Originally, temp gauge crapped out and CEL light came on, I had P1296 error and I first changed the 4 pin green coolant temperature sensor, no luck. Then noticed no heat so moved onto the Thermostat
I changed the Thermostat on Sunday, and bled the air out of the coolant multiple times/refilled....Temperature gauge is now working correctly and heat is coming into the cabin. Only issue I see is the fan comes on when I start and seems to run for about 5 minutes.
I had an emissions test last night and passed.
Today, go to an dentist apt., warms up fine on the way, come out after the apt., car won't turnover, takes about 3 times and then EPC and CEL come on. This also happened about a month ago before the thermostat went out but no CEL or EPC light came on, just took several times to crank. Thought my battery might be going bad. I actually remember unplugging phone/gps from power and then restarted (if that actually has anything to do with it)
I head to Advanced Auto Parts and the pop a P1296 - MCC and P0322.
Looks like the P0322 code is related to the Engine Speed Sensor
So, my questions are
1) Can the P1296 be related to the P0322?
2) Any ideas on why fan still runs on start up for a few minutes? Could it be b/c the lower coolant temp sensor?
3) I'm going to go by Audi and pick up the Engine Speed Sensor and replace tonight, anything else?
4) Do things tend to go out together on these cars? Should I anticipate changing anything else soon, or go ahead and replace something else now?
thx
