Originally Posted by
k33psp00lin
Not to bring back this dead thread, but Im about to go pick up this oil what the verdict on the filter?
Verdict = MANN is the better choice.
The M1-301 was actually designed to fit a Ford SB V8... it just happens to have the same thread size and gasket placement as the VW filters... M1 knows this and markets the same filter across the board to sell more filters w/o having to produce more models... its all about their profit, not what is best for YOUR car.
the bypass setting on the M1 is set to 10psi. Stock VW/MANN bypass pressure setting is around 30psi. The M1 although it will fit, is not your optimal choice. If you are looking for something over the counter that you can buy at a local autoparts, then the WIX #51191 would be a better choice.
SPEEDBUILT
From what the Autozone guy has told me......
Mobile one filters down to the smallest particle while K+N flows the best and has the highest burst rate.
FWIW
dont trust anything the AutoZone guy tells you. they are not there cause they are experts, they are there cause AZ needs a body to take your money, mop the floors, & keep people from robbing the store blind. (not that it does not happen anyways) the guys in the red shirts make minimum wage, or a hair above... the guys in the gray shirts average about $2 more. what they preach is their personal opinion, so take the information for that, just that, and nothing more... most dont know what the hell they are talkaing about, and could not find their way out of a paper bag.
