Coaxial speakers have a built in tweeter (obviously), so if you go that route it would be in your best interest to unhook the OEM tweeter and not plan on ever using any other tweeter except for the one on the Coax speaker. I would advise against it anyway, as it will kill the soundstage.
Here is what I would recommend, as an installer of 10+ years & a pretty big SQ person.
1. Replace the oem radio. A quality aftermarket radio will make a huge difference, because it will be sending a much stronger & cleaner signal to the Bose amp, which will result in an equally cleaner signal reaching the speakers. Problem solved. It will also open up your options for sound tuning, further increasing the sound improvement.
2. Replace the Bose amp. The next weakest link in the system is the Bose amp, and the problem here would be due to not having enough power. Bypassing with an aftermarket amp is a little complicated, but very doable and without loosing any speakers in the process. After this you will have a very clean & VERY loud system, much clearer & much louder than OEM was.
3. Replacing speakers. At this point the speakers are now the only weakest link in the system. After this you will have a system FAR superior to the OEM in every way.
Why in that order?
1. OEM radios are not that great, and at high volume the signals are weak & get very muddy. Ish starts clipping & distorting, and the amp will play whatever signal it gets, regardless of clarity. Amp & speakers get a bad rap for something caused by the deck.
At this point the system will sound noticeably better than all OEM did.
2. It doesnt take uber expensive speakers to get incredible sound. The Bose speakers are a great starting platform, they can play clean & loud, and have a great sound to them. With a clean & powerful source (radio), the only other reason why the speakers would sound "muddy" would be because the Bose amp just cant keep up & more power is needed. Replacing the Bose amp requires either a new radio or something along the lines of the JL clean sweep, which is a waste of money UNLESS you have no other choice but to keep the oem radio.
3. Now you are just being incredibly picky, but luckily upgrading the speakers now is a simple choice because the aftermarket amp opens up a world of options.
& thanks for the pos rep.
