Originally Posted by
RichardsA4
Hmm... what he described was exactly the same thing I had happen. Light got dim and looked purple. I drove around for a month like that occasionly having the light flicker to full brightness than one day it just gave up completely. I bought and installed a new bulb... no light... new ballast and everything was back to normal.
I suggest removing both bulbs and switch them from right to left ect. See how that works. If the light is the same way on the same side then start lookin for a deal on a ballast.
Ya, tmrrw ill change the bulbs from left to right and see what happens. Tonight the 1 light started to flicker around and turn off a couple times while driving. I doubt its the ballast though.
vietxnam
Usually when a hid bulb gets older they color shift. When the bulb degrades the bulb changes then gets dimmer and dimmer and finally goes out.
Ya, thinking its still the bulb, its getting more purple/blue while one, and flickering a lot more, and then going off while driving.
Is there a DIY for removing the bulbs, or is it a pretty basic swap...
