Results 1 to 38 of 38
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    B8 S4 vs B7 RS4!
    6 Runs Stock B7 RS4 - Averaged
    6 Runs Stock B8 S4 - Averaged
    ALL WHEEL HP/TQ
    Discuss.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Veteran Member Four Rings bunnn's Avatar
    Jan 24 2006
    e92
    What happened to the last little bit of revs on the RS4? Your graph reminds me of how my m3 dyno'd...just cut off at 7800....
    How many kms was on the RS4? Wonder if the carbon build up affected this particular car.
    Cheers!
    ~Ben
    Aug 23 2008
    Auburn, AL
    around 7850 the power drops off as it's ending the run so I cut off the graph.
    Veteran Member Four Rings NWS4Guy's Avatar
    Sep 29 2009
    2015 Range Rover Evoque 2010 Audi S4
    Good topic, 2 stock cars run back to back on the same dyno - I like it!
    Question about the B7 RS4 - how clean were the intakes? Any thoughts to carbon buildup on them since this is an older car compared to the B8?
    Like a surgeon with a scalpel, my S4 is a precision instrument, with which I carve and dissect my way through traffic.
    2010 S4 Prem+, Quartz Gray, S-tronic, Sport Diff, B&O, Nav, Gray Birch
    StopTech ST-60 BBK - Stratmosphere intake - APR v2.2 Stage 2 w/pulley + exhaust, v2 Coolant System
    Alu-Kreuz, Apikol rear diff mount, 034 transmission mount
    Veteran Member Four Rings GQ//S4's Avatar
    Jul 25 2007
    Today?
    North of Seattle in trees, WA
    Interesting to see, I've heard about this a couple of times already on here where the b8 has a rather impressive pull compared to an Rs4.
    After hearing so many recent threads about carbon and misfire issues I'm starting to look at the s4 more than the Rs4 as a next car....
    - Michael
    Fact: I'm Awesome
    Former: '92 911 C2, 01.5 S4 Stg 3, 00 S4
    I always dreamed of walking on clouds, so I drive on air
    My logic is infallible. Always.
    Grammar Nazi #1
    "I'm too close for missiles, I'm switching to guns!!!"
    Sep 29 2009
    Oh and if you want to see some action on this thread, someone cruise over by the B7 chatterbox and point them this way - though I think Sak is gone now.
    Veteran Member Four Rings riegeraudi's Avatar
    Apr 16 2009
    Do you guys have any dyno's for the S5? I wonder if the S5 is also underrated because the S5 does the 0-60 about the same and the 1/4 also about the same as the S4.
    Feb 11 2010
    I've been watching these forums for a while, and from everything I have seen I bet the next RS4 will have a pretty similar engine to the S4, but with that 400lbs weight reduction they are testing with the new frame (see another thread for that). That thing will fly, even if they only moderately bump the engine output from the S4.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Awesome, awesome post!
    Very cool differences...really makes one appreciate each motor!
    So, the question is, do you like to rev?
    Or...does one prefer the early/constant boat-load of torque...?
    Win win.
    Brilliant Black 2001 S4 - 6MT <3
    Jan 01 2010
    2010 B8 S4, 2014 Audi Q5 TDI, 2013 BMW S1000RR
    Wayland, MA
    The thing I like about the S4 output over the RS4 is the mid-range advantage, which is what counts on the street IMHO.
    Apr 16 2009
    Quote Originally Posted by JackalS4 View Post
    Win win.
    This discussion is the same as the ones that happen on the BMW forums with the chipped 335 and the M3. The 335 has more torque but the M3 revs much higher.
    Veteran Member Three Rings drvolkl's Avatar
    300ZX TT, NSX, S2000, Tacoma, X3
    I just can't wait to see APR's chipped S4 results... I imagine that will really bring some spirited discussion to the forum. :)
    C5 S6
    B6 S4
    B8 S4
    B6 S4 Avant
    B8 RS5
    C8 RS6
    C8 RS6 Performance
    Active Member Two Rings kwikwi's Avatar
    Dec 03 2009
    MB ML320 BlueTEC
    Quebec/Canada
    Different cars for different purposes. One is a very good DD and the other is a very good track car where higher revs are useful. S4 vs RS4 / 335 vs M3. The best is to own both!
    2010 S4 / Premium (in CANADA) / Brilliant Red / Magma-red Silk Napa / S-Tronic / Sport Diff / B&O / NAV
    Senior Member Two Rings s-4man's Avatar
    Nov 11 2009
    Range rover evoque Audi TTRS Polaris ace 900 sp
    montreal
    looks like the s4 doesnt like high rpm.
    2018 TT RS
    Jul 11 2005
    04 Audi S4, 04 VW R32, etc....
    Auburn
    Quote Originally Posted by s-4man View Post
    hehe, its interesting to see how that curve changes when you can add loads more boost up top.
    Sep 29 2009
    Quote Originally Posted by Keith@APR View Post
    You tease!!!
    Hey so about the RS4 - can you speak to it's mileage or the potential of carbon?
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    the S4 factory curve starts to limit boost at high rpm, this is why it has a very flat torque curve and a low peak hp after such a low rpm. Its not that the tuned version poushes high boost, as it maintains boost to redline.
    The sportec curve shows this quite well. from 3000rpm to 7000rpm the tuned version makes increasingly more hp. The curves slope is just steeper past 3000. Take the great stock curve that dominates the rs4 in the midrange, then add just as much domination on the top end, and you have the tuned S4.
    add the hp and torque curve past 5000rpm to the stock curve.......poor rs4. weak sause in the 2010s decade.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Senior Member Two Rings notjoefromnh's Avatar
    Apr 10 2007
    2010 S4, 2007 Chevy 1500, 2011 MXZX 800Etec
    NH
    Wheres our chip?
    2010 S4 - Sprint Blue, Magma Interior, Prestige, Drive Select, H&R Sport Springs, Smoked 19"s, AWE Exhaust, Strat Intake
    Veteran Member Three Rings BKNYCS4's Avatar
    Jan 14 2010
    Quote Originally Posted by notjoefromnh View Post
    wheres our chip?
    where where where??!?!?!?
    2010 Phantom Black S4, 6MT, Fully Loaded *SOLD
    2019 Nardo Grey SQ5 Fully Loaded *SOLD
    2020 Blue Metallic A6 3.0T, Fully Loaded *SOLD
    2017 Daytona Grey RS3, Fully Built TTE700 *CURRENT
    Jul 11 2005
    Auburn
    Quote Originally Posted by NWS4Guy View Post
    You tease!!!
    12k vs 45k+
    Jul 11 2005
    Auburn
    Wheres our chip?
    I ate them.
    Seriously, its still in long term R&D.
    Dec 15 2009
    Calgary/AB
    Quote Originally Posted by riegeraudi View Post
    S5 cab should be underrated just like S4. S5 coupe is just an V8. I don't think there is any buzz about it being underrated by that huge margin.
    And Keith, you better have the tune ready by summer
    Established Member Two Rings Relentless's Avatar
    Jan 27 2010
    San Francisco, CA
    interesting. I've heard that the RS4 and the B8 S4 do about the same quarter mile times... that sound right?
    Dec 15 2009
    Calgary/AB
    12.8 vs 13.2 they are close. Now that we know what's hindering the S4, I'm sure it will blow away RS4 after tune.
    Wait a sec........
    So S4's stock HP is closer to 400HP?
    Nov 11 2009
    montreal
    I have seen 13.2 1/4 for the rs4....and it doesnt trap very high.
    2018 TT RS
    Nov 11 2009
    montreal
    maybe this guy didnt know how to drive... http://www.dragtimes.com/Audi-RS-4-Timeslip-13304.html
    2018 TT RS
    Account Terminated Two Rings
    Jul 28 2007
    Porsche 911 Speed Yellow
    Metuchen, NJ
    The APR graphs are so fucking impossible to read. Red should be one color, and the white should be another. This is so fucking confusing to look at.
    Nov 11 2009
    montreal
    rs4 Performance Top
    0 - 30 (sec): 1.7
    0 - 45 (sec): 3.1
    0 - 60 (sec): 4.7
    0 - 75 (sec): 6.8
    1/4 Mile (sec @ mph): 13.2 @ 106.8
    30 - 0 (ft): 26.5
    60 - 0 (ft): 107
    Braking Rating (Excellent, Good, Average, Poor or Very Poor): Excellent
    Slalom (mph): 70.6
    Skid Pad (g-force): .90
    Handling Rating (Excellent, Good, Average, Poor or Very Poor): Excellent
    Db @ Idle: 47.4
    Db @ Full Throttle: 79.4
    Db @ 70 mph Cruise: 65.3
    Specifications Top
    Length: 180.7 inches
    Width: 71.5 inches
    Height: 55.7 inches
    Wheelbase: 104.3 inches
    Legroom (front): 41.3 inches
    Legroom (rear): 34.3 inches
    Headroom (front): 37.9 inches
    Headroom (rear): 37.1 inches
    Maximum Seating Capacity: 5
    Cargo Volume: 13.4 cubic feet
    Maximum Cargo Volume (rear seats down): N/A
    Source(s):
    Edmunds.com
    2018 TT RS
    Apr 16 2009
    Quote Originally Posted by xtrema View Post
    I am talking about the 4.2 V8 as the coupe with this motor has about the same 0-60 and 1/4mile times.
    Nov 11 2009
    montreal
    RS4 Sedan Clocked at...
    0-60: 4.3 seconds. 1/4 Mile: 12.8 @ 109.7 (Road and Track)
    0-60: 4.5 seconds. 1/4 Mile: 13.0 @ 102.1 (Motor Trend)
    0-60: 4.5 seconds. 1/4 Mile: 13.1 @ 108 (Car and Driver)
    0-60: 4.7 seconds. 1/4 Mile: 13.2 @ 106.8 (Edmunds)
    2018 TT RS
    Registered Member Two Rings DucatiSim's Avatar
    Jan 30 2010
    Anyone know how much Crank HP the graph in the original post represents for the stock S4?
    2010 S4 Black 6MT (Mar Build Date), 2008 Ducati 848 Red, 2008 VW Touareg V8 Black, 2008 A4 3.2 6MT Sliver, 2007 BMW X3 Tan, 2008 Baby Boy - Evan
    Jul 14 2008
    Hong Kong
    I had a B7RS4 before and a S4 now. I have not done any performance testing but the butt dyno tells me that they are very very close in terms of acceleration. The S4 being the S-tronic is obviously easier to do it repeatedly. However, the RS4 does feel more powerful in the lower range, where the S4 is all torque.
    I have to stress that it is from my personal experience and no testing whatsoever.
    Jul 11 2008
    Italy
    @Arin
    Is this the same S4 whose dyno of about 330 WHP started all the debate ? didn't you have the opportunity to dyno another one ? thanks,
    Mar 01 2006
    2021 X7 M50i, 2021 911 Carrera S
    Melrose, MA
    2020 M4 Convertible 6MT - Alpine White - Sakir Orange - JB1
    2019 X3 M40i - Dark Graphite Metallic
    2010 S4 - 6MT - Phantom Black - Black/Black Alcantara - Nav - Sports Diff - G.I.A.C. Stage 2 - AWE S-Flo Intake - 034 Transmission Mount Insert - JHM Crank Pulley - CR-15 Strut Tower Brace – Sachs XTend Clutch
    Established Member Two Rings Dubber4life's Avatar
    Nov 08 2009
    New England
    The S4 dynoed at 316 whp on APR's dyno. The 330 whp was the corrected number.
    Cesar
    2010 S4 | 6MT | Prem+ | Quartz Gray | Black/Brown Nappa | Nav | Sport Diff | B&O | Stainless Steel Inlays | 19" Wheels
    Jul 11 2008
    Italy
    Quote Originally Posted by Ray Khan View Post
    Damn how could i have missed it ? this is important and recent... how comes there's no dedicated thread ? altough i don't see the test conditions (temp, type of fuel, etc.), nor indications if those value are uncorrected or SAE, the numbers are impressive... i want to know more...
    Mar 01 2006
    Melrose, MA
    Quote Originally Posted by aherl83c6h View Post
    It's from the AWE exhaust teaser post. They use a mustang dyno. Everything I've seen from them seems to make sense as far as numbers go. Stock B5 S4 puts down 190 whp. My APR stage 3 A4 put down 224 whp on the same summer day that a friend's T28 A4 put down 225 whp. The numbers and curve seem to agree with the APR numbers. Hopefully their exhaust numbers are coming soon.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Dyno results are dyno results, it has little to do with 0-60 and 1/4 mile times. The 0-60 and 1/4 times can depend largely on gearing, tire/road condition and the all important, human factor. The V8 S5 was dyno'ed to be ~30whp less than the V6 S/C engine ( http://www.audizine.com/forum/showth...ght=S4+S5+dyno ) a little while back.
