Results 1 to 4 of 4
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    ABS and Traction Control lights come on under heavy boost
    Alright, well my ABS and traction control light have started coming on under full throttle in second gear or higher. It only does this some times though. It usually occurs on the first or second pull when I start driving it. But then on consecutive pulls after that it usually does not come on again. I do have a CEL but it's from not having 02 spacers. Any ideas what could be causing this?
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: ABS and Traction Control lights come on under heavy boost
    my car the esp light will come on under WOT if i don't turn off the ESP, you may have a wheel sensor starting to go bad
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Senior Member Three Rings Deep6ed's Avatar
    Mar 09 2009
    NoVa
    I've got the same thing.
    +1 on WSS
    Have it diagnosed, just havent fixed it yet.
    2013 TT RS Plus - APR Stage 1 - Nimbus Gray - Exclusive Interior
    2013 Allroad - APR E85 Stage 1 - Scuba Blue - Sport Interior
    Veteran Member Three Rings Jurjen's Avatar
    Sep 17 2006
    B5 S4
    North Vancouver, BC
    The only time I've those lights come on is when had a boost leak from a tear in my TBB.
    b5 s4
