Results 1 to 6 of 6
    Junior Member Two Rings
    Jun 15 2009
    Chicago
    Flywheel/Pressure Plate bolt torque specs
    Just wondering if anyone has the flywheel and pressure plate bolt torque specs? The Wiki page has most of the other specs but not these... Any help is appreciated! Thanks
    Sep 12 2008
    South Central PA
    Re: Flywheel/Pressure Plate bolt torque specs
    gutentight
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Three Rings handyvorb's Avatar
    Jan 31 2009
    '04 S4, '95 Eagle Talon MSnS
    Huntsville, AL
    Dualmass Flywheel to Crankshaft: Replace bolts, Torque to 60 Nm + 90°
    Pressure Plate to Flywheel: Replace bolts, tighten all bolts in 1/4 turn increments to a final torque of 22 Nm plus an additional 90° turn.
    Cheers.
    Joel Baldridge
    Stage 4 Audi Technician (Master Guild Certified)
    Jun 15 2009
    Chicago
    Quote Originally Posted by handyvorb View Post
    Cheers.
    Thank you!
    Dec 02 2007
    corn powered b5
    duluth, mn
    just as an fyi, my bentley doesn't say an additional 1/4 turn for the pressure plate to flywheel. just says 18ft/lbs....
    my car is like my own personal universe, she's my drug and it only takes 12 bucks to fill her up.
    Jan 31 2009
    Huntsville, AL
    Those specs I posted are from the official Audi service information.
    Joel Baldridge
