Results 1 to 16 of 16
    Sep 23 2009
    Racine wi
    What size tires on a 18x9 rim?
    I just bought raderwerks mten80 rims. 18x9. And I was wonder what would be the best size tire for them on stock suspention.
    Veteran Member Four Rings L0U's Avatar
    Sep 03 2009
    18 R8 RWS, 20 RS3, 21 RS6, 04 Ducati SS1000DS
    Quote Originally Posted by S4whity View Post
    255 works well with 9, but if that is too much to stuff under the car...depends on rims offset, a 245 will work. 235s will start to look stretched.
    What car is it going on? And what is the stock wheel size. Need to know to recomomend a profile...likely a 40 series.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    Quote Originally Posted by L0U View Post
    Really depends on the car.
    Admins: this is why we need the "my garage" feature under avatars
    -Jeff
    Sep 23 2009
    Racine wi
    I have a b5 s4. Stock suspention and the offset is 35.
    Sep 03 2009
    225x40 on 30et 18x8.5 work well.
    so 18x9 35et and 235x40 should be great.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Apr 27 2009
    Personally, I would go 235/40. Might stretch just slightly but nothing really noticeable and will look nice
    -Jeff
    Veteran Member Four Rings forevraudi's Avatar
    Sep 01 2008
    San Diego, CA
    you better post up pics! those are my next wheels
    Sep 23 2009
    Racine wi
    wont 235 be stretched alot, would that be safe for daily driving or should i just go with 245.
    Sep 23 2009
    Racine wi
    235 or 245? Witch one would be better it can streach a little but I don't want it to be overkill. Because it's a daily driver.
    Apr 27 2009
    235 will be fine. I'm pretty sure you'll have to roll your front fenders regardless though.
    This is a 225/40 on an 18x9 wheel -----> http://www.tyrestretch.com/9_225_40_R18/
    So it'll obviously have less stretch than that, and that doesn't have very much.
    -Jeff
    Senior Member Three Rings Brian@rotiform's Avatar
    Nov 13 2009
    Westminster, CA
    Depends on the look you want. I've ran 255/35/18 on some 18x9s on my old b5 s4 if you want the motorsports/functional look. 225/40 or 235/40 is the standard fitment for B5 S4 18s.
    Sep 03 2009
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    245/35-18 is best, but might need a fenderlip roll depending on the wheel.. We don't have anything wider than an 18x8.5 that we guarantee to work, so the 9" may have its own issues.
    Sep 03 2009
    those rims on the rederwerks site look like they come staggered 18x8 f and 18x9 r both et35, and 100/112.
    Are yours both 18x9? 245s work nice on a 9" rim, but they are gonna rub....buy the 235s
    https://www.raderwerks.com/
    these are 8.5 wide same et35, and 235s......so you'd fit like these, but your rims aew 12.5mm wider. or 6.2mm more each side of centre. Luckily with the same et and same tire, it will fit nearly the same, only slightly stretch the tire....but the rim won't rub.
    2021 Suzuka RS6
    2020 Nardo RS3
    2018 Ibis R8 RWS
    Sep 23 2009
    Racine wi
    yea im gonna but 18x9s on front and back and i just bought 235/40/18 tires
    thanks everyone for your input.
    Dec 05 2007
    That is the tire size I was planning on running if I got 18x9 wheels.
