simple test. The last thing you want to do is mount it in a spot that blocks easy access to other controls.
    Jul 27 2012
    Winter Park, FL
    Quote Originally Posted by TexasEric View Post
    I agree that the extra cost really isn't worth it. What do you think about running the wire through the hole where the oem auxiliary plug would be. On my car there is just a square filler plate there that I assume can be removed. A notch could be cut in the plate to allow for the cord which would prevent the connector from falling back under the console. A few feet of slack in the cable could then be left in the area under the armrest. Has anyone done something similar to this?
    Mar 28 2009
    Minneapolis, MN
    I thought about ordering one of those mounts with a pass-through connector, but with all the rumors that Apple is switching to a small dock connector on the next iPhone (which I plan to upgrade to), I thought I'd wait and see what comes of it. Here's some speculative info about what may or may not be the next dock connector, based on some "leaked photos" of it: http://itsmorereal.tumblr.com/post/2...dock-connector
    Jan 20 2010
    Texas
    If your goal is to move the phone closer and have no need to see the screen, then this is a great idea. I am not sure how well it would work if you want to look at the screen (for navigation).
    Jul 27 2012
    Winter Park, FL
    Since my car has navigation the main goal for relocating the cable is for just convenience of having my phone closer. Does anyone know if there are any difficulties with running a cable from the glovebox to the aux location under the armrest?
    Mar 28 2009
    Minneapolis, MN
    No difficulties that I know of, but you're probably going to need at least a 6' cable.
    Jul 25 2012
    United States
    Here's how my iphone was mounted:
    The bracket was originally from my old car a Mazda 3, its a Bracketron brand (I do no believe they sell them anymore). Basically the screw that holds down the CD changer holds the bracket in place and of course its wedged between the vent and the side. Purchased for $2 bucks, since they were clearing them out.
    The pass through dock is a Dice (now audiovox) DC 50 i believe ($50?). It works no problem. Unlike the Proclip, the connection is through the back so you don't see a ipod wire hanging down. From the back you only see a wire (and its black) coming out of the glove compartment to the dock (I did buy an extender, haven't tested to see if the standard wire is long enough). The dock it self swivels so you can adjust how it faces you, also it came with side holders for different types of iphones/ipods.
    I'd love for just a bit cleaner look (the bracket does stick out far and at an odd angle), but its pretty good now. Hopefully apple creates a dock adapter for the new iphone and I can somehow shoe horn the side holder.
    Mar 28 2009
    Minneapolis, MN
    That's similar to the Panavise 75102-109 I put in my car. It's a two-piece mount that goes in the same location.
    My phone sits in a ProClip holder. I have since re-run the cable so it's not sticking straight out of the glovebox.
