Results 1 to 8 of 8
    Active Member Two Rings ksatan's Avatar
    Jan 15 2010
    Moscow, Russia
    Question Test pipe and downpipe? Difference?
    Hi.
    Guys, I've tried to search but haven't found. Can anyone explain what's the difference between test pipe and downpipe?
    Dec 06 2007
    Re: Test pipe and downpipe? Difference?
    testpipe replaces your catalytic converter with a straight pipe.
    The downpipe is the pipe that goes from the cat down to the exhaust.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Some places sell replacement/aftermarket downpipes which replaces the cat as well, to make a downpipe-testpipe combo, which is listed as just a downpipe.
    Established Member Two Rings DasValet's Avatar
    Nov 08 2009
    Morgantownish
    I've having mine set up with a turbo-back set of pipes, with a resonator. The thing is, I'm not real sure what a resonator is. Anyone clear that up for my dumb ass?
    R135
      246
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    Quote Originally Posted by DasValet View Post
    http://www.magnaflow.com/02product/u...sp?shape=Round
    Resonator
    The muffler alone cannot always quiet all of the engine noise. Many car exhaust systems also include a resonator which is like a mini muffler. They are usually straight pipes filled with sound muffling materials. The resonator can be either before of after the muffler in the exhaust system
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    to help more... the test pipe replaces the stock cat converter. It is a straight pipe that deletes the cat. Helps the turbo breath more, spool faster.
    Downpipe also helps turbo breath more... it is the part that is attached after the cat or testpipe that goes down to the exhaust.
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Aug 17 2009
    Pittsburgh
    a resonator is a muffler. it is usually packed with fiberglass wick rather than baffled like a standard muffler. it will quiet the sound usually 1-15Db, depending on how much and the quality of the wick. Ebay mufflers for example have cheap wick that isn't packed very well, so after a while you get a tinny rattle from the resonator. dynomax or cherrybomb or apexi, although a big difference in price, are all equal in quality and will last a LONG time without the wick coming apart and ruining the effect of the resonator.
    Nov 08 2009
    Morgantownish
    Awesome. Hope it makes my car sound good.
    R135
      246
