Results 1 to 10 of 10
    Jan 21 2010
    Virginia
    Missing OBD port?
    Hey I took my S4 in to get it checked out for the check light light and the guy says he can't find the OBD plug so I look and sure enough I didn't see one either... anyone know why? anyone else had this problem?
    If you cant find something to live for, you better find something to die for.
    2pac
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Re: Missing OBD port?
    http://www.ross-tech.com/vag-com/car...ions/a4s4.html
    Under Dash -or-
    Inside Rear Ashtray
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Senior Member Three Rings lukeag25's Avatar
    Jul 02 2009
    B5 S4,V8 S-10, 12v CUMMINS
    Denver
    Where you looking? It's either to the left and under the steering wheel, or behind the center console near the ashtray.
    Stg3 B5 S4
    Jan 29 2007
    08 S4 00 S4
    MD
    It may have been pushed back up into the lower dash portion where it mounts.
    08 S4- Stock SOLD
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    I was just thinking about this the other day, it is possible that the clip that holds the OBDII port on the knee bolster may have broken and then would be up under the dash, there are a few hidden screws on the knee bolster, take those off and see if it was pushed up underneath the dash.
    Dec 30 2009
    gah, you beat me!
    Jan 21 2010
    Virginia
    I was looking to the left next to the door under the steering wheel and there is a whole but no port ill check the rear ashtray
    2pac
    Jan 21 2010
    Virginia
    ok so I checked the rear ash tray for the OBD port and there is the plug where the OBD plugs in but it looks like its just a blank surface at the bottom if you know what I mean is that what its supposed to be like?
    2pac
    Jan 29 2007
    08 S4 00 S4
    MD
    That rear port was used on early A4 models, never on an S4 I don't believe. I think yours is stuck up under the knee bolster.
    08 S4- Stock SOLD
    Jan 21 2010
    Virginia
    oh ok, I thought that was it since it had a check engine light imprint on it but guess not
    thanks for the help ill pull the knee bolster tommorrow and search for it
    2pac
