Results 1 to 15 of 15
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Posi/Limited Slip
    Just wondering if anyone makes a LSD/Posi rear diff for the b6 quattro. I thought I remembered stasis making one but its not on their site.?
    Fill me in!
    - Caractere - BBS - Kamei - 034 - Stasis - Hotchkis - Stern - Forge - Apikol - Revo - Podi - RNSE - Bi-Xenon - Door Blades -
    If your gunna do it.. DO IT right!
    Aug 26 2005
    Re: Posi/Limited Slip
    I don't believe there is anything like that avalable, but you would want a Torsen diff anyway.
    Veteran Member Three Rings JustinCase's Avatar
    May 25 2007
    2013 A4, 2011 A4 Avant
    Scranton, Pa
    I think stasis does make a limited slip rear diff but it's something like $1500.
    -Justin
    2013 A4 Sedan
    2011 A4 Avant
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Not necessarily.. Sports car (SCCA) did a comparison some years ago. Depends on the use. For the rear diff, a clutch pack diff is nice for full on race conditions....
    I thought there was a different biased center diff tho? That would make a big difference and reduce the understeer.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Mar 13 2007
    1989 VW Jetta GLI Helios
    Stasis doesn't sell rear diffs anymore I tried to purchase one this summer. I was told that the company that was making them for stasis went under.
    Aug 26 2005
    Quote Originally Posted by Spinnetti View Post
    Thanks for that, I did not think of full race, I was assuming race/street mixed use.
    Mar 27 2005
    The Cold North
    Quote Originally Posted by vintagespin View Post
    intersting. I was told in October that they were no longer avaliable when i tried to order one from a STaSIS dealer. I wonder if 034 has an alternative source.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Diff type totally depends on vehicle, setup and use. To make a blanket statement that one is better than the other is a tad foolish...
    Having used a variety, I personally prefer a helical (torsen) diff. It just works....that and the science behind it is quite awesome.
    '11 Q7 TDI Prestige
    Function > Form
    Registered User Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Yeah, from what I heard, Stasis wasn't selling the rear diffs anymore.
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    I would love to know if the Sport Diff now available as an option on the B8 S4 and S5 can retrofit onto our cars. It's supposed to be a 100% mechanical piece, so we wouldn't have to worry about any electronics or software.
    USP CLUB MEMBER #34
    Oct 15 2006
    From a few to one...
    Arlington, VA
    Quote Originally Posted by CyberPMG View Post
    but if we swap it over, does that mean we have to disable EDL? isn't that tied into our ABS, ESP and other systems?
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1 ECU/TCU, APR Intake
    Nov 29 2007
    '06 Cayman S, '04 A4 3.0 USP, '85 UrQ
    Scottsdale, AZ
    If you're only trying to improve traction in a straight line, then a Torsen rear diff will probably work okay. However, if you're trying to improve traction out of corners, then you're much better off using a clutch-pack LSD instead, as the Torsen behaves exactly like an open diff when one wheel is in the air and I haven't yet seen a B6 A4 that doesn't lift its inside rear wheel under hard cornering...
    Nov 29 2007
    Scottsdale, AZ
    Quote Originally Posted by downhillracer View Post
    Stasis was originally selling slightly tweaked Porsche 944 LSDs made by Guard Transmission then switched to an overseas supplier. I have no idea whether they are or are not still selling these LSDs, but I know firsthand that a 944 LSD will fit inside a B5 rear diff housing with only minor modifications because I installed one in my B5 A4 1.8. I haven't opened my B6 A4 rear diff case yet to verify this, but as I believe Stasis used the same diff in both B5 and B6 apps, you should be able to use at least Guard's 944 diff and most likely the OEM one as well and live happily ever after...
