Results 1 to 26 of 26
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Clutch switch for ignition???
    Hey I've been having a minor problem and I have a good idea what the problem is but looking for some info.
    When I go to start the car sometimes (it is a 6 spd manual) I turn the key and you have to push clutch in so engine turns over. Well sometimes the car wont turn over.
    It acts like I didnt push clutch in and does nothing. If I let clutch out and push back in then the engine will start turning over and car will start.
    Usually I just need to either let clutch out and push it back in, or if I turn key to off and then try starting it again it will work.
    Now I know there is a safety type switch on the clutch to prevent you from just turning the key and starting so you dont jolt forward if car is in gear.
    So I'm guessing this safety switch might be loose, faulty or sticky and isnt popping out when you push the clutch in.
    Has anyone had issue with this switch? Also I want to say that my cruise works perfect and thought there must be two switches on clutch one for cruise and one for ignition cut out so it doesnt turn over if clutch not pushed in. (Or there is one switch that works as both but maybe that isnt the case) Judging by problem I'm thinking there must be two switches.
    if you have had a simular problem or have seen it, how much is switch? Where exactly is it located? Hard to replace?
    I tried looking for a few minutes last night but couldnt see much because of plastic insulation cover hiding everything under dash. I will take that off tonight and look closer.
    Thoughts?
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Re: Clutch switch for ignition???
    there is an actual plunger down there that gets depressed when you put the clutch to the ground. You can fool the car into thinking its always down. This can throw a soft code (aka won't throw a CEL) but it over-rides the whole "put the clutch down to start the car" need.
    Be advised it does defeat a safety feature though.
    There are 2 ways to do this. Zip tie the actual plunger down or rewire the unit to bypass the plunger.
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Veteran Member Three Rings s4andtls's Avatar
    Jul 14 2009
    Ma.
    I remember last year mine acted up like that for 9 months or so and after replacing it I've never had a problem. So in my case it was a intermittent problem and not just a fail/work scenario.
    605.2 Brad tuning
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Mine is intermitant too. I'm going to look at the plunger and see what I can find.
    It does how ever seem to be getting worse where I have to play with it more before it will get started.
    Feb 07 2008
    The boonies, near Seattle
    There are two switches at the top of your clutch, one for the cruise control and the other for the start mechanism.
    The one you'll want to bypass is the top one if I remember correctly. The easiest way to do it is to strip both wires, twist them together, wrap them in electrical tape and then put a zip tie around it tightly.
    Obviously, your car will start in gear now, so be cautious.
    -dre
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    this is the way I've done it in the past and, IMO, the better way to do it.
    My WTB List:
    KNaudi's story
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    That makes sense you can hotwire and bypass the switch but I guess I have better piece of mind for my front and rear bumpers if I leave it in there. (for when my wify drives the car.)
    Anyway does anyone know the part number for the switch and what it actually is called? (MHolme this is where you post with part number and picture of the part)
    I still want to check it to make sure its really defective or if it is loose or sticky and just needs to be played with a little. I am thinking it is just getting wore out though.
    Thanks for all the replies though.
    Scott
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I wanted to update this thread. I believe I fixed the problem today finally. Well I didnt do anything about it until today when I changed oil and figured I should take some time instead of have to fidget with trying keep pushing in clutch and messing with key when it wouldnt start.
    I took off the kick pannel (3 - 8 mm screws I believe)
    I then had nice view to the clutch, brake and gas pedals and saw that there are 1 cruise control switch for each brake and clutch (which is what I thought) Then I found the clutch safety switch as shown below by arrow and also you see the plug in for it behind one of the cruise witches (actually one end is behind it, the other is in front of it - I had it unplugged in this picture)
    Here is a close up of clutch safetly switch
    here is close up of clutch safety switch plugin (this is when it was plugged together)
    I saw the switch was fastened tight so figured it was just wearing out so decided right now easiest way to fix this is hot wire it. So I unplugged toe electrical connetor and put a paperclip in the connection so it hotwired them together as shown below
    Since doing this the car has started flawlessly. But then again its only been a few hours. So I'm going to leave it like this for a little while to make sure I dont see the problem anymore. But I am confident this is what was causing my problem.
    I hear others have had this too so hope this helps.
    Now I dont plan to keep this permanently this way because it does allow the possibility of turning key and lunging forward if in gear and clutch not pressed in. What I plan to do now is leave car in neutral and have e brake on and just get in habit of leaving car parked like that so I dont have to worry about forgetting or having problems.
    If anyone knows this part number that would be great. Just so I can price out what this switch costs or what the real name for the switch is.
    Thanks
    Please forgive my grammar and spelling its almost 1am and I am tired. :)
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    thanks for the pictures. I've done this in the past and have struggled to explain what people should look for because I never took pictures. Looks pretty much exactly the same as to what I did.
    My WTB List:
    KNaudi's story
    Senior Member Three Rings lukeag25's Avatar
    Jul 02 2009
    B5 S4,V8 S-10, 12v CUMMINS
    Denver
    Clutch Pedal Position switch, F194 (If I recall). The bracket the switch is sitting on is adjustable, sometimes the switch isn't being depressed all the way.
    Stg3 B5 S4
    Senior Member Two Rings madman1234509's Avatar
    Mar 20 2009
    2002 A6 2.7t 6mt
    mayfield ny
    try adjusting the bracket as said above. I had this problem for about 7 months with my car and decided id finally try to fix it. Ordered the switch from ecstuning, but when i got up under it to check it out i adjusted it and it never happened again. So try adjusting it first, if it doesnt work I have the switch brand new from ecs that i never put on my car, just pay for shipping and you can have it. Its most likely the exact same thing as your model cars switch, seems like a pretty generic part. Pm me if you want it
    C5 Union
    Vast Stage2+
    (SOLD) '02 a6 black sport pkg 6MT, EVOMs intake, Custom 3" DPs, Custom 2.5" w/ borla mufflers & test pipes, RS4 clutch and PP, Samco TBB, Forge007 DVs, ER SMIC's, VAST w/m, dynotune digital boost gauge,
    5% tint, In.pro chrome mirrors
    '08 Black crew cab/short bed F-350 6.4l twin turbo. 5" exhaust, 6" tip. AFE intake, Spartan custom tuned. 35X12.5R20. 2.5" lift.
    600hp/1200ftlbs
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    what about instead of just hotwiring it, put a small Single Pull/Single Throw switch hidden somehwere. maybe a push button or toggle switch.
    a push button momentary switch would be cool, so you actually have to be pushing the switch while tuning the key to start. basically the same idea of the stock clutch switch, but you use your finger to hold the button istead of your foot. maybe something like this:
    http://www.radioshack.com/product/in...ductId=2062545
    Red Car - Under the knife
    Silver Car - ALIVE
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Quote Originally Posted by gointoscott View Post
    Thanks
    Nice DIY !
    So how long did it take you for the whole thing ? 30 mins ?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    May 16 2008
    WA
    Quote Originally Posted by xuandatou View Post
    Nice DIY !
    That guy hasn't even so much as logged into the forum in 3 years. I wouldn't hold my breath waiting for him to respond.
    gointoscott
    Four Rings
    Join Date 01-26-2006
    Last Activity 10-25-2011 06:19 AM
    Veteran Member Four Rings JKnight41's Avatar
    Oct 11 2012
    Southern Illinois
    This is the DIY I was talking about. I would say you should give this a try. Just unbolting the knee bolster and putting a paperclip in the plug should only take you like 15 minutes at the very most
    -00 Hibiscus S4 Sedan (FOR SALE)
    -09 Audi S5 / SOLD
    -01 Audi S4 Avant / SOLD
    -04 Audi S4 / SOLD
    -00 Audi S4 Stage 2 / SOLD
    Oct 17 2012
    NoCal
    Quote Originally Posted by getslideways View Post
    gointoscott
    Four Rings
    haha
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Oct 17 2012
    NoCal
    Quote Originally Posted by JKnight41 View Post
    Thank you !
    So you would recommend just use the paperclip to stable the wires together (bypass the switch)?
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Oct 11 2012
    Southern Illinois
    Yes, as a temporary fix, if it works, then you know that it is the faulty switch. Then find the part number for the new one. Or try adjusting the plunger as stated above
    -09 Audi S5 / SOLD
    -04 Audi S4 / SOLD
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I usually just unplug the connector down there and pop one of the mini blade fuses in it.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    Oct 17 2012
    NoCal
    Quote Originally Posted by zillarob View Post
    So now you can start the engine without pressing the clutch pedal (eg. the passenger can start the engine as well by simply turning the key?)
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Nov 16 2010
    WetSide, WA
    Yup.
    Be careful, there is a reason they put it there.
    People die every year because "I thought it was in neutral".
    Oct 17 2012
    NoCal
    Yup.
    Thank you ! I will get it a try !
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Junior Member Two Rings sgudino's Avatar
    Jul 07 2012
    Mazda RX-8
    California
    Xuandatou, I am having the same issue. I am out of state right now but I will try the switch position first and then the part. Have you done it yet?
    Sergio
    2002 Audi A4 B6
    2004 Mazda RX-8
    1997 VW Jetta GT
    Oct 17 2012
    NoCal
    Quote Originally Posted by sgudino View Post
    I haven't get a chance to try it out yet, but I think it will be done by this weekend and I will definitely let you know how it works
    2001 S4 Avant
    Instagram
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Veteran Member Three Rings Audimilo's Avatar
    Apr 19 2014
    CO
    Just adjusted my Clutch Pedal Position switch, F194 - to accommodate for my new clutch and pressure plate setup, which doesn't require stomping the pedal to the floor any longer to activate the switch. was tight getting in there but worth it. thanks Zillarob for suggesting this.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    1) i've had 2 of these go bad and had to replace them
    2) i've had an issue where it wasn't aligned properly, and when i would shift the throttle body wouldn't shut and the rpms would climb a bit extra between shifts. this was a surprise result.
