Results 1 to 30 of 30
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Rear Side Window Defroster
    Are the rear side window defrosters supposed to come on when you have the rear defroster activated from the climate control? My windows were fogged up on my car today for the first time so I hit the rear defroster. The rear window worked fine but the two side cargo area windows didn't look like they were doing anything.
    Is there another button, is this a typical avant problem area, or am I just straight up broken?
    thanks!
    Established Member Two Rings j_sonel's Avatar
    Jan 18 2008
    '06 A6 Avant 3.2Q, '06 A4 Avant 2.0TQM
    Chapel Hill, NC
    Re: Rear Side Window Defroster
    Quote Originally Posted by PNW Avant View Post
    thanks!
    Mine don't work either, and my guess is that they're supposed to come on with the rear defroster. I can see visible breaks in the defrost lines, probably due to the previous owner having tint and then removing it.
    '91 Coupe Quattro - 034, H&R, Autocraft, Keskin - S2 look alike
    '06 A4 Avant 2.0T Quattro Manual
    '12 Touareg TDI Lux
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Thanks for the response. I'll inspect mine for breaks tonight
    Jan 24 2008
    West Coast
    I'm thinking you have a broken line. Mine work fine - come on when the rear is on.
    Moderator
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    That's an antenna
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Jan 18 2008
    Chapel Hill, NC
    Quote Originally Posted by MYDWAGON View Post
    That's an antenna
    For what? The radio antenna is on the roof.
    '12 Touareg TDI Lux
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    That's an antenna
    Correct. The only window w/ defrost is the tailgate window.
    As an FYI, not all B6s have a roof antenna. The earlier years didn't come w/ one. They came out in '04 when satellite radio became an option. They would all get the roof antenna regardless whether or not the car was equipped w/ satellite radio.
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Haha, ok, I'm thoroughly confused now.
    I have a roof antenna, and I also have defroster looking things on the rear windows. If I don't have Sat radio, is the roof antenna functional, or even connected to anything?
    Pretty peculiar looking antennas on the windows if you ask me. But, I'm hoping that's the case cause that would mean I wouldn't have to fix anything. I'll have to more closely inspect them tonight I guess!
    SoCal...you must be on crack!
    Jan 24 2008
    West Coast
    Apparently. I'll take pictures when I get home.
    Moderator
    Aug 18 2009
    A Unicorn
    Portland, OR
    As far as I know, the sharkfin antenna on the roof is SAT only. Even if you don't have the satellite module, most of our cars are prewired for it.
    There is in fact radio antennae in the side windows, however I was under the impression that there was also a defroster. So I'm not entirely sure on that aspect of it.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I can't imagine why they would put antenna in the middle of the windows when they could just wire them around the perimeter to be out of sight.
    My intuition says there are both. I've seen the same thing on other makes/models of wagons. Looking forward to finding out later!
    SoCal...maybe you are clean afterall...
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Just got done workin on the car for a bit. I checked out the lines in the back windows briefly. They looked like defrosters to me!
    Jan 24 2008
    West Coast
    Mine are defrosters too...didn't take a pic, but I will if people MUST have them! lol
    There's no way that Audi would put antenna on both sides - both windows - and my radio reception could still be so crappy!
    Apparently, I'm not on too much crack after all, PNW!
    Moderator
    Established Member Two Rings Subyroo651's Avatar
    Jul 12 2009
    04' A4 Avant 1.8T
    Chicago(Suburbs), IL
    I say post pics just to silence any skeptics...
    Than is used only in comparisons.
    Everything else is Then.
    Brake = Stopping or slowing
    Break = Something is Broken or You're resting a few minutes.
    Jan 24 2008
    West Coast
    Quote Originally Posted by Subyroo651 View Post
    LOL - fair enough.
    Here you guys go. This is the same on both sides. Definitely not antennas.
    Moderator
    Jul 12 2009
    04' A4 Avant 1.8T
    Hahah That was dumb, I though you meant you actually had pics showing the frost being melted. I could've looked at my car for those shots
    for the Recaros though
    San Francisco, CA
    That pattern is kind of interesting for a defrost... don't you think?
    Until I see pics of the defrosted side windows, to me these are antennas. As for your crappy FM/AM reception, your AM/FM reception module mighty be cracked. Apparently it's a common feature on these...
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I dont see why the antenna would be different for avants. There's no antenna in the sedan's rear quarter window...
    The lines are the same material and same thickness as the rear defroster. The pattern would be to get the most area defrosted as possible in the window.
    San Francisco, CA
    So then I guess your side windows defrosters are broken then.
    Jul 12 2009
    04' A4 Avant 1.8T
    Could we maybe find something in the Bentley manual that can possibly prove or dis prove this idea?
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Quote Originally Posted by AvanTTix View Post
    Dang.
    I checked the manual last night to see if there were seperate fuses but it looks like they run on the same one. Then again, the manual isn't always avant specific.
    Veteran Member Three Rings Mezzer's Avatar
    May 23 2008
    19 SQ5 & 08 RS4
    Gas station
    I think that maybe the car has to be equipped with the cold weather package in order to have the side window defrosters hooked up. I know my car doesn't have the c/w package and they don't work.
    Not fact but just a thought.
    Old enough to know better... Young enough to do it again, just getting harder to recover.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    That's beacause it's on the rear window instead on a sedan.
    They are not defrosters kids. That's why not a single person in this thread has ever seen them "work".
    -Darrick
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Quote Originally Posted by Mezzer View Post
    Not defrosters - they are terrestrial AM/FM radio antenna. The only thing your roof antenna is good for is nav and satellite radio (OEM).
    FTR, the cold weather package is heated driver and passenger seat and the rear seat center armrest with a ski bag.
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by MikeWire View Post
    I think that's only true on the B6. For the B7, front heated seats come as part of the premium package, and the cold weather package adds heated rears and the ski bag.
    San Francisco, CA
    Quote Originally Posted by Capt. Obvious View Post
    Well some of us never expected to see "them" work either...
    Mar 08 2007
    Air and water
    SATX
    Correct. I was speaking of the B6, not the B7.
    To add to the mix, the B6 2002 had heated rear seats, but no other year did.
    +rep for good info.
    -Mike
    @countdowngarage
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    What an ugly set of antennae! My intuition fails me again. AvanTTix, I should have listened to you in the first place!
    At least now I know they ain't broke!
    Veteran Member Two Rings
    Mar 02 2004
    2001 Audi A4 Avant
    Upstate NY
    Speaking for the B5, the rear window is an antenna and there is an antenna on the roof. The car uses both to get a better signal.
    Current:
    2001 Audi A4 Avant, Stage 3 (17 years, 120K)
    Sold:
    1999 Audi A6 Avant, Worn (3 years, 134K)
    1996 Audi A6 Avant (5 years, 155K)
    *(Owned, Odometer)
    Veteran Member Four Rings bblume's Avatar
    Dec 20 2007
    06 avant. 92 Gti. 07 X3. 14 Sq5
    Colorado
    That's an antenna
    this^^^
    14 Sq5
    02 Eurovan
    04 DBP R32:.
    92 Gti-TDi 1Z (sold)
    06 AVANT S-line QMT6 (Just sold it!!)
    07 BMW X3 (given to the in-laws
