Results 1 to 8 of 8
    Active Member One Ring tigerstyle's Avatar
    Jan 23 2010
    nottingham uk
    Run flat tyre? good or bad idea
    Hi guys
    When i bought my A4 from the dealer it came with standard Bridgestone tyres but recently i ve changed them to Bridgestone runflats all round. Now the steering seems heavier like if the tyres are underflatted. Size of tyres has nt changed all i ve done is gone from standard to runflat. Shall i just go back to standard tyres to solve the problem .Any ideas lads
    Veteran Member Four Rings ultra's Avatar
    Apr 12 2007
    13 Allroad
    San Antonio,TX
    Re: Run flat tyre? good or bad idea
    change it back , run flat tires are bad news. If you get a flat you will most likely damage the wheels as well which will be pretty expensive.
    pretty much every BMW(use run flats) lease return I see , work at an Audi dealership, needs new wheels and tires.
    Eurocode
    2013 Allroad Volcano Red, Eurocode goodies
    2018 SQ5 Florett Silver S-Sport package
    Veteran Member Two Rings ni8done's Avatar
    Mar 14 2004
    2010 G37, 2008 Lexus IS-F
    Had them on my last BMW and never again! the worst tire ride and comfort on the market! Needless to say if you get a simple nail in the tire, the tire is shot no fix available and u have to buy a whole new one. Also sidewalls are prone to bubbles. Went threw 3 sets on my 07 BMW coupe + 3 separate warranty claims where they replaced the tires!!
    2010 A4 S-Line Loaded...H&R Sport Springs Custom Exhaust from AMS Autowerks TinTed All Around 30%
    2008 Lexus IS-F Tein Drop Custom Exhaust 10mm spacers Jun-Tec roof spoiler
    2010 G37 XS
    Jan 23 2010
    nottingham uk
    Nice one lads i m going back to standard tyre these runflats are doing my head in i can feel every bump on the road plus you need arms the size of Arnold schwarzenegger to turn the steering wheel
    Veteran Member Three Rings CLEAR's Avatar
    Aug 28 2009
    2009 Audi A4 3.2Q Aruba Blue
    Pasadena, CA
    run flat ... -1 , noisier and cost to much for what they are, and not so good grip.
    graphic designer - photographer
    Sold : Ducati DESMOSEDICI D16RR
    Jun 14 2005
    Anaheim, CA
    it does go both ways, the driver feel for RFT's isn't as good as regular tires, but you don't need to worry so much about...well, getting a flat. It's really personal preference regarding which direction you want to go in.
    Brandon @ VMR Wheels
    Veteran Member Four Rings riegeraudi's Avatar
    Apr 16 2009
    Quote Originally Posted by VMRWheels View Post
    but you also have to worry about getting replacement runflats if say you're travelling and get a flat in a small town, then you have no spare and no place to get a runflat tire. I much always rather have a spare tire.
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    I've never had run-flats, but everything I've read makes it clear that the only advantage they have is in allowing you to drive with a tire puncture (and the weight savings from not having a spare). In every other way they are inferior to standard tires (cost, performance, road feel, noise, wear, etc). I don't get enough flats to even consider their one advantage as important.
    2009 A5 3.2 6MT | Brillant Black/Black | Prem | Nav | Tech | B&O
