Results 1 to 28 of 28
    Active Member One Ring everfresh's Avatar
    Nov 10 2009
    SQ5
    Crankcase Breather Valve
    Anyone have this problem? Took my car into Audi the other day for a routine oil change... car has 60K on it. They found the crankcase cover leaking oil, so they replaced the crankcase breather valve, cover and gasket... this a common problem?
    Senior Member Two Rings Jman25's Avatar
    May 18 2009
    98 A4
    PDX
    Re: Crankcase Breather Valve
    YEP! I think on all audis no matter make or model. I just replaced all my PCV tubes and valves, I was getting oil out the top under my oil cap. Yeah its a common problem for sure.
    Senior Member Three Rings jpcallmotor's Avatar
    Jan 11 2009
    B5 A4 1.8T
    Chicago
    Yes, those are prone to fall apart over time and break into pieces.
    Jan 04 2010
    Jeep Wrangler, VW Atlas
    Southeastern, CT
    i had a rough idle problem, they replaced crank case breather tube. car would stumble and almost stall when starting under 20 degrees F.
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    I believe it is a common problem. I had mine replaced (PCV valve) and it felt like my car came back to life. Car had 32,000 miles at the time. They said that my PCV was clogged/gunked up.
    Nov 10 2009
    SQ5
    Would a atmospheric or blow off valve prevent this problem? I guess alot of the pressure is being built up and cracks the seals...
    Mar 30 2009
    I think a catch can would prevent this problem. I think the more common issue is that the PCV gets clogged and in turn pressure starts to build up.
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    Quote Originally Posted by Giantsfan10 View Post
    They replaced mine and i still have this problem....
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Account Terminated Four Rings
    Jul 10 2008
    06 A4 / 09 IS-F / 10 Cayenne
    Austin, TX
    Quote Originally Posted by everfresh View Post
    Not necessarily. The PCV uses a diaphragm which is prone to failure. Basically, you have a few ways to fix it.
    1) Get the stage 1 PCV fix from BSH (bshspeedshop.com)
    2) Get the stage 2 PCV fix which includes a catch can from BSH
    3) Have the dealer replace the PCV system with an updated version
    The atmospheric BOV has nothing to do with the PCV system.
    Nov 10 2009
    SQ5
    That about covers it! Thanks...
    Quote Originally Posted by brownishwater View Post
    Oct 02 2006
    Wadsworth,OH
    The 2.0t has problems with PCV failure and oil seepage like you have describes. There have been several revisions to the PCV system. We carry a few different PCV fixes depending on year/VIN of your car. "L" is the latest revision for early VINs and "E" is the latest revision for late VINs.
    Click here for various PCV fix kits, it is an easy job to DIY: Click here for more info.
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    So if my car is under warranty and nothing is wrong with my car I can just go in a ask them to replace my PCV?
    Mar 30 2009
    Quote Originally Posted by B72.0T View Post
    In my situation I had oil around the coilpack area and around the oil cap. At first they replaced the valve cover (even though I told them I thought it was the PCV). Shortly afterwards, oil showed up again. This time around they actually replaced the PCV. I also told them that I noticed that the car wasn't pulling as nicely as it was, which was a result of the bad PCV. Regardless, usually there has to be a reason to have the item replaced. And my car is still under the original warranty.
    Dec 18 2009
    Pennsylvania
    ^ Ok thanks, so I cant just go in and be like "REPLACE MY PCV NOWWW!"
    Jul 10 2008
    Austin, TX
    Unfortunately, it all depends on the dealer. Most will require an MIL to perform the service. Never hurts to ask though.
    Veteran Member Four Rings chaze's Avatar
    Sep 16 2007
    2001 A4 Avant, 2009 328i
    Canyon Hills, CA
    Mine was replaced during my 25k mile Audi Care service. I had complained when I took it in of hard shudders during start-up, they checked and found that it was whistling so went ahead and replaced it.
    -Chris
    2001 A4 Avant - Apr '11 to Present
    2008 A4 Sedan - In the graveyard
    Veteran Member Four Rings nramsey's Avatar
    Dec 09 2004
    My car was leaking oil from the fill cap and valve cover gasket. No check engine lines or shudders or rough idle. The dealer replaced the valve and the oil leaks went away. That was at about 23k miles.
    - Nathan
    http://www.flickr.com/photos/nramsey
    2008 A4 2.0T Quattro Avant - Dolphin Gray
    Eibach Pro-Kit - Koni FSD - Rotiform MIAs
    Jun 07 2010
    san diego
    removing hoses
    When changing the crankcase vent valve how do I remove the two hoses without breaking them. They have some kind of clamp on the end of them.
    Jul 10 2008
    Austin, TX
    Quote Originally Posted by gustave View Post
    Pinch both ends (top and bottom) and pull.
    Established Member Two Rings envious's Avatar
    Dec 29 2009
    b5 a4, 1972 datsun 240z, 2004 nissan 350z, and a nissan titan(hate it)
    League City, Texas
    http://www.bshspeedshop.com/store/bs...-can-kits.html - is this the stage 2 pcv fix?
    live hard; play harder
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Quote Originally Posted by envious View Post
    That's for a 1.8t. Your sig says B7 S4, but you're posting on an A4 forum. Assuming you're in an A4, see below...
    http://www.bshspeedshop.com/store/home.php?cat=1113
    Justin
    DTM S4 Sprint Blue
    Jan 16 2008
    bosnia and herzegovina
    Quote Originally Posted by Jason@ECSTuning View Post
    HI, I have 2005 2.0 tfsi quattro and I need to ask,
    is it true that we who have the latest ,,L'' PCV revision need to have also a breather tube which goes down to turbo together with a check valve in it?
    (metal hose like in the picture above)??
    thanks
    OP
    Jan 04 2012
    Norcal/CA/USA
    Breather Valve Replaced under warranty
    Just found out this was my problem, symptom was a nasty whine coming from under the hood. My initial thought was a belt, but after closer inspection sounded like maybe the turbo or the vacuum system.
    I didn't put 2 and 2 together, there was a rather large oil mess under my hood when I first noticed the sound, I just assumed that it was the oil stop making a mess when they topped up my oil the other day!
    Sonnen in San Rafael, CA happily replaced it under warranty.
    --norcalwingman
    Jan 04 2012
    atlanta ga
    Im on my second one now. I had the same issues. super rouch idle. was like the damn engine was trying to break free!. ha, replaced it cleared up the issue. Then had something similar happen again, took it in because i was getting El flashing they ended up replaceing the valve again along with coil packs and something else i cant remeber rite off hand. Seems to happen often, the way the car acts as it happens tho makes you think the $h!ts falling to pieces.
    Feb 28 2012
    west islip, ny
    i just got my 2007audi a4 back from the dealer for the third time with c/o white exhaust with hard rapid acceleration and they have so far replaced my turbo, and a fuel injector which did not remedy the situation and now my crank breather valve...hopefully this resolves the problem..anyone having this problem with the white thick exhaust
    Veteran Member Four Rings Leo14's Avatar
    Mar 09 2010
    North E. Jerz
    Mine too just went lol, having it replaced as well as a bunch of other things
    RIP QG TI B7 A4
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Die zombie thread, die!
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Veteran Member Four Rings bman005's Avatar
    Sep 06 2011
    2015 Silverado, 2012 A4 Avant. Former; 90 Corrado, 97 Golf, 05.5 A4, 2010 Tiguan
    Harrisburg, Pa
    Quote Originally Posted by gemini5924 View Post
    You need a new dealer, if the breather was 3rd on their list the techs there are about as sharp as a volleyball
    New Build, 2010 Tiguan. Details to com
