Page 1 of 3 123 LastLast
Results 1 to 40 of 90
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    UPDATED!! Red Oil death light and results of fixing the problem (pickup screen)
    I have seen this topic come up a million times and have always given advice on what to do to fix it, well this time I took my own advice.
    Recently in various post I have posted that my cam chain tensioner was making ticking noises leading me to believe it was on its way out or it was starving of oil, but never had the low oil pressure light. When driving on saturday I got the low oil pressure light, called up Jordan (co avant) and got the car to his house.
    We already had plans to drop my oil pan and clean the pick up screen, but didnt plan to do it this soon and were going to do it down the line when doing my block. We put the car on the lift and within an hour we had the subframe dropped out and the oil pan off. Right when the oil pan came off, we then saw the oil pick up screen clogged like a mother ******! We tried to shine a light through one side of the pick up tube and the light wouldnt even come out through the screen. Thats how bad it was.
    We then cleaned it out with various little techniques.
    1) brake cleaner
    2) brake cleaner and setting it on fire (burns all the deposits out)
    3) soaking in diesel for a little while
    4) more burning and using a pic to get everything out.
    After doing all this the pick up screen was perfect.... if you shined a light through one side of the tube you can see every hole in the screen was free and clear.
    Buttoned everything back up with the cleaned out pickup, new oil, new filter, cleaned the inside of the oil pan etc. Started the car up and it has never sounded this quiet. Cam chain tensioner noise completely gone, valve train seems a lot less noisy and overall the motor sounds a lot healthier.
    Total time of the process was One hour for taking it apart, two hours for cleaning of the screen, one hour to install everything back on.
    Not much more to say. If you get the red oil light, chances are this is your problem. I will be posting up a lot of pictures of the before and after, as well as dropping the subframe/oil pan and cleaning of the screen etc.
    WERD!
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Wow! Nice job in correcting the issue before major damage occurred! Any idea as to what was clogging the screen? I'm sure it wasn't sludge since I know you have been performing adequate PM on your car. Kinda scary!
    Mar 31 2004
    CA
    Good point! Totally forgot to mention what I think caused the light to finally trigger.
    When I installed my turbo last week and put the new oil in, I put a dose of AUTO-RX in with it. My guess is the Auto-rx did its job and cleaned out any deposits etc and then got sucked up in the screen. However im sure there was some build up in the screen considering my motor has 150k on the clock but not enough to cause low oil pressure.
    No signs of sludge though and overall looked pretty clean inside. (besides the pickup)
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    Wouldn't it be easier to just but a new pick-up screen instead of cleaning the existing one?
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Mar 31 2004
    CA
    It would be a lot easier yes... however it was sunday (when finally working on the car) and dealers were closed. I had friends in town and needed a car ASAP! Also pickup cost about 100 dollars so it saves you a bit of money... but if the dealer was open I would have just bought a new one to save me time.
    TIME IS MONEY!
    Dec 28 2006
    Western Maryland
    Don't like hearing that! I have been using a maintenance dose of Auto-RX for several years and everything looked good last year when i replaced the valve cover gasket. Hope the red light of death isn't in my near future.
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    Great post man. I recently did the same thing on my car as well and it solved the oil pressure light as well as the ticking from the cam chain tensioner. Unfortunately for me, the previous owner didnt quite keep up on maintenance and I now have a sludge issue. I've been meaning to make a post about this but it looks like you beat me to it
    RS4 Rear Sway :: KW V1 Coilovers :: B5S4 Calipers :: W&L Catalytic Converter :: 30% black tint :: S4 Door Blades
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    Great job! This is gonna help a lot of people out!
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Q8 Rotors, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Mar 31 2004
    CA
    I woudnt worry about it to much. My cam chain tensioner was making noise and slowly getting louder. So it was either on its way out or just not getting enough oil due a clogged pickup. I thought maybe a the auto-rx would help in cleaning it a bit, before I try and replace the chain tensioner or drop the pan to do the pickup. So really im happy this was the case... saved me 250+ dollars on buying a new tensioner, but of course i caught it in time so no damage was done.
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    I really need to do this soon. I don't have a garage though... I'm going to have to take it somewhere.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Mar 31 2004
    CA
    yea, thankfully Jordan has a lift in his garage. It is possible to do on jackstands, but life was a lot easier having the lift!
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    Charlie and Old Guy, did you guys perform the basic application? If so, which conventional oil? Or just did the maintenace program? Thanks
    Mar 31 2004
    CA
    This was my first time with auto-rx. I have done seafoam before though. On this one I did the full thing so went with dino oil, GTX 5w-30. Didnt even make it over 50 miles when i got the oil light.
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Great info! I have the same cam chain tensioner sound you speak of, I hope this isn't my prob.
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by mrbacardi35 View Post
    I have just been adding a maintenance dose with each synthetic oil change. Since I purchased the car new I know the maintenance performed (5K synth oil and filter) so I really haven't felt the need for a full treatment. With that being said, I have run the full treatment on numerous other vehicles that had an unknown service record.
    Jun 22 2009
    Dundalk, MD
    no pics?
    Mar 31 2004
    CA
    Pics are coming. my chick took a bunch of pics while we were doing it and I am going to post them soon as she uploads them. the pics will do all the talking.
    Mar 31 2004
    CA
    Yea, adding it from day one, im sure your motor is good to go. Auto-rx is great and I have nothing bad to say about it. It did its job on my car, however my pickup was just to backed up to pass the stuff it cleaned up.
    lot of success stories with auto-rx. i am now going to do the 3oz dose with every oil change.
    Jun 30 2009
    Washington DC
    What is this noise that you guys are speaking of?
    Mar 31 2004
    CA
    noise is a loud ticking noise coming from chain tensioner (back of the head by firewall)
    mine was like this... but not nearly as loud http://www.youtube.com/watch?v=toO2nP9UjDk
    Sep 18 2006
    Thanks Charlie and Old Guy.
    Sep 18 2006
    Quote Originally Posted by Audi Skate Snow View Post
    thats what i got in mind too since i have been using the seafoam treatment.
    Jun 30 2009
    Washington DC
    Thanks, i wish i can give you rep because i always wondered what that sound was.
    ANother question would be; how would i know if the cam tensioner needs to be replaced or if the screen picks need to be changed?
    Aug 14 2007
    2002 Dodge Dakoto 4.7L & a 1990 Honda Accord that won't die
    Bellevue, WA
    Good catch by you. Very much looking forward to pics and info on dropping subframe and getting to the oil pan.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    yeah a lift and air tools makes it for an easy 1 hour job. but on jackstands with hand tools, i'd guess it would take at least 3 hours to get that damn pan off
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Mar 31 2004
    CA
    Quote Originally Posted by sean1.8t View Post
    for sure... this job on jackstands is possible, but just plan on it taken fuckin forever! ahahahha Guess if you gotta do it though. Air tools are not necessary, but just like a lift makes life easier.
    Jun 30 2009
    Washington DC
    Looks like i should get myself a good set of air tools.
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Pics por favor?
    Oct 03 2007
    New York
    Pics would be great. My oil pan has a moderate leak that I need to get on. Now I am dreading doing it on jackstands, or even worse shelling out the cash for 5 hours of labor!!
    Mar 31 2004
    CA
    Quote Originally Posted by [email protected] View Post
    Pics por favor?
    workin on it... have some trouble with the camera, for some reason the firewire will not go in.
    Veteran Member Four Rings nananana4k's Avatar
    Sep 10 2005
    A4 B6 3.0, Q5 B8 3.2
    If you have email on your phone you can email it to yourself and host on an image site. Great work on this btw.
    Mar 31 2004
    CA
    Quote Originally Posted by nananana4k View Post
    Took the pics with a real camera no on the phone... would be sweat if a camera could email though ahah
    Thanks man, I have tried to help a lot of people with this issue and finally had to do it for myself.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    I knew for sure even before Charlie's red light of death that this thing was clogged to hell. Just did my GF's on her B6 with 1/2 the miles as Charlie and it was even more clogged. Oil light never came on with her car, but just by looking at the sludge under the valve cover when I did her VC gasket a couple months ago, I just knew there was no way it wasn't clogged. The last 5 B6's I've dropped pans on have all had clogged pickup tubes. Only one I've seen (out of 7) without a clogged pickup with over 50K was my car when I broke it down to go 2.0L in 2006.
    Veteran Member Four Rings davkav's Avatar
    Dec 04 2008
    Dublin, Ireland
    I hate Reading this shit.
    Always makes me think "what if"
    I think for safteys sake I'll tackle this next month along with a treatment of autoRX
    curious to see these pics too
    -Dave
    B6 A4 USP Avant 1.9 TQ 6M (01E) - 71r - Revo 550 File
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    So to drop the pan you need to drop the front subframe too? Will that mess with the front alignment?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    Quote Originally Posted by CO AVANT View Post
    Lol well I'm at 53k and you've got me worried. I'm going to do my VC Gasket when I do my next oil change in 2k miles, so that should let me see if I have any sludge buildup.
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Feb 12 2004
    Everywhere
    Quote Originally Posted by MikeWire View Post
    Not necessarily but it will take a lot of time off the job by just getting the subframe out of the way. A/C line can be moved by hand so you can wiggle the oil pan out without having to take the A/C line off. The front engine mount bolts have to be lowered down (not taken all the way out) to get the subframe to wiggle out. A big pry bar helps get the control arms out. You will also need a high jack stand to support the trans/engine while the subframe is out. The part of the secondary subframe that connects to the trans needs to come off. You can just pull it back toward the rear of the car over the exhaust so you don't have to pull it all the way out and take your exhaust off. These are just a few good pointers on this job. Next one I do I'll definitely do a write-up on it.
    Yes it will mess with the front alignment. Sometimes you can get it close though if you know what to look for, mark, etc.
    If you have had your car for its entire life and have been doing regular oil changes every 3-5K with a new filter then you "should" have a cleaner pickup tube than most.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by vintagespin View Post
    It will be difficult to determine if the oil pump pick up is clogged by just looking at the valve cover and cylinder head.
    Why? The valve cover and head may be clean looking with no sludge present, yet the oil pump pick up would be pretty clogged.
    If you have sludge build-up in the valve cover than you better clean that oil pump pick up ASAP.
    I remember doing the oil pan gasket on my original, bone stock, motor (we dropped the subframe to get the pan off). That was with 110k on the odometer and motor. I bought my car at 36k and did oil changes ever 5k with a new filter (oversized) and synthetic oil. Had no idea what the previous maintenance records were beyond the dealership 10k oil change with the small filter.
    When we had the pan off at 110k the oil pump pick-up was spotless. Never did seafoam or auto-rx either.
    -Doug
    Mar 08 2007
    Air and water
    SATX
    ^^ great info!
    I got my car w/ 102K miles and don't know the oil change history. I use RP and the big filter, but who knows what the OP used.
    The only real info I know about it is that it's a Colorado car. A kid owned it who went to CU Boulder, and made frequent trips back home to CT, and @ 90K the dealership replaced a shit ton of parts...turbo, CAT and TB job, brakes.
    Anyhow, I digress...back OT. I'm gonna do some searching on dropping the pan and inspecting the pickup tube. Possible DIY in the works, unless there already is one.
    -Mike
    @countdowngarage
    Sep 15 2008
    CO
    Yeah, that's what I figured. At least I'll know if the engine is in deep shit or not. I bought it with 33k and have no idea how the car was treated previously, but I have been doing 5k changes with a new oversized filter since I bought it.
