Results 1 to 9 of 9
    Active Member Two Rings Corrupted's Avatar
    May 03 2009
    Palm Beach
    LED Tail Lights (Resistors/Load Balancers)
    Okay, so I have searched through the forums and I haven't got any firm answers. I had bought a pair of LED tail lights which i'm sure you've all seen or atleast read about and I've always heard about installing resistors, but what exactly are they, where do you buy them, what's a website to buy them from, any resistors will work? I searched throughout the site and through google yet there are no answers for "Resistors for Dummies" like myself. I did come across a website, here http://www.superbrightleds.com/cgi-b...rake-turn.html but there are 2 different resistors, which one do we need and are these the correct ones? I know a few others are having the same problem but all threads seem to end with the same question with no answers. I would really appreciate if someone could help me and those who would like to know the information as well. The "burnt out bulb" warning is driving me insane!
    The LED tail lights are these: (Image was found on Google)
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Re: LED Tail Lights (Resistors/Load Balancers)
    You are going to want the taillight resistor kit, that should fix the bulb out messages.
    I'm using the Tail light resistor kit from SuperBrightLEDS for my LED taillights in my B5 and it fixed that problem. Easy to install, you just need to find a place to mount the resistor (but remember the resistors will get hot so make sure it isn't touching anything flammable)
    ~Brian
    1998.5 A4 2.8QT
    Oct 22 2005
    Reppin the Mitten.
    Well here you go buddy.
    10 min job tops. Good luck.
    http://www.audizine.com/forum/showthread.php?t=90325
    May 03 2009
    Palm Beach
    Ahhh finally i'll be able to get this done!!! The write up is great. Seeing that I'm lazy as hell, I'm going to buy the 25w from SuperBrightLED and follow the directions of the write up. I appreciate the help guys! Let's just hope I'm smart enough to pull this off...ha
    Dec 11 2006
    Minnesota
    Quote Originally Posted by Corrupted View Post
    Probably not.........considering you need to 5 Watt 60 ohm resistors and not the 25 Watt 25 ohm resistors
    Just make sure you order the right ones
    GL!
    ~Brian
    1998.5 A4 2.8QT
    May 03 2009
    Palm Beach
    Quote Originally Posted by Silverstreak98 View Post
    GL!
    Do you mean the 6 Ohm, 50 Watt?
    Established Member Two Rings Young SS's Avatar
    Jul 10 2009
    95 Impala SS, Blk 04 A4 6speed
    Chicago, IL 60616
    I went with the 10 watt 100ohm resistors. No problem for the two months ive had them in. i went with LEDs in the reverse lights too and had to use the same size resistors.
    Senior Member Three Rings DarkW!sh's Avatar
    Dec 09 2007
    2007 AUDI A3(RETIRED) BMW 335i
    Los Angeles/Santa Cruz
    Love the pic of the tail lights... But those already have the resistors retro fitted... Like on the thread vinny posted...
    How do I know this.
    Those were my tail lights, and that's my pic hahaha
    Account Terminated Four Rings
    Feb 16 2009
    Ithaca New York
    bringing this back from dead sorry but I had some questions about resistors.
    We just installed 25w 6ohm into CREE LED back up lights on a B8 car which did not throw any codes but resistors got extremely hot. I wanted to see if anyone knew answer to this question. If I was to run smaller wattage like 10w how big my ohms would have to be? My CREE bulbs are 3w.
    Can i use 10w100ohms just like you guys used on your taillights?
