I recently threw a CEL and just had it scanned, came up misfires on all cylinders due to a bad Idle Air Check Valve. After letting the car idle rough for a few minutes the CEL started flashing, however after revving the motor the CEL went back to solid. Now, I can drive it and keep the light from flashing by putting the car into neutral and keeping the revs above 1k while stopped as to just not let the car idle. I believe the valve is stuck shut and I am getting too much fuel at idle causing the misfiring. All that being said, does anyone have a part number or know a place to order one from? I am getting ready to do a number if things on the car including the timing belt, fuel filter, steering rack among other things and this is just one more thing to add to the never ending list of fixes...the car is an '04 1.8tq tip with 79k on the clock. Thanks in advance!
-Trent
