I need help making this work cuz the sensor are diferent from each other. The connectors are not the same but I will make it work instead of buying new one.
For this conversion I bought:
2 ecu awm (auto and 5 speed)
2 wiring harness (2001 awm audi a4 and 2003 vw awm engine)
awm maf
awm map sensor
dbw throutle body
2001 instrument cluster
green coolant temp sensor
oil pressure sender
4 4pins coil pack
Need to get:
pedal assembly
gas pedal wiring harness
alternator(different connection)
n249(just til I delete it)
n115(just til I delete it)
some interior harness(cluster, radio, fuse, hvac)
fuse box
4-windows hall sender wheel or plate for cam sensor
Now there are two connectors that I don't know yet. I got this information out from a passat awm engine. correct me if I am wrong.
One of the connector look just like the connector from the map sensor
and the other one is a 3-pins with 2 cable
does it have speed sensor?
