Results 1 to 26 of 26
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    2004 A6 S-Line Wood Grain....
    Ok so i have a 2004 A6 S-line.....does anyone know if the wood grain inside is REAL wood??? i saw somewhere that it was real, but im not 100% sure.....anyone know?
    this is the same color and wood i have inside...
    thanks.
    2004 Audi A6 2.7T
    Veteran Member Three Rings awtst3.a6's Avatar
    Nov 08 2008
    2000 s4, 2001 a6
    Va
    I have also heard it is real wood . That is why I always knock on it, when I say knock on wood :P
    auto GT a6 - is here.....
    "I compare it to a centerfold model.Just because her measurements are great doesn't mean she's a good lay"
    Mar 30 2008
    Pittsburgh
    HAHA same here man....i hope its real :)
    2004 Audi A6 2.7T
    Apr 18 2007
    ny
    YEah it's real
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Mar 30 2008
    Pittsburgh
    NICE! ...... now here's the other question ..... do you think it has clear coat paint over it, or some kind of hard plastic dip stuff?
    2004 Audi A6 2.7T
    Apr 18 2007
    ny
    It should be clear coat, but who knows what kind they use. Are you looking to refinish Frank?
    SOLD
    Greg
    C5UNION
    Mar 30 2008
    Pittsburgh
    Yeah, i want to get them all sanded and do it flat like the Volvo wood grain.
    2004 Audi A6 2.7T
    Apr 18 2007
    ny
    I would buy a used piece from ebay and do your testing on that. I'm pretty sure if you scuff the finish and respray with a flat based clear coat it would look good.
    SOLD
    Greg
    C5UNION
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    Walnut was used for the allroad
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    Senior Member Three Rings Asicks's Avatar
    Apr 01 2009
    01 allroad 2.7T 6MT/00 A6 2.7T
    Minneapolis
    Quote Originally Posted by FrankA6 View Post
    I hope you get it to work. Flat would look awesome!
    -Scott-
    Mods - Far from stock
    C5UNION
    Reppin' the Midwest
    http://www.audizine.com/gallery/data...fitti_wall.jpg
    Established Member Four Rings matt@oCarbon's Avatar
    Oct 19 2004
    Glendale, AZ
    Few things of note since I routinely sand through all the various types of trim that Audi offers:
    1) Not sure what the surface is coated with, but I'm almost positive its not a clearcoat. You can sand it down though, its pretty thick. I use a finishing sander and even with 80 grit and some muscle it takes me a while to get it down.
    2) You have to be REALLY careful after you've sanded a lot of the top coat down, especially if you've never done it before. Once you burn through the top coat, the actual layer of decorative wood is pretty thin. You'd have to use a very high grit sandpaper and take a lot of care not to sand for too long in one spot other wise you run the risk of cutting through to the ugly wood below.
    Apr 18 2007
    ny
    Good advice Matt, +1 imaginary rep
    SOLD
    Greg
    C5UNION
    Oct 19 2004
    Glendale, AZ
    I just Dremelled through a bit of a B5 door piece to give you a better idea of what I'm talking about. All the areas that are still slighty hazy and grey are where there is still top coat on the wood. As soon as you go through that top coat though, you hit the ugly wood.
    If I were you, I would just scuff up the top coat a little bit, wetsanding at like 400-600 grit, and then add whatever finish you were you going to add. Maybe a brushable Minwax Satin finish?
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    You have a PM coming Frank ;)
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    I agree with Matt, you'll have to dull the gloss finish and use like a matte clear.
    OEM + work in progress
    Veteran Member Three Rings Tamas's Avatar
    Jul 27 2009
    '05 allroad 2.7t 6MT, APR Stage I
    Toronto Ontario Canada -eh?
    Quote Originally Posted by doobiesdaddy View Post
    Real walnut?
    And that flat finish would look really good.
    Mar 30 2008
    Pittsburgh
    Im going to try and do something with it.
    So does anyone have a DIY on how to remove the wood trim?
    2004 Audi A6 2.7T
    Oct 19 2004
    Glendale, AZ
    Yes. Just because some here might be swapping out interior trim...
    Veteran Member Three Rings patrick23's Avatar
    Dec 09 2009
    2004 Audi A6 S-line, 2001 Nissan Pathfinder SE, 1999 Subaru Legacy Outack Limited
    val-des-monts quebec
    that's the same one I used to remove mine Matt- follow those Frank and you should be good
    here's the same one with pics :)
    link
    Mar 30 2008
    Pittsburgh
    thanks guys :)
    2004 Audi A6 2.7T
    Dec 09 2009
    oh and try not using a screwdriver as pictured though, too risky imo- get a zdmak tool or something similar
    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    can anyone confirm if all C5 wood trim interior real wood? or does it just apply to s-lines
    Oct 19 2004
    Glendale, AZ
    Quote Originally Posted by deucescorner View Post
    Every Audi set of trim I've ever received (across all model lines) that looked like wood, was real wood.
    Aug 26 2008
    None
    None
    Quote Originally Posted by matt@oCarbon View Post
    sweet!!
    Thanks
    Veteran Member Three Rings BostonDriver's Avatar
    Sep 22 2004
    Massachusetts
    Quote Originally Posted by patrick23 View Post
    Absolutely! I was shocked when I saw the "updated" post with pictures to my instructions. I use plastic pry tools from Zdmak, available from ECS Tuning. Those are the BEST tools for this job! Also, Lowe's Home Improvement has a micro-adjust 13mm wrench that is great for the bolt under the armrest.
    I am curious to see the finished product of this wood refinishing project. Just keep in mind that the wood, although real, is only a VERY thin veneer over aluminum, so there is not a lot of wood to work with once you strip off the clear epoxy. Good luck!!!
    Nov 18 2005
    Pair of (. )( .)
    Its like 1mm of real wood lol
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
