Results 1 to 8 of 8
    Established Member Two Rings winreboot's Avatar
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    Headlight warning buzzer
    When I got my 04 A4 avant from day 1 I notice that the buzzer was not working or didn't existed on my model. I just thought that Audi would not skip on such a basic feature. I try to remember to turn my lights off but I forget time to time and just want to have that as my neighbor have A4 and he said he does have the buzzer.
    I search and some say it's the switch in the door itself, but my light in door and dim interior lights work fine. When I turn the car on I don't hear any initial buzzing, if there should be any.. like seat belts etc..
    Does anyone know what can it be? Maybe the buzzer itself?
    Thanks,
    Dave
    Veteran Member Four Rings Synthetik's Avatar
    Aug 26 2009
    03 A4 3.0L V6 04 YZF600R
    Colorado
    Re: Headlight warning buzzer
    Maybe a VagCom thing... I'm not sure.
    15% Tint | USP Front End | Graphite Stockers | "Custom" Grills | DICE Ipod | Hardwired Garmin | Alpine Amp w/ 12" Sub | NEXT PROJECT: RS4 Sway Bar
    The B6 A4 DIY Master List
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Yeah it was probably turned off with a VagCom
    Veteran Member Three Rings sxman69's Avatar
    Oct 04 2009
    08 CRF250R, BLKMRKT Mob, Giant Glory DH
    Auburn, CA
    nope... no buzzer here either. its been good training tho to always remember to manually turn off your lights. I just wish we got the "Auto" (a.k.a. dummy) feature on our gen.
    -Sam
    New: 2009 Mazdaspeed 3 GT
    SOLD!!!! Staggared AMG Monoblock // Podi // Magnaflow // Forge // Kicker // Kenwood // JHM stud conversion // Tint //15mm H&R spacers // Hardwired Passport 8500 X50 // 034 Wiring Harness // Hawk HPS // 034 Blockoff Plate // MKIV Euro Switch
    Sep 13 2008
    Western Chicago Burbs
    mine buzzes
    Oct 04 2009
    Auburn, CA
    maybe its a 3.0 thing?
    -Sam
    Apr 13 2009
    2002 A4 3.0Q tiptronic
    Peru, MA
    My 02 3.0 bings when I start it for the seatbelt chime and bings if you open the door with the headlights on. Likely its been turned off wiht a VAG-COM by a prior owner.
    In the old days we used to reach up under the dash and pull the buzzer out of the socket...now you have to reprogram the computer.
    Jan 06 2010
    A6 TDI, Q7 4M
    NE PA
    Good info, if this could be turn on/off with vagcom then maybe the owner before me turn this off, if this is possible. That would be the only option that would make sense. Or the buzzer was removed..
    Have the cable and will linkup my laptop to mess with it, but I'm lost as to where should I go and look in vagcom and if I find it how would I change it?
    Ross, has online DEMO and the menus work to browse around, using this where would it be hidden under?
    http://www.ross-tech.com/vcds/tour/scm_screen.html
    Thanks,
    Dave
