Results 1 to 24 of 24
    Registered Member One Ring slip_'s Avatar
    Jan 29 2010
    Oslo, Norway
    Xenon flickering (video)
    Hello everyone!
    I'm having a problem with the drivers side xenon headlamp. Some days it lights up just fine, but now and then it gets these "flicker-attacks", like seen in this video:
    http://www.youtube.com/watch?v=7sMnScTiN5U
    What's more likely - the bulb or the ballast failing?
    What type of bulbs do I need if I need to order new ones? D1S, like these: http://www.suvlights.com/index.php?cPath=25_50_32?
    Regards,
    slip_
    Active Member Four Rings SEXICN's Avatar
    May 20 2004
    More cars
    Never Land Ranch
    Re: Xenon flickering (video)
    bulb going out. take out the right bulb and put it in the right and see if it still flickers that will show you if it's the bulb or ballast
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    I had the exact same problem, especially as the car gets warm. Typically a flickering issue is in the ballast and NOT the bulb. The D1S using an internal ignitor, which is like lighting a stove--it simply needs to ignite the ONCE, and a steady stream of power should be supplied by the ballast. What I'm trying to say is, once the bulb is ignited and lit, the problem is no longer in the ignitor.
    The best way to diagnose is to swap bulbs/ballasts left-to-right to see if the problem persists.
    For me, the problem started with the headlamps flickering occasionally while driving, which was almost unnoticeable...to where it would flicker for a few seconds at a time, to then flickering and completely shutting off. Turning the switch off and back on should reignite the bulb, in which it will start flickering again. This issue drove me insane for a few weeks, but in the early pre-death cycle of the ballast, it was difficult to diagnose as the issue was sporadic as it went away as I got home.
    Dec 19 2009
    Liege/Belgique
    I had the same problem and i bought new D1S bulbs ... 90$ is not the end ....
    Oct 16 2008
    South Florida - Ft Lauderdale
    Replace the bulb
    Phil
    Veteran Member Three Rings Stea1th's Avatar
    Aug 25 2009
    New York
    I had the same exact issue. it's the bulb.
    I went on ebay and bought 2 for 100 bucks.
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Here's another +1 to bulbs. Bought McCulloch 3000k replacement D1S bulbs. No more flicker.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Jan 29 2010
    Oslo, Norway
    Thanks for the reply people. I'll try replacing the bulbs first, and take it from there :)
    Senior Member Three Rings pyrobecks's Avatar
    Oct 05 2006
    '06 A4 2.0TQ Prem/S-Line
    SoCal - OC
    Not to hijack this thread, but I have a similar (not as pronounced) problem with a slight flicker when I go over bumps while driving. I can replicate it easily when changing lanes on the freeway, the cat's eyes make the bulb flicker ever so slightly.
    Any ideas, bulb or ballast?
    ~ pyrobecks
    06 A4 2.0T Quattro Tip | Premium | DTM
    Stasis SS's > RS4 Rear Sway > VM Onyx Black 19” RS4 Reps > Black Optic DTM Grill >
    Smoked Corner and Side Markers > Audi Sport Floor Mats > Euro OEM Clear Corner Xenon's > VAGged
    Jan 29 2010
    Oslo, Norway
    Quote Originally Posted by pyrobecks View Post
    No problem:)
    OT: Will these fit my car?
    Aug 18 2009
    la
    just replaced my bulbs and issue resolved was getting dipped headlight on both L and R sides.
    Dec 25 2007
    '06 A4, 08 R6s
    Quote Originally Posted by slip_ View Post
    No problem:)
    Yes.
    2008 R6s
    Sep 26 2008
    B7 A4 2.0T Dolphin Grey
    Brampton, Ontario
    stupid stock d1s bulbs ! i had the same problem. thank god someone local let go a pair of D1s for 20 bux ! it was the bulbs for me at least. now the funny thing is. i gave my flickering pair to a friend with a b6 and hes been running them for a week no flickering or anything,
    Aug 25 2009
    New York
    mine would sometimes not flicker for weeks, then all of a sudden flicker badly
    for a few days to the point where they would shut off.
    It wasn't constant, which made me not want to fix them right away.
    Feb 18 2004
    Los Angeles, CA
    Quote Originally Posted by inphamous_A4 View Post
    It's the ballasts. I would change the bulbs, and "thought" my flickering problem was surprisingly solved. But then it would start flickering again in a few weeks. After 3 pairs of bulbs, I replaced the ballast and problem solved. Now with the new ballast, I used all the old bulbs that I 'thought' were bad, and they work flawlessly.
    Veteran Member Three Rings Winners Eat Pho's Avatar
    May 17 2008
    Alright, so I'm now having this problem with seemingly the rest of the world, but only on the drivers side for now. Over time, it's getting worse, with more frequent and longer flickering. So, it sounds like the ballast is the first thing to try and replace? How much is that, and do you have a part no. please?
    Oct 16 2008
    Start by the cheapest solution: THE BULB
    Phil
    Aug 25 2009
    New York
    Phil
    Cosign
    Veteran Member Four Rings D0lphinGrey's Avatar
    May 31 2007
    B7 2.0TQ S_line
    Sydney
    Quote Originally Posted by Stea1th View Post
    Exactly like mine. It hasn't been flickering for the last 3 weeks.
    B7 A4 GT28
    May 17 2008
    Alright, this leads me to the next question. I'm not well versed about the different bulbs - I think different temperatures put out a different light? What's the stock temperature I'm looking for? Is this a good time to replace both to get a different fresh hue?
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    Quote Originally Posted by Winners Eat Pho View Post
    stock is 4300k.. i wouldn't go over 5k. and yes, replace both.
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Feb 28 2010
    pennsylvania
    my flickering is horrible at this point as well. if i were to get a new ballast(s) where would i get one from? oem is way too expensive
    Established Member Three Rings b7kevin's Avatar
    Jan 04 2011
    East Haddam, CT
    Incorrect after much research TRUE oem color is 4150k
    2006 A4 Brilliant Black 6MT
    - Revo Stage 2+ - AWE HPFP - ST Coils - K&N - 034 TIP - Newsouth Vent Gauge - Neuspeed Snub - OEM DV Upgrade - E-Code test pipe - AWE Quad tip - s4 rear valance - de-badged - vag'd -
    -Wake up an address the biggest issue of our freedom. National DEBT.
    Oct 16 2008
    Quote Originally Posted by adwatter View Post
    Still these, even used, are expensive
    phil
