Results 1 to 6 of 6
    Registered Member Two Rings
    Oct 20 2008
    2002 Audi A4 1.8T Quattro
    nj
    How to remove spark plug wire clips
    its about 25 degree out and when i attempt to push down on the spark wire clip on my 02 a4 1.8t the clip on the wires seems to snap and break off. Is there another way or removing these
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: How to remove spark plug wire clips
    I use a small flathead screwdriver and just lightly twist in the gap where the clip is until I hear the little click of the clip disengaging. You have to really baby it though or else the clips will break.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Oct 09 2008
    Not to my knowledge. You can try to just bypass the clip and muscle the harness off
    The Awesome™
    May 03 2008
    Orlando
    yeah - if the clips are already broken, you can just pull the connector off, but be careful since the wires and connector are probably pretty brittle - especially on an '02!
    Kevin W.
    Oct 20 2008
    nj
    o yea tried to use a small flathead and broke two off and salvaged the other two, these 02s really stink
    May 03 2008
    Orlando
    I just said that about the '02 because it's older and has had more time for engine heat to affect the plastic. Mine's an '03, and I have the same issues.
    Kevin W.
