Results 1 to 30 of 30
    Established Member Two Rings torquewrench's Avatar
    Jan 26 2009
    WA
    Cam follower - A possible root cause...
    Not related to my recent cam follower failure, I was randomly searching for some information on oil additives. During this search, I found some interesting information....
    The EPA mandated that domestic oil remove the additive ZDDP from their oil. What is ZDDP? ZDDP reduces the friction between parts (in particular camshaft/lifters) The change was due to the fact that it may have adverse affects on your CAT. It shouldn't have been a big deal since most newer engines utilize roller lifters on camshafts and such. However, we do NOT have a roller lifter on our HPFP.
    I don't think it's too far of a stretch to theorize that our FSI 2.0 engine testing was done with an engine oil that has ZDDP. Probably done around 2003. The engine surely passed durability testing. Now that there has been a change to the oil, we are getting premature cam follower wear. Debatable, but plausible.
    More info:
    http://www.macysgarage.com/myweb6/ZDDP.htm
    Senior Member Three Rings JohnUSMC's Avatar
    Jan 13 2009
    07 B7 A4 2.0T Quattro
    Dallas, TX
    Re: Cam follower - A possible root cause...
    I like where you are going with this...
    Maybe we can get some more clarification about Audi's testing of our 2.0TFSi engines and their relationship with this additive and EPA mandated change...
    Seems very plausible to me... we need to send this in to the Mythbusters!!
    --APR Stg 1 Full tune - RS4 Rear Sway - AWE exhaust - AWE Boost Gague - Dice iPod controller w/custom ashtray mount - Hardwired Passport X50 - Fly's V3 LEDs - LED Plate lights **
    ** In the works as of Dec 1 2010 - 034 HFC - APR HPFP - Fly's V4 LEDs - APR Stg 2+ tune--
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    ive heard this theory before. it makes perfect sense.
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Established Member Two Rings Mark16q's Avatar
    Jan 10 2010
    '08 Honda Fit, '10 Prius, '10 Civic EX
    CA
    Similar line of thought for the Lotus Elise and cam wear issues. I sold mine before it became a problem, but pretty catastrophic when things failed. Apparently the additive is nasty for emissons but vaguely recall that certain diesel grade oils had more of the additive.
    The more I think about this, the more it makes sense. the cam follower is pretty similar to a flat tappet design which zddp is designed to lubricate. The way around this is roller bearing which obviously Audi didn't do (do the B8's have a roller bearing follower?). zddp+ seems to get good reviews, and if you can find STP red bottle that has quite a bit of zddp in it.
    '10 135i 'vert 6mt, sold '09 A4 Quattro SE Ragtop tiptronic, '08 Honda Fit, '10 Prius, '10 Civic EX. Sold.......'95 Miata M Ed., '05 Elise, '04 S2000, '01 Miata LE
    Veteran Member Three Rings illegitimus's Avatar
    Mar 17 2009
    2006 B7 A4 Quattro Tip S-line
    Boston, MA
    interesting theory and quite possibly the cause of the problem when coupled with the obvious design flaw. I don't know what everyone considers as worse: destroyed cat or the cam. I think, I'd take the former. Unfortunately, we have no say-so in the matter. EPA had decided this for us.
    Sep 27 2008
    Phoenix
    Where can I purchase some ZDDP to put into my oil?
    Jan 26 2009
    WA
    Quote Originally Posted by illegitimus View Post
    Don't tell the EPA - I'm choosing. I plan to put the additive back in my oil and use ZDDP additive. If my CAT goes, then so be it. It's much easier to replace the CAT than the engine. Been there, done that.
    http://www.audizine.com/forum/showthread.php?t=335457
    Jan 26 2009
    WA
    Quote Originally Posted by wootwoot View Post
    Found it here. I'm sure there are other sites also.
    http://www.eastwood.com/zddp-oil-additive.html
    Veteran Member Four Rings rxer311's Avatar
    Dec 27 2009
    Nissan Rouge
    Mount Joy, Pa
    Interesting...
    If I helped you...Rep me!
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Just run a tp and you dont have to worry about your cat.
    Thanks for the info.
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Veteran Member Four Rings Sly Raskal's Avatar
    Jan 22 2007
    Fontana, CA
    Can any harm come from using this additive?
    -Anil
    2019 A4 Sedan, Nardo Gray, 45TFSI, Prestige Plus, S-Line, Quattro, Black-Optic, PPF, Ceramic Paint Coating, Ceramic Tint, Audi Black Door Handle Kit
    Dec 11 2007
    San Diego, CA
    From what the OP said just your cat. Not sure if it does anything else. Thats a good enough reason to take it out of the oil though.
    FRRG Southern Ring
    Dec 11 2007
    San Diego, CA
    I just changed my oil the other day. Thinking of getting a bottle and trying it out.
    Going to Autozone in a lil while to see how much ZDDP that STP red bottle has in it.
    FRRG Southern Ring
    Jan 22 2007
    Fontana, CA
    Quote Originally Posted by Sal_B7 View Post
    If it ruins your cat, i'd much rather pay ~$1K to swap out a cat down the road than have to deal with engine problems.
    -Anil
    Dec 11 2007
    San Diego, CA
    oh of course. I feel the same way. Im running a TP so i dont have to worry about that.
    My concern for us Cali folks is how it would do on a smog test. You know how strict our emmission laws are.
    FRRG Southern Ring
    Mar 17 2009
    Boston, MA
    My concern for us Cali folks is how it would do on a smog test. You know how strict our emission laws are.
    how are you passing emissions with the TP now?
    Dec 11 2007
    San Diego, CA
    Im not, havent had to do a smog check yet.
    FRRG Southern Ring
    Dec 11 2007
    San Diego, CA
    A friend of mine knows a guy who knows a guy. So when its time ill go that route.
    FRRG Southern Ring
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    ZDDP... seems like a plausible explanation. Googling it and notice that there's a rash of posts around 2006 and onwards about premature wear on cams and lobes, so it's quite possible that the timing around when ZDDP was just being eliminated and when Audi started to sell the 2.0Ts goes hand-in-hand with the cam follower wearing.
    Mike
    Mar 17 2009
    Boston, MA
    that works...
    Mar 17 2009
    Boston, MA
    so, how does everyone feels about throwing a 4oz of this ZDDP additive into the oil on the oil change? I am considering on buying a bottle to try. of course, I won't know the difference unless my exhaust starts smelling of rotten eggs.
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    Would anyone consider this as another alternative?
    http://www.tufoil.com/cars.html
    I used Tufoil on my 1997 Jetta VR6 for close to 6 years. I sold the car with over 150,000 miles on it and never had any engine issues. The car pulled strong up to the day I sold it. Not sure if the Tufoil had anything to do with it, but I think it didn't hurt. I'm considering it for the A4 and am now thinking, because of this post, it may help with the cam follower wear issue. Thoughts?
    Veteran Member Four Rings groundround's Avatar
    Jun 19 2009
    17 ram 1500
    Hartford CT
    from Wikipedia !! and if it's not lead chances are it can be reversed under heavy load or maybe long drive by melting it away? what i take from it.
    Damage
    [edit] Poisoning
    Catalyst poisoning occurs when the catalytic converter is exposed to exhaust containing substances that coat the working surfaces, encapsulating the catalyst so that it cannot contact and treat the exhaust. The most notable contaminant is lead, so vehicles equipped with catalytic converters can only be run on unleaded gasoline. Other common catalyst poisons include manganese primarily from the gasoline additive MMT, and silicon which can enter the exhaust stream if the engine has a leak allowing coolant into the combustion chamber. Phosphorus is another catalyst contaminant. Although phosphorus is no longer used in gasoline, it (and zinc, another low-level catalyst contaminant) was until recently widely used in engine oil antiwear additives such as ZDDP. Beginning in 2006, a rapid phaseout of ZDDP in engine oils was begun.
    Depending on the contaminant, catalyst poisoning can sometimes be reversed by running the engine under a very heavy load for an extended period of time. The increased exhaust temperature can sometimes liquefy or sublimate the contaminant, removing it from the catalytic surface. However, removal of lead deposits in this manner is usually not possible due to lead's high boiling point.
    Dec 11 2007
    San Diego, CA
    I was watching a episode of Horsepower TV and the main guy was talking about ZDDP. The same bottle that was mentioned here. He just says how it would protect againts cam wear and they put it in the engine they were building.
    I remember Arin from APR posting some pics of the cam followers that their motorsports team were using. For the beatdown those cars take the followers were in pretty good condition. He said they used Motul motor oil.
    Im still thinking about buying that bottle off ZDDP and putting it in my car. Wish i would have known about this like a week ago before i changed my oil. Ill still order the 3 pack and see how my follower is after these next 5K miles.
    FRRG Southern Ring
    Jun 19 2009
    17 ram 1500
    Hartford CT
    I am going to order some to. My follower just came in the mail and is the first time i am checking it 81,000 miles . What the hell
    Mar 12 2008
    New York
    ^^^^^^ hope for the best :/
    Mar 17 2009
    Boston, MA
    i am due for an oil change in about another 500 miles and I just swapped my cam follower last weekend. this might be the right time to try some of that ZDDP stuff.
    Active Member Two Rings bishop13's Avatar
    Feb 28 2009
    13 Ford Focus ST / 97 Toyota Camry
    Burbank, CA
    Quote Originally Posted by groundround View Post
    Well, hell, isn't that we're told to do to combat the carbon build up issue anyway?
    Dec 11 2007
    San Diego, CA
    That and some 44K!
    I bought some STP red bottle from Kragen and it says it has "ZDDP anti wear agents."
    Not sure how much of that it has in it but we will see how it goes.
    FRRG Southern Ring
    Dec 11 2007
    San Diego, CA
    I just added that STP red bottle and that stuff is thick!!! Its like the consistency of honey.
    FRRG Southern Ring
