Results 1 to 17 of 17
    Veteran Member Three Rings revbjeff's Avatar
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    225/45/18 will they fit
    I found an alright deal on some Hankook Ventus 225/45/18 will they fit on my A4 my wheels are 8.5" wide and I will be putting on H&R coils this weekend.
    Veteran Member Four Rings JEmm's Avatar
    Apr 27 2009
    Re: 225/45/18 will they fit
    You should be fine depending on how low you go on those coils...
    -Jeff
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    They will fit
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    thanks
    Dec 04 2007
    New York, NY
    225/40-18 is what you should be going with
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Really I have 235/40/18 right now
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    225/45/18 will have a pretty thick sidewall
    TEAM|AXION
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    i plan on upgrading to 18's and am going with 215/40r18's. theres a .04% difference in rolling circumference compared to factory 205/55/r16's which is the closest/lowest difference i could find. 1010tires.com has a tire size calculator that is very handy.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Mar 26 2005
    ^ as long as all 4 tires are the same size and brand/model, it will not ruin your diff.
    unless if you're talking about your speedometer accuracy.
    TEAM|AXION
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Yeah 1010tires.com says there is a 4% difference. I'll probably pass on them.
    Oct 02 2007
    Lone Tree, Colorado
    I have 225/40/18's right now on coilovers. I have ruined parts of my inner wheel well on both sides but only from hard driving and never changing the hieght on my coilovers after I upgraded from 17's to 18's. Nevertheless I still use the same wheel well liners and they are still fine and arent being worn down anymore at this point. 45's will be bigger tho...
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by revbjeff View Post
    +1, it's recommended to stay within 3% of your stock rolling circumference for speedometer accuracy
    Brandon @ VMR Wheels
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I'd be more worried about control arm clearance. Taller tires are a tight fit. It is easier to go wider than taller.
    Jim
    I Do Werk.
    Established Member Two Rings da1nonlymikeo's Avatar
    Feb 02 2009
    mn
    Quote Originally Posted by onemoremile View Post
    agree. I purchased the same set up on oz wheels and I did not clear the arms. so I put 225/25/18 on and it fits nicely.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    Quote Originally Posted by da1nonlymikeo View Post
    Do you have any pictures of these? That seems like a really short sidewall, does it have some stretch to them?
    Feb 02 2009
    mn
    pic:
    http://www.facebook.com/photo.php?pi...6&id=585679551
    sorry for the fbook link, i have old macbook and it will not let me attach photos to this..
    no side wall flex at all really. but 25 is the sweet spot i say, i dont like anything more, or anything less.
    Apr 22 2008
    00 2.8QM A4
    Leavenworth, KS
    link not working
